GitLab maintenance scheduled form Friday, 2021-06-18 5:00pm to Satursday, 2021-06-19 10:00pm CT - Services will be unavailable during this time.
Commit 8146ced2 authored by Jonathan Jenkins's avatar Jonathan Jenkins
simplify deprecation macro
parent d5d91fd3
......@@ -22,9 +22,9 @@
// simple deprecation attribute hacking
#if defined(__GNUC__) || defined(__GNUG__) || defined(__clang__)
#define DEPRECATED(_msg) __attribute__((deprecated))
#define DEPRECATED __attribute__((deprecated))
#else
#define DEPRECATED
#endif
/* HACK: there is currently no scheduling fidelity across multiple
......@@ -269,7 +269,7 @@ int model_net_get_msg_sz(int net_id);
/* NOTE: we may end up needing additoinal arguments here to track state for
* reverse computation; add as needed
DEPRECATED("use model_net_event_rc2 instead, invalid RNG rollback can occur otherwise")
DEPRECATED
void model_net_event_rc(
int net_id,
tw_lp *sender,
......@@ -325,7 +325,7 @@ model_net_event_return model_net_pull_event_mctx(
void const *self_event,
tw_lp *sender);
DEPRECATED
void model_net_pull_event_rc(
int net_id,
tw_lp *sender);
Markdown is supported
0%
or
Please register or to comment
