Commit 7fe1a55d authored by Philip Carns's avatar Philip Carns
Browse files
minor tweaks
parent 0a89fcac
...@@ -9,8 +9,7 @@ LPGROUPS ...@@ -9,8 +9,7 @@ LPGROUPS
PARAMS PARAMS
packet_size="512"; message_size="128";
message_size="256";
modelnet="loggp"; modelnet="loggp";
net_config_file="logp-param-table.conf"; net_config_file="logp-param-table.conf";
...@@ -26,7 +26,6 @@ ...@@ -26,7 +26,6 @@
/* TODO: these things should probably be configurable */ /* TODO: these things should probably be configurable */
#define NUM_PINGPONGS 1000 /* number of pingpong exchanges per msg size */ #define NUM_PINGPONGS 1000 /* number of pingpong exchanges per msg size */
#define MIN_SZ 4 #define MIN_SZ 4
#define MAX_SZ 67108864
#define NUM_SZS 25 #define NUM_SZS 25
static int net_id = 0; static int net_id = 0;
...@@ -63,6 +62,7 @@ struct svr_msg ...@@ -63,6 +62,7 @@ struct svr_msg
enum svr_event svr_event_type; enum svr_event svr_event_type;
tw_lpid src; /* source of this request or ack */ tw_lpid src; /* source of this request or ack */
int size; int size;
int sent_size; /* for rc */
static void svr_init( static void svr_init(
...@@ -289,6 +289,7 @@ static void handle_ping_rev_event( ...@@ -289,6 +289,7 @@ static void handle_ping_rev_event(
svr_msg * m, svr_msg * m,
tw_lp * lp) tw_lp * lp)
model_net_event_rc(net_id, lp, m->sent_size);
return; return;
...@@ -300,6 +301,7 @@ static void handle_pong_rev_event( ...@@ -300,6 +301,7 @@ static void handle_pong_rev_event(
ns->pingpongs_completed--; ns->pingpongs_completed--;
/* NOTE: we do not attempt to reverse timing information stored in /* NOTE: we do not attempt to reverse timing information stored in
* stat_array[]. This is will get rewritten with the correct value when * stat_array[]. This is will get rewritten with the correct value when
...@@ -353,6 +355,7 @@ static void handle_pong_event( ...@@ -353,6 +355,7 @@ static void handle_pong_event(
m_remote.size = stat_array[msg_sz_idx].msg_sz; m_remote.size = stat_array[msg_sz_idx].msg_sz;
/* send next ping */ /* send next ping */
m->sent_size = m_remote.size;
model_net_event(net_id, "ping", peer_gid, stat_array[msg_sz_idx].msg_sz, sizeof(m_remote), &m_remote, 0, NULL, lp); model_net_event(net_id, "ping", peer_gid, stat_array[msg_sz_idx].msg_sz, sizeof(m_remote), &m_remote, 0, NULL, lp);
return; return;
...@@ -374,6 +377,7 @@ static void handle_ping_event( ...@@ -374,6 +377,7 @@ static void handle_ping_event(
m_remote.size = m->size; m_remote.size = m->size;
/* send pong msg back to sender */ /* send pong msg back to sender */
model_net_event(net_id, "pong", m->src, m->size, sizeof(m_remote), &m_remote, 0, NULL, lp); model_net_event(net_id, "pong", m->src, m->size, sizeof(m_remote), &m_remote, 0, NULL, lp);
return; return;
Markdown is supported
0% or .
Please register or to comment
