Commit 7a4ac2f9 authored by Nikhil's avatar Nikhil
Bug fixes on idle status
Change-Id: I6677c21ebce465ab18ece457b839fa374615da75
parent 7ecf1a42
...@@ -1099,7 +1099,7 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg ...@@ -1099,7 +1099,7 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg
if(!num_chunks) if(!num_chunks)
num_chunks = 1; num_chunks = 1;
nic_ts = g_tw_lookahead + (num_chunks * s->params->cn_delay) + tw_rand_unif(lp->rng); nic_ts = g_tw_lookahead + (msg->packet_size * s->params->cn_delay) + tw_rand_unif(lp->rng);
msg->my_N_hop = 0; msg->my_N_hop = 0;
...@@ -1205,10 +1205,10 @@ void ft_packet_send_rc(ft_terminal_state * s, tw_bf *bf, fattree_message * msg, ...@@ -1205,10 +1205,10 @@ void ft_packet_send_rc(ft_terminal_state * s, tw_bf *bf, fattree_message * msg,
if(bf->c4) { if(bf->c4) {
s->in_send_loop = 1; s->in_send_loop = 1;
/*if(bf->c5) { if(bf->c5) {
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
s->issueIdle = 1; s->issueIdle = 1;
/* sends the packet from the compute node to the attached switch */ /* sends the packet from the compute node to the attached switch */
void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
...@@ -1311,12 +1311,12 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1311,12 +1311,12 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
s->in_send_loop = 0; s->in_send_loop = 0;
/* if(s->issueIdle) { if(s->issueIdle) {
bf->c5 = 1; bf->c5 = 1;
s->issueIdle = 0; s->issueIdle = 0;
model_net_method_idle_event(codes_local_latency(lp), 0, lp); model_net_method_idle_event(codes_local_latency(lp), 0, lp);
return; return;
...@@ -1700,11 +1700,6 @@ void ft_terminal_buf_update(ft_terminal_state * s, tw_bf * bf, ...@@ -1700,11 +1700,6 @@ void ft_terminal_buf_update(ft_terminal_state * s, tw_bf * bf,
//printf("[%d] term buf Send to %d\n", lp->gid, lp->gid); //printf("[%d] term buf Send to %d\n", lp->gid, lp->gid);
tw_event_send(e); tw_event_send(e);
else if(s->in_send_loop == 0 && s->terminal_msgs[0] == NULL)
bf->c2 = 1;
model_net_method_idle_event(ts, 0, lp);
return; return;
Markdown is supported
0%
or
Please register or to comment
