Commit 768cd3d7 authored by Noah Wolfe's avatar Noah Wolfe
Browse files
Changes made during bluejeans hack. Added tracer-fattree-type2.conf
parent 6c8404d2
......@@ -2,15 +2,15 @@ LPGROUPS
MODELNET_GRP
repetitions="2";
server="4";
modelnet_fattree="4";
fattree_switch="3";
repetitions="4"; #Number of leaf level switches
server="2";
modelnet_fattree="2";
fattree_switch="2";
PARAMS
ft_type="0"; # Only appears to be one type (type=0) in fattree.c
ft_type="1"; # Only appears to be one type (type=0) in fattree.c
num_levels="2"; # Must be 1 < num_levels < 4
switch_count="2,4"; # Some sort of csv string. I'm thinking it's the number of switches per level
switch_radix="4,4"; # Another csv string. I'm thinking it's the radix of the switches per level. All switches within same level have same radix
LPGROUPS
MODELNET_GRP
repetitions="16";
server="4";
fattree_switch="3";
PARAMS
ft_type="1";
packet_size="1024";
message_size="512";
modelnet_scheduler="fcfs";
#modelnet_scheduler="round-robin";
modelnet_order=( "fattree" );
num_levels="3";
switch_count="16";
switch_radix="8";
router_delay="60";
soft_delay="1000";
vc_size="65536";
cn_vc_size="65536";
link_bandwidth="4.7";
cn_bandwidth="5.25";
......@@ -180,7 +180,7 @@ static void handle_kickoff_event(
// assert(net_id == FATTREE); /* only supported for fat tree model right now. */
ns->start_ts = tw_now(lp);
printf("Kicking off events\n");
codes_mapping_get_lp_info(lp->gid, group_name, &group_index, lp_type_name, &lp_type_index, anno, &rep_id, &offset);
/* in case of uniform random traffic, send to a random destination. */
if(traffic == UNIFORM)
......@@ -198,9 +198,11 @@ static void handle_kickoff_event(
local_dest = (rep_id * 2 + offset + 2) % num_nodes;
// printf("\n LP %ld sending to %ld num nodes %d ", rep_id * 2 + offset, local_dest, num_nodes);
*/ assert(local_dest < num_nodes);
codes_mapping_get_lp_id(group_name, lp_type_name, anno, 1, local_dest / num_servers_per_rep, local_dest % num_servers_per_rep, &global_dest);
*/// assert(local_dest < num_nodes);
// codes_mapping_get_lp_id(group_name, lp_type_name, anno, 1, local_dest / num_servers_per_rep, local_dest % num_servers_per_rep, &global_dest);
global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0);
printf("global_dest:%d local_dest:%d\n",(int)global_dest,(int)local_dest);
ns->msg_sent_count++;
model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp);
issue_event(ns, lp);
......@@ -316,7 +318,7 @@ int main(
int argc,
char **argv)
printf("program start\n");
int nprocs;
int rank;
int num_nets;
......@@ -326,9 +328,9 @@ printf("program start\n");
lp_io_handle handle;
tw_opt_add(app_opt);
printf("Pre timewarp init\n");
tw_init(&argc, &argv);
printf("Post timewarp init\n");
offset = 1;
if(argc < 2)
......@@ -342,13 +344,13 @@ printf("Post timewarp init\n");
MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
configuration_load(argv[2], MPI_COMM_WORLD, &config);
printf("loaded configuration\n");
model_net_register();
printf("Registered model-net\n");
svr_add_lp_type();
printf("Added LP types\n");
codes_mapping_setup();
printf("Setup Codes mapping\n");
net_ids = model_net_configure(&num_nets);
assert(num_nets==1);
......@@ -369,6 +371,10 @@ printf("Setup Codes mapping\n");
num_nodes = num_groups * num_routers_per_grp * (num_routers_per_grp / 2);
num_nodes_per_grp = num_routers_per_grp * (num_routers_per_grp / 2);
num_nodes = codes_mapping_get_lp_count("MODELNET_GRP", 0, "server", NULL, 1);
if(lp_io_prepare("modelnet-test", LP_IO_UNIQ_SUFFIX, &handle, MPI_COMM_WORLD) < 0)
return(-1);
Markdown is supported
0% or .
Please register or to comment
