Commit 75cdb76f authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Merging branch llnl-updates with master
parents e7c122ef 101e99a7
...@@ -29,6 +29,7 @@ extern "C" { ...@@ -29,6 +29,7 @@ extern "C" {
#include "net/simplenet-upd.h" #include "net/simplenet-upd.h"
#include "net/simplep2p.h" #include "net/simplep2p.h"
#include "net/torus.h" #include "net/torus.h"
#include "net/express-mesh.h"
extern int model_net_base_magic; extern int model_net_base_magic;
...@@ -90,6 +91,8 @@ void model_net_method_send_msg_recv_event_rc(tw_lp *sender); ...@@ -90,6 +91,8 @@ void model_net_method_send_msg_recv_event_rc(tw_lp *sender);
// method - strange and disturbing things will happen otherwise // method - strange and disturbing things will happen otherwise
void model_net_method_idle_event(tw_stime offset_ts, int is_recv_queue, void model_net_method_idle_event(tw_stime offset_ts, int is_recv_queue,
tw_lp * lp); tw_lp * lp);
void model_net_method_idle_event2(tw_stime offset_ts, int is_recv_queue,
int queue_offset, tw_lp * lp);
// Get a ptr to past the message struct area, where the self/remote events // Get a ptr to past the message struct area, where the self/remote events
// are located, given the type of network. // are located, given the type of network.
...@@ -114,6 +117,8 @@ typedef struct model_net_base_msg { ...@@ -114,6 +117,8 @@ typedef struct model_net_base_msg {
// no need for event type - in wrap message // no need for event type - in wrap message
model_net_request req; model_net_request req;
int is_from_remote; int is_from_remote;
int isQueueReq;
tw_stime save_ts;
// parameters to pass to new messages (via model_net_set_msg_params) // parameters to pass to new messages (via model_net_set_msg_params)
// TODO: make this a union for multiple types of parameters // TODO: make this a union for multiple types of parameters
mn_sched_params sched_params; mn_sched_params sched_params;
...@@ -132,6 +137,7 @@ typedef struct model_net_wrap_msg { ...@@ -132,6 +137,7 @@ typedef struct model_net_wrap_msg {
sn_message m_snet; // simplenet sn_message m_snet; // simplenet
sp_message m_sp2p; // simplep2p sp_message m_sp2p; // simplep2p
nodes_message m_torus; // torus nodes_message m_torus; // torus
em_message m_em; // express-mesh
// add new ones here // add new ones here
} msg; } msg;
} model_net_wrap_msg; } model_net_wrap_msg;
...@@ -72,6 +72,8 @@ typedef struct mn_stats mn_stats; ...@@ -72,6 +72,8 @@ typedef struct mn_stats mn_stats;
X(DRAGONFLY_CUSTOM, "modelnet_dragonfly_custom", "dragonfly_custom", &dragonfly_custom_method)\ X(DRAGONFLY_CUSTOM, "modelnet_dragonfly_custom", "dragonfly_custom", &dragonfly_custom_method)\
X(DRAGONFLY_CUSTOM_ROUTER, "modelnet_dragonfly_custom_router", "dragonfly_custom_router", &dragonfly_custom_router_method)\ X(DRAGONFLY_CUSTOM_ROUTER, "modelnet_dragonfly_custom_router", "dragonfly_custom_router", &dragonfly_custom_router_method)\
X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\ X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\
X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\
X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\
X(MAX_NETS, NULL, NULL, NULL) X(MAX_NETS, NULL, NULL, NULL)
#define X(a,b,c,d) a, #define X(a,b,c,d) a,
...@@ -123,6 +125,7 @@ typedef struct model_net_request { ...@@ -123,6 +125,7 @@ typedef struct model_net_request {
uint64_t msg_id; uint64_t msg_id;
int net_id; int net_id;
int is_pull; int is_pull;
int queue_offset;
int remote_event_size; int remote_event_size;
int self_event_size; int self_event_size;
char category[CATEGORY_NAME_MAX]; char category[CATEGORY_NAME_MAX];
#ifndef COMMON_NET_H
#define COMMON_NET_H
#include "codes/model-net-lp.h"
#include "codes/quickhash.h"
#ifdef __cplusplus
extern "C" {
#endif
struct mn_hash_key
uint64_t message_id;
tw_lpid sender_id;
struct mn_qhash_entry
struct mn_hash_key key;
char * remote_event_data;
int num_chunks;
struct qhash_head hash_link;
extern int mn_rank_hash_compare(void *key, struct qhash_head *link);
extern int mn_hash_func(void *k, int table_size);
extern void free_tmp(void * ptr);
typedef struct message_list message_list;
struct message_list {
union {
terminal_message dfly_msg;
em_message em_msg;
char* event_data;
message_list *next;
message_list *prev;
int port, index;
message_list *altq_next, *altq_prev;
int in_alt_q, altq_port;
extern void append_to_message_list(
message_list ** thisq,
message_list ** thistail,
int index,
message_list *msg);
extern void prepend_to_message_list(
int index,
message_list *msg);
extern message_list* return_head(
int index);
extern message_list* return_tail(
int index);
extern void delete_from_message_list(
message_list *** allq,
message_list *** alltail,
message_list *msg);
extern void add_to_message_list(
message_list *msg);
extern void altq_append_to_message_list(
int index,
message_list *msg);
extern void altq_prepend_to_message_list(
int index,
message_list *msg);
extern message_list* altq_return_head(
int index);
extern message_list* altq_return_tail(
int index);
extern void altq_delete_from_message_list(
message_list *msg);
extern void altq_add_to_message_list(
message_list *msg);
extern void delete_message_list(void *thism);
extern tw_stime bytes_to_ns(uint64_t bytes, double GB_p_s);
#ifdef __cplusplus
#endif
#endif
* Copyright (C) 2014 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#ifndef EXPRESS_MESH_H
#define EXPRESS_MESH_H
#ifdef __cplusplus
extern "C" {
#endif
#include <ross.h>
typedef struct em_message em_message;
struct em_message
/* magic number */
int magic;
/* flit travel start time*/
tw_stime travel_start_time;
/* packet ID of the flit */
unsigned long long packet_ID;
/* event type of the flit */
short type;
/* category: comes from codes */
/* final destination LP ID, this comes from codes can be a server or any other LP type*/
tw_lpid final_dest_gid;
/*sending LP ID from CODES, can be a server or any other LP type */
tw_lpid sender_lp;
tw_lpid sender_mn_lp; // source modelnet id
/* destination terminal ID */
tw_lpid dest_terminal_id;
int dest_terminal;
/* source terminal ID */
tw_lpid src_terminal_id;
short saved_channel;
short my_N_hop;
short hops[8];
/* Intermediate LP ID from which this message is coming */
unsigned int intm_lp_id;
short saved_vc;
short dim_change;
/* last hop of the message, can be a terminal, local router or global router */
int last_hop;
/* For routing */
uint64_t chunk_id;
uint64_t packet_size;
uint64_t total_size;
int saved_remote_esize;
int remote_event_size_bytes;
int local_event_size_bytes;
// For buffer message
int vc_index;
int output_chan;
model_net_event_return event_rc;
int is_pull;
uint64_t pull_size;
/* for reverse computation */
tw_stime saved_available_time;
tw_stime saved_avg_time;
tw_stime saved_rcv_time;
tw_stime saved_busy_time;
tw_stime saved_total_time;
tw_stime saved_hist_start_time;
tw_stime saved_sample_time;
tw_stime msg_start_time;
int saved_hist_num;
int saved_occupancy;
#ifdef __cplusplus
#endif
#endif
...@@ -49,6 +49,7 @@ struct fattree_message ...@@ -49,6 +49,7 @@ struct fattree_message
// For buffer message // For buffer message
short vc_index; short vc_index;
short rail_id;
short vc_off; short vc_off;
model_net_event_return event_rc; model_net_event_return event_rc;
...@@ -87,6 +87,7 @@ nobase_include_HEADERS = \ ...@@ -87,6 +87,7 @@ nobase_include_HEADERS = \
codes/model-net-lp.h \ codes/model-net-lp.h \
codes/model-net-sched.h \ codes/model-net-sched.h \
codes/model-net-inspect.h \ codes/model-net-inspect.h \
codes/net/common-net.h \
codes/net/dragonfly.h \ codes/net/dragonfly.h \
codes/net/dragonfly-custom.h \ codes/net/dragonfly-custom.h \
codes/net/slimfly.h \ codes/net/slimfly.h \
...@@ -94,6 +95,7 @@ nobase_include_HEADERS = \ ...@@ -94,6 +95,7 @@ nobase_include_HEADERS = \
codes/net/loggp.h \ codes/net/loggp.h \
codes/net/simplenet-upd.h \ codes/net/simplenet-upd.h \
codes/net/simplep2p.h \ codes/net/simplep2p.h \
codes/net/express-mesh.h \
codes/net/torus.h \ codes/net/torus.h \
codes/codes-mpi-replay.h \ codes/codes-mpi-replay.h \
codes/configfile.h codes/configfile.h
...@@ -149,8 +151,10 @@ src_libcodes_la_SOURCES = \ ...@@ -149,8 +151,10 @@ src_libcodes_la_SOURCES = \
codes/rc-stack.h \ codes/rc-stack.h \
src/util/rc-stack.c \ src/util/rc-stack.c \
src/networks/model-net/model-net.c \ src/networks/model-net/model-net.c \
src/networks/model-net/common-net.c \
src/networks/model-net/simplenet-upd.c \ src/networks/model-net/simplenet-upd.c \
src/networks/model-net/torus.c \ src/networks/model-net/torus.c \
src/networks/model-net/express-mesh.C \
src/networks/model-net/dragonfly.c \ src/networks/model-net/dragonfly.c \
src/networks/model-net/dragonfly-custom.C \ src/networks/model-net/dragonfly-custom.C \
src/networks/model-net/slimfly.c \ src/networks/model-net/slimfly.c \
#line 2 "codeslexer.c" #line 2 "../src/iokernellang/codeslexer.c"
#line 4 "codeslexer.c" #line 4 "../src/iokernellang/codeslexer.c"
#define YY_INT_ALIGNED short int #define YY_INT_ALIGNED short int
...@@ -54,6 +54,7 @@ typedef int flex_int32_t; ...@@ -54,6 +54,7 @@ typedef int flex_int32_t;
typedef unsigned char flex_uint8_t; typedef unsigned char flex_uint8_t;
typedef unsigned short int flex_uint16_t; typedef unsigned short int flex_uint16_t;
typedef unsigned int flex_uint32_t; typedef unsigned int flex_uint32_t;
#endif /* ! C99 */
/* Limits of integral types. */ /* Limits of integral types. */
#ifndef INT8_MIN #ifndef INT8_MIN
...@@ -84,8 +85,6 @@ typedef unsigned int flex_uint32_t; ...@@ -84,8 +85,6 @@ typedef unsigned int flex_uint32_t;
#define UINT32_MAX (4294967295U) #define UINT32_MAX (4294967295U)
#endif #endif
#endif /* ! C99 */
#endif /* ! FLEXINT_H */ #endif /* ! FLEXINT_H */
#ifdef __cplusplus #ifdef __cplusplus
...@@ -159,15 +158,7 @@ typedef void* yyscan_t; ...@@ -159,15 +158,7 @@ typedef void* yyscan_t;
/* Size of default input buffer. */ /* Size of default input buffer. */
#ifndef YY_BUF_SIZE #ifndef YY_BUF_SIZE
#ifdef __ia64__
/* On IA-64, the buffer size is 16k, not 8k.
* Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
* Ditto for the __ia64__ case accordingly.
#define YY_BUF_SIZE 32768
#else
#define YY_BUF_SIZE 16384 #define YY_BUF_SIZE 16384
#endif /* __ia64__ */
#endif #endif
/* The state buf must be large enough to hold one state per character in the main buffer. /* The state buf must be large enough to hold one state per character in the main buffer.
...@@ -538,20 +529,20 @@ static yyconst flex_int32_t yy_rule_can_match_eol[37] = ...@@ -538,20 +529,20 @@ static yyconst flex_int32_t yy_rule_can_match_eol[37] =
#define yymore() yymore_used_but_not_detected #define yymore() yymore_used_but_not_detected
#define YY_MORE_ADJ 0 #define YY_MORE_ADJ 0
#define YY_RESTORE_YY_MORE_OFFSET #define YY_RESTORE_YY_MORE_OFFSET
#line 1 "codeslexer.l" #line 1 "../src/iokernellang/codeslexer.l"
* Copyright (C) 2013 University of Chicago. * Copyright (C) 2013 University of Chicago.
* See COPYRIGHT notice in top-level directory. * See COPYRIGHT notice in top-level directory.
#line 8 "codeslexer.l" #line 8 "../src/iokernellang/codeslexer.l"
#include <stdlib.h> #include <stdlib.h>
#include "CodesIOKernelTypes.h" #include "src/iokernellang/CodesIOKernelTypes.h"
#include "CodesIOKernelParser.h" #include "src/iokernellang/CodesIOKernelParser.h"
#define YY_NO_INPUT #define YY_NO_INPUT
#line 25 "codeslexer.l" #line 25 "../src/iokernellang/codeslexer.l"
YYLTYPE *CodesIOKernel_get_lloc (yyscan_t yyscanner); YYLTYPE *CodesIOKernel_get_lloc (yyscan_t yyscanner);
int CodesIOKernel_lex_init (yyscan_t* scanner); int CodesIOKernel_lex_init (yyscan_t* scanner);
int CodesIOKernel_lex(YYSTYPE * lvalp, YYLTYPE * llocp, void * scanner); int CodesIOKernel_lex(YYSTYPE * lvalp, YYLTYPE * llocp, void * scanner);
...@@ -568,7 +559,7 @@ static yyconst flex_int32_t yy_rule_can_match_eol[37] = ...@@ -568,7 +559,7 @@ static yyconst flex_int32_t yy_rule_can_match_eol[37] =
#define YY_USER_ACTION /* no user action */; #define YY_USER_ACTION /* no user action */;
#endif #endif
#line 572 "codeslexer.c" #line 563 "../src/iokernellang/codeslexer.c"
#define INITIAL 0 #define INITIAL 0
...@@ -703,12 +694,7 @@ static int input (yyscan_t yyscanner ); ...@@ -703,12 +694,7 @@ static int input (yyscan_t yyscanner );
/* Amount of stuff to slurp up with each read. */ /* Amount of stuff to slurp up with each read. */
#ifndef YY_READ_BUF_SIZE #ifndef YY_READ_BUF_SIZE
#ifdef __ia64__
/* On IA-64, the buffer size is 16k, not 8k */
#define YY_READ_BUF_SIZE 16384
#else
#define YY_READ_BUF_SIZE 8192 #define YY_READ_BUF_SIZE 8192
#endif #endif
/* Copy whatever the last rule matched to the standard output. */ /* Copy whatever the last rule matched to the standard output. */
...@@ -727,7 +713,7 @@ static int input (yyscan_t yyscanner ); ...@@ -727,7 +713,7 @@ static int input (yyscan_t yyscanner );
if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \ if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \
int c = '*'; \ int c = '*'; \
size_t n; \ unsigned n; \
for ( n = 0; n < max_size && \ for ( n = 0; n < max_size && \
(c = getc( yyin )) != EOF && c != '\n'; ++n ) \ (c = getc( yyin )) != EOF && c != '\n'; ++n ) \
buf[n] = (char) c; \ buf[n] = (char) c; \
...@@ -812,10 +798,10 @@ YY_DECL ...@@ -812,10 +798,10 @@ YY_DECL
register int yy_act; register int yy_act;
struct yyguts_t * yyg = (struct yyguts_t*)yyscanner; struct yyguts_t * yyg = (struct yyguts_t*)yyscanner;
#line 43 "codeslexer.l" #line 43 "../src/iokernellang/codeslexer.l"
#line 819 "codeslexer.c" #line 805 "../src/iokernellang/codeslexer.c"
yylval = yylval_param; yylval = yylval_param;
...@@ -916,7 +902,7 @@ do_action: /* This label is used only to access EOF actions. */ ...@@ -916,7 +902,7 @@ do_action: /* This label is used only to access EOF actions. */
case 1: case 1:
YY_RULE_SETUP YY_RULE_SETUP
#line 45 "codeslexer.l" #line 45 "../src/iokernellang/codeslexer.l"
if(yyextra->text != NULL) if(yyextra->text != NULL)
...@@ -929,7 +915,7 @@ YY_RULE_SETUP ...@@ -929,7 +915,7 @@ YY_RULE_SETUP
YY_BREAK YY_BREAK
case 2: case 2:
#line 55 "codeslexer.l" #line 55 "../src/iokernellang/codeslexer.l"
...@@ -942,7 +928,7 @@ YY_RULE_SETUP ...@@ -942,7 +928,7 @@ YY_RULE_SETUP
YY_BREAK YY_BREAK
case 3: case 3:
#line 65 "codeslexer.l" #line 65 "../src/iokernellang/codeslexer.l"
...@@ -955,7 +941,7 @@ YY_RULE_SETUP ...@@ -955,7 +941,7 @@ YY_RULE_SETUP
YY_BREAK YY_BREAK
case 4: case 4:
#line 75 "codeslexer.l" #line 75 "../src/iokernellang/codeslexer.l"
...@@ -967,166 +953,166 @@ YY_RULE_SETUP ...@@ -967,166 +953,166 @@ YY_RULE_SETUP
YY_BREAK YY_BREAK
case 5: case 5:
#line 84 "codeslexer.l" #line 84 "../src/iokernellang/codeslexer.l"
return GE; return GE;
YY_BREAK YY_BREAK
case 6: case 6:
#line 85 "codeslexer.l" #line 85 "../src/iokernellang/codeslexer.l"
return LE; return LE;
YY_BREAK YY_BREAK
case 7: case 7:
#line 86 "codeslexer.l" #line 86 "../src/iokernellang/codeslexer.l"
return EQ; return EQ;
YY_BREAK YY_BREAK
case 8: case 8:
#line 87 "codeslexer.l" #line 87 "../src/iokernellang/codeslexer.l"
return NE; return NE;
YY_BREAK YY_BREAK
case 9: case 9:
#line 88 "codeslexer.l" #line 88 "../src/iokernellang/codeslexer.l"
return WHILE; return WHILE;
YY_BREAK YY_BREAK
case 10: case 10:
#line 89 "codeslexer.l" #line 89 "../src/iokernellang/codeslexer.l"
return IF; return IF;
YY_BREAK YY_BREAK
case 11: case 11:
#line 90 "codeslexer.l" #line 90 "../src/iokernellang/codeslexer.l"
return ELSE; return ELSE;
YY_BREAK YY_BREAK
case 12: case 12:
#line 91 "codeslexer.l" #line 91 "../src/iokernellang/codeslexer.l"
return PRINT; return PRINT;
YY_BREAK YY_BREAK
case 13: case 13:
#line 92 "codeslexer.l" #line 92 "../src/iokernellang/codeslexer.l"
return WRITE; return WRITE;
YY_BREAK YY_BREAK
case 14: case 14:
#line 93 "codeslexer.l" #line 93 "../src/iokernellang/codeslexer.l"
