Commit 74feda70 authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly Custom: add route verification methods
parent 90aa47c4
...@@ -178,6 +178,8 @@ struct dragonfly_param ...@@ -178,6 +178,8 @@ struct dragonfly_param
double global_delay; double global_delay;
double credit_delay; double credit_delay;
double router_delay; double router_delay;
int max_hops_notify; //maximum number of hops allowed before notifying via printout
static const dragonfly_param* stored_params; static const dragonfly_param* stored_params;
...@@ -535,6 +537,7 @@ void dragonfly_print_params(const dragonfly_param *p) ...@@ -535,6 +537,7 @@ void dragonfly_print_params(const dragonfly_param *p)
printf("\tcredit_delay = %.2f\n",p->credit_delay); printf("\tcredit_delay = %.2f\n",p->credit_delay);
printf("\trouter_delay = %.2f\n",p->router_delay); printf("\trouter_delay = %.2f\n",p->router_delay);
printf("\trouting = %d\n",routing); printf("\trouting = %d\n",routing);
printf("\tmax hops notification = %d\n",p->max_hops_notify);
printf("------------------------------------------------------\n\n"); printf("------------------------------------------------------\n\n");
...@@ -647,6 +650,12 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -647,6 +650,12 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
routing = -1; routing = -1;
rc = configuration_get_value_int(&config, "PARAMS", "notification_on_hops_greater_than", anno, &p->max_hops_notify);
if (rc) {
printf("Maximum hops for notifying not specified, setting to INT MAX\n");
p->max_hops_notify = INT_MAX;
// rc = configuration_get_value_int(&config, "PARAMS", "num_vcs_override", anno, &p->num_vcs); // rc = configuration_get_value_int(&config, "PARAMS", "num_vcs_override", anno, &p->num_vcs);
// if(rc) { // if(rc) {
// if(routing == PROG_ADAPTIVE) // if(routing == PROG_ADAPTIVE)
...@@ -1649,6 +1658,11 @@ static void send_remote_event(terminal_state * s, terminal_custom_message * msg, ...@@ -1649,6 +1658,11 @@ static void send_remote_event(terminal_state * s, terminal_custom_message * msg,
static void packet_arrive(terminal_state * s, tw_bf * bf, terminal_custom_message * msg, static void packet_arrive(terminal_state * s, tw_bf * bf, terminal_custom_message * msg,
tw_lp * lp) { tw_lp * lp) {
if (msg->my_N_hop > s->params->max_hops_notify)
printf("Terminal received a packet with %d hops! (Notify on > than %d)\n",msg->my_N_hop, s->params->max_hops_notify);
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
// Trigger an event on receiving server // Trigger an event on receiving server
...@@ -2873,6 +2887,83 @@ static int do_global_adaptive_routing( router_state * s, ...@@ -2873,6 +2887,83 @@ static int do_global_adaptive_routing( router_state * s,
static void router_verify_valid_receipt(router_state *s, tw_bf *bf, terminal_custom_message *msg, tw_lp *lp)
printf("Router received a packet with %d hops so far! (Notify on > than %d)\n",msg->my_N_hop, s->params->max_hops_notify);
bool has_valid_connection;
if (msg->last_hop == TERMINAL) {
tw_lpid src_term_lpgid = msg->src_terminal_id;
int src_term_rel_id;
try {
src_term_rel_id = codes_mapping_get_lp_relative_id(src_term_lpgid,0,0);
catch (...) {
tw_error(TW_LOC, "\nRouter Receipt Verify: Codes Mapping Get LP Rel ID Failure - Terminal");
has_valid_connection = (s->router_id == (src_term_rel_id / s->params->num_cn)); //a router can only receive a packet from a terminal if that terminal belongs to it
if (!has_valid_connection) {
tw_error(TW_LOC, "\nRouter received packet from non-existent connection - Terminal\n");
else if (msg->last_hop == LOCAL) {
int rel_id;
try {
rel_id = codes_mapping_get_lp_relative_id(msg->intm_lp_id,0,0);
catch (...) {
tw_error(TW_LOC, "\nRouter Receipt Verify: Codes Mapping Get LP Rel ID Failure - Local");
int my_loc_id = s->router_id % s->params->num_routers;
int intm_loc_id = rel_id % s->params->num_routers;
if (intraGroupLinks[my_loc_id][intm_loc_id].size() > 0)
has_valid_connection = true;
else
has_valid_connection = false;
tw_error(TW_LOC, "\nRouter received packet from non-existent connection - Local\n");
else if (msg->last_hop == GLOBAL) {
int rel_id;
try {
rel_id = rel_id = codes_mapping_get_lp_relative_id(msg->intm_lp_id,0,0);
catch (...) {
tw_error(TW_LOC, "\nRouter Receipt Verify: Codes Mapping Get LP Rel ID Failure - Global");
int rel_id_grp_id = rel_id / s->params->num_routers;
if (interGroupLinks[s->router_id][rel_id_grp_id].size() > 0)
else
tw_error(TW_LOC, "\nRouter received packet from non-existent connection - Global\n");
else {
tw_error(TW_LOC, "\nUnspecified msg->last_hop when received by a router\n");
static void router_packet_receive_rc(router_state * s, static void router_packet_receive_rc(router_state * s,
tw_bf * bf, tw_bf * bf,
terminal_custom_message * msg, terminal_custom_message * msg,
...@@ -2952,6 +3043,9 @@ router_packet_receive( router_state * s, ...@@ -2952,6 +3043,9 @@ router_packet_receive( router_state * s,
tw_lp * lp ) tw_lp * lp )
router_verify_valid_receipt(s, bf, msg, lp);
router_ecount++; router_ecount++;
tw_stime ts; tw_stime ts;
Markdown is supported
0%
or
Please register or to comment
