Commit 730f50ca authored by Shane Snyder's avatar Shane Snyder
Browse files
Bug fixes in the recorder workload plugin
The plugin was not destroying a hash table properly, causing
segfaults. Also, the workload did not close open files or
directories, causing an error on the number of open file
descriptors.
parent 08356edd
...@@ -140,6 +140,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -140,6 +140,7 @@ static int recorder_io_workload_load(const char *params, int rank)
if(entry->d_type == DT_REG) if(entry->d_type == DT_REG)
nprocs++; nprocs++;
closedir(dirp);
char *trace_file_name = (char*) malloc(sizeof(char) * 1024); char *trace_file_name = (char*) malloc(sizeof(char) * 1024);
sprintf(trace_file_name, "%s/log.%d", trace_dir, rank); sprintf(trace_file_name, "%s/log.%d", trace_dir, rank);
...@@ -171,7 +172,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -171,7 +172,7 @@ static int recorder_io_workload_load(const char *params, int rank)
token = strtok(NULL, ", "); token = strtok(NULL, ", ");
strcpy(function_name, token); strcpy(function_name, token);
// printf("function_name=%s:\n", function_name); //printf("function_name=%s:\n", function_name);
struct recorder_trace rt; struct recorder_trace rt;
...@@ -245,15 +246,23 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -245,15 +246,23 @@ static int recorder_io_workload_load(const char *params, int rank)
rt.trace_params.write.size = size; rt.trace_params.write.size = size;
else if(!strcmp(function_name, "MPI_Barrier")) {
rt.rank = rank;
rt.type = BARRIER;
rt.start_time = start_time;
else{
continue;
new->traces[i] = rt; new->traces[i] = rt;
new->last_trace_in_memory_index = i; new->last_trace_in_memory_index = i;
new->last_line_read = ftell(trace_file); new->last_line_read = ftell(trace_file);
new->trace_list_ndx = 0; new->trace_list_ndx = 0;
/* initialize the hash table of rank contexts, if it has not been initialized */ /* initialize the hash table of rank contexts, if it has not been initialized */
if (!rank_tbl) { if (!rank_tbl) {
...@@ -269,6 +278,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -269,6 +278,7 @@ static int recorder_io_workload_load(const char *params, int rank)
/* add this rank context to the hash table */ /* add this rank context to the hash table */
qhash_add(rank_tbl, &(new->rank), &(new->hash_link)); qhash_add(rank_tbl, &(new->rank), &(new->hash_link));
rank_tbl_pop++; rank_tbl_pop++;
fclose(trace_file);
return 0; return 0;
...@@ -283,8 +293,10 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op ...@@ -283,8 +293,10 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op
/* Find event context for this rank in the rank hash table */ /* Find event context for this rank in the rank hash table */
hash_link = qhash_search(rank_tbl, &rank); hash_link = qhash_search(rank_tbl, &rank);
/* terminate the workload if there is no valid rank context */ /* terminate the workload if there is no valid rank context */
if(!hash_link) { if(!hash_link) {
op->op_type = CODES_WK_END; op->op_type = CODES_WK_END;
return; return;
...@@ -304,14 +316,17 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op ...@@ -304,14 +316,17 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op
free(tmp); free(tmp);
rank_tbl_pop--; rank_tbl_pop--;
if(!rank_tbl_pop) if(!rank_tbl_pop)
qhash_finalize(rank_tbl); qhash_finalize(rank_tbl);
rank_tbl = NULL;
else { else {
/* return the next event */ /* return the next event */
/* TODO: Do I need to check for the delay like in Darshan? */ /* TODO: Do I need to check for the delay like in Darshan? */
next_trace = tmp->traces[tmp->trace_list_ndx]; next_trace = tmp->traces[tmp->trace_list_ndx];
*op = recorder_trace_to_codes_workload_op(next_trace); *op = recorder_trace_to_codes_workload_op(next_trace);
// tmp->last_event_time = next_event.end_time // tmp->last_event_time = next_event.end_time
tmp->trace_list_ndx++; tmp->trace_list_ndx++;
...@@ -325,6 +340,7 @@ static struct codes_workload_op recorder_trace_to_codes_workload_op(struct recor ...@@ -325,6 +340,7 @@ static struct codes_workload_op recorder_trace_to_codes_workload_op(struct recor
struct codes_workload_op codes_op; struct codes_workload_op codes_op;
switch (trace.type) switch (trace.type)
case POSIX_OPEN: case POSIX_OPEN:
codes_op.op_type = CODES_WK_OPEN; codes_op.op_type = CODES_WK_OPEN;
Markdown is supported
0% or .
Please register or to comment
