Commit 70488a96 authored by Philip Carns's avatar Philip Carns
Browse files
reverse computation in test harness
parent 1916b7e7
...@@ -40,6 +40,7 @@ struct client_msg ...@@ -40,6 +40,7 @@ struct client_msg
enum client_event_type event_type; enum client_event_type event_type;
int barrier_count; int barrier_count;
struct codes_workload_op op_rc;
static void handle_client_op_loop_rev_event( static void handle_client_op_loop_rev_event(
...@@ -63,6 +64,7 @@ static void handle_client_op_barrier_event( ...@@ -63,6 +64,7 @@ static void handle_client_op_barrier_event(
client_msg * m, client_msg * m,
tw_lp * lp); tw_lp * lp);
static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count); static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count);
static void cn_enter_barrier_rc(tw_lp *lp);
static void client_init( static void client_init(
client_state * ns, client_state * ns,
...@@ -206,8 +208,22 @@ static void handle_client_op_loop_rev_event( ...@@ -206,8 +208,22 @@ static void handle_client_op_loop_rev_event(
tw_lp * lp) tw_lp * lp)
/* TODO: fill this in */
assert(0); codes_workload_get_next_rc(ns->wkld_id, ns->my_rank, &m->op_rc);
switch(m->op_rc.op_type)
case CODES_WK_END:
break;
case CODES_WK_BARRIER:
cn_enter_barrier_rc(lp);
break;
case CODES_WK_OPEN:
svr_op_start_rc(lp);
break;
default:
assert(0);
return; return;
...@@ -256,7 +272,6 @@ static void handle_client_op_loop_event( ...@@ -256,7 +272,6 @@ static void handle_client_op_loop_event(
struct codes_workload_op op;
tw_lpid dest_svr_id; tw_lpid dest_svr_id;
printf("handle_client_op_loop_event(), lp %llu.\n", (unsigned long long)lp->gid); printf("handle_client_op_loop_event(), lp %llu.\n", (unsigned long long)lp->gid);
...@@ -268,14 +283,18 @@ static void handle_client_op_loop_event( ...@@ -268,14 +283,18 @@ static void handle_client_op_loop_event(
assert(ns->wkld_id > -1); assert(ns->wkld_id > -1);
codes_workload_get_next(ns->wkld_id, ns->my_rank, &op); /* NOTE: we store the op retrieved from the workload generator in the
* inbound message for this function, so that we have it saved for
* reverse computation if needed.
codes_workload_get_next(ns->wkld_id, ns->my_rank, &m->op_rc);
/* NOTE: in this test model the LP is doing its own math to find the LP /* NOTE: in this test model the LP is doing its own math to find the LP
* ID of servers just to do something simple. It knows that compute * ID of servers just to do something simple. It knows that compute
* nodes are the first N LPs and servers are the next M LPs. * nodes are the first N LPs and servers are the next M LPs.
switch(op.op_type) switch(m->op_rc.op_type)
case CODES_WK_END: case CODES_WK_END:
printf("Client rank %d completed workload.\n", ns->my_rank); printf("Client rank %d completed workload.\n", ns->my_rank);
...@@ -284,7 +303,7 @@ static void handle_client_op_loop_event( ...@@ -284,7 +303,7 @@ static void handle_client_op_loop_event(
break; break;
case CODES_WK_BARRIER: case CODES_WK_BARRIER:
printf("Client rank %d hit barrier.\n", ns->my_rank); printf("Client rank %d hit barrier.\n", ns->my_rank);
cn_enter_barrier(lp, op.u.barrier.root, op.u.barrier.count); cn_enter_barrier(lp, m->op_rc.u.barrier.root, m->op_rc.u.barrier.count);
return; return;
break; break;
/* "normal" io operations: we just calculate the destination and /* "normal" io operations: we just calculate the destination and
...@@ -293,18 +312,24 @@ static void handle_client_op_loop_event( ...@@ -293,18 +312,24 @@ static void handle_client_op_loop_event(
case CODES_WK_OPEN: case CODES_WK_OPEN:
printf("Client rank %d will issue an open request.\n", ns->my_rank); printf("Client rank %d will issue an open request.\n", ns->my_rank);
dest_svr_id = g_num_clients + op.u.open.file_id % g_num_servers; dest_svr_id = g_num_clients + m->op_rc.u.open.file_id % g_num_servers;
break; break;
default: default:
assert(0); assert(0);
break; break;
svr_op_start(lp, dest_svr_id, &op); svr_op_start(lp, dest_svr_id, &m->op_rc);
return; return;
codes_local_latency_reverse(lp);
return;
static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count) static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count)
tw_event *e; tw_event *e;
...@@ -186,7 +186,7 @@ static void handle_svr_op_event_rc( ...@@ -186,7 +186,7 @@ static void handle_svr_op_event_rc(
svr_msg * m, svr_msg * m,
assert(0); cn_op_complete_rc(lp);
return; return;
Markdown is supported
0% or .
Please register or to comment
