Commit 6e4081e6 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Add new routing configurations for min/nonmin choices
parent 73f126d5
...@@ -194,6 +194,10 @@ struct dragonfly_plus_param ...@@ -194,6 +194,10 @@ struct dragonfly_plus_param
int num_router_leaf; // number of leaf routers (bottom level) int num_router_leaf; // number of leaf routers (bottom level)
int adaptive_threshold; // predefined queue length threshold T before a packet is routed through a lower priority queue int adaptive_threshold; // predefined queue length threshold T before a packet is routed through a lower priority queue
bool source_leaf_consider_nonmin;
bool int_spine_consider_min;
bool dest_spine_consider_nonmin;
int max_hops_notify; //maximum number of hops allowed before notifying via printout int max_hops_notify; //maximum number of hops allowed before notifying via printout
long max_port_score; // maximum score that can be given to any port during route scoring long max_port_score; // maximum score that can be given to any port during route scoring
...@@ -604,35 +608,38 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p) ...@@ -604,35 +608,38 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p)
MPI_Comm_rank(MPI_COMM_CODES, &myRank); MPI_Comm_rank(MPI_COMM_CODES, &myRank);
if (!myRank) { if (!myRank) {
printf("\n------------------ Dragonfly Plus Parameters ---------\n"); printf("\n------------------ Dragonfly Plus Parameters ---------\n");
printf("\tnum_routers = %d\n",p->num_routers); printf("\tnum_routers = %d\n",p->num_routers);
printf("\tlocal_bandwidth = %.2f\n",p->local_bandwidth); printf("\tlocal_bandwidth = %.2f\n",p->local_bandwidth);
printf("\tglobal_bandwidth = %.2f\n",p->global_bandwidth); printf("\tglobal_bandwidth = %.2f\n",p->global_bandwidth);
printf("\tcn_bandwidth = %.2f\n",p->cn_bandwidth); printf("\tcn_bandwidth = %.2f\n",p->cn_bandwidth);
printf("\tnum_vcs = %d\n",p->num_vcs); printf("\tnum_vcs = %d\n",p->num_vcs);
printf("\tlocal_vc_size = %d\n",p->local_vc_size); printf("\tlocal_vc_size = %d\n",p->local_vc_size);
printf("\tglobal_vc_size = %d\n",p->global_vc_size); printf("\tglobal_vc_size = %d\n",p->global_vc_size);
printf("\tcn_vc_size = %d\n",p->cn_vc_size); printf("\tcn_vc_size = %d\n",p->cn_vc_size);
printf("\tchunk_size = %d\n",p->chunk_size); printf("\tchunk_size = %d\n",p->chunk_size);
printf("\tnum_cn = %d\n",p->num_cn); printf("\tnum_cn = %d\n",p->num_cn);
printf("\tintra_grp_radix = %d\n",p->intra_grp_radix); printf("\tintra_grp_radix = %d\n",p->intra_grp_radix);
printf("\tnum_level_chans = %d\n",p->num_level_chans); printf("\tnum_level_chans = %d\n",p->num_level_chans);
printf("\tnum_router_spine = %d\n",p->num_router_spine); printf("\tnum_router_spine = %d\n",p->num_router_spine);
printf("\tnum_router_leaf = %d\n",p->num_router_leaf); printf("\tnum_router_leaf = %d\n",p->num_router_leaf);
printf("\tadaptive_threshold = %d\n",p->adaptive_threshold); printf("\tmax_port_score = %ld\n",p->max_port_score);
printf("\tmax_port_score = %ld\n",p->max_port_score); printf("\tnum_groups = %d\n",p->num_groups);
printf("\tnum_groups = %d\n",p->num_groups); printf("\tradix = %d\n",p->radix);
printf("\tradix = %d\n",p->radix); printf("\ttotal_routers = %d\n",p->total_routers);
printf("\ttotal_routers = %d\n",p->total_routers); printf("\ttotal_terminals = %d\n",p->total_terminals);
printf("\ttotal_terminals = %d\n",p->total_terminals); printf("\tnum_global_connections = %d\n",p->num_global_connections);
printf("\tnum_global_connections = %d\n",p->num_global_connections); printf("\tcn_delay = %.2f\n",p->cn_delay);
printf("\tcn_delay = %.2f\n",p->cn_delay); printf("\tlocal_delay = %.2f\n",p->local_delay);
printf("\tlocal_delay = %.2f\n",p->local_delay); printf("\tglobal_delay = %.2f\n",p->global_delay);
printf("\tglobal_delay = %.2f\n",p->global_delay); printf("\tcredit_delay = %.2f\n",p->credit_delay);
printf("\tcredit_delay = %.2f\n",p->credit_delay); printf("\trouter_delay = %.2f\n",p->router_delay);
printf("\trouter_delay = %.2f\n",p->router_delay); printf("\tscoring = %d\n",scoring);
printf("\tscoring = %d\n",scoring); printf("\tadaptive_threshold = %d\n",p->adaptive_threshold);
printf("\trouting = %d\n",routing); printf("\trouting = %d\n",routing);
printf("\tmax hops notification = %d\n",p->max_hops_notify); printf("\tsource_leaf_consider_nonmin = %s\n", (p->source_leaf_consider_nonmin ? "true" : "false"));
printf("\tint_spine_consider_min = %s\n", (p->int_spine_consider_min ? "true" : "false"));
printf("\tdest_spine_consider_nonmin = %s\n", (p->dest_spine_consider_nonmin ? "true" : "false"));
printf("------------------------------------------------------\n\n"); printf("------------------------------------------------------\n\n");
...@@ -722,10 +729,47 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -722,10 +729,47 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
rc = configuration_get_value_int(&config, "PARAMS", "notification_on_hops_greater_than", anno, &p->max_hops_notify); rc = configuration_get_value_int(&config, "PARAMS", "notification_on_hops_greater_than", anno, &p->max_hops_notify);
if (rc) { if (rc) {
printf("Maximum hops for notifying not specified, setting to INT MAX"); printf("Maximum hops for notifying not specified, setting to INT MAX\n");
p->max_hops_notify = INT_MAX; p->max_hops_notify = INT_MAX;
int src_leaf_cons_choice;
rc = configuration_get_value_int(&config, "PARAMS", "source_leaf_consider_nonmin", anno, &src_leaf_cons_choice);
if (rc) {
printf("Source leaf consideration of nonmin ports not specified. Defaulting to True\n");
p->source_leaf_consider_nonmin = true;
else if (src_leaf_cons_choice == 1) {
else
p->source_leaf_consider_nonmin = false;
int int_spn_cons_choice;
rc = configuration_get_value_int(&config, "PARAMS", "int_spine_consider_min", anno, &int_spn_cons_choice);
if (rc) {
printf("Int spine consideration of min ports not specified. Defaulting to True\n");
p->int_spine_consider_min = true;
else if (int_spn_cons_choice == 1) {
else
p->int_spine_consider_min = false;
int dst_spn_cons_choice;
rc = configuration_get_value_int(&config, "PARAMS", "dest_spine_consider_nonmin", anno, &dst_spn_cons_choice);
if (rc) {
printf("Dest spine consideration of nonmin ports not specified. Defaulting to False");
p->dest_spine_consider_nonmin = false;
else if (dst_spn_cons_choice == 1) {
p->dest_spine_consider_nonmin = true;
else
/* MM: This should be 2 for dragonfly plus*/ /* MM: This should be 2 for dragonfly plus*/
p->num_vcs = 2; p->num_vcs = 2;
...@@ -2687,8 +2731,23 @@ static vector< Connection > get_legal_nonminimal_stops(router_state *s, tw_bf *b ...@@ -2687,8 +2731,23 @@ static vector< Connection > get_legal_nonminimal_stops(router_state *s, tw_bf *b
else if (my_group_id == fdest_group_id) { else if (my_group_id == fdest_group_id) {
assert(possible_nonminimal_stops.size() == 0); //empty because all legal stops within the destination group are minimal if (s->params->dest_spine_consider_nonmin == true) { //then its legal for the dest spine to route to dest leaves that aren't the final destination leaf
return possible_nonminimal_stops; if (s->dfp_router_type == SPINE) {
vector< Connection > conns_to_leaves = s->connMan->get_connections_by_type(CONN_LOCAL);
vector< Connection > retVec;
for (int i = 0; i < conns_to_leaves.size(); i++)
if (conns_to_leaves[i].dest_gid != fdest_router_id)
retVec.push_back(conns_to_leaves[i]);
return retVec;
else {
assert(s->dfp_router_type == LEAF);
assert(possible_nonminimal_stops.size() == 0); //empty because a leaf in the destination group has no legal nonminimal moves
else { else {
tw_error(TW_LOC, "Invalid group classification\n"); tw_error(TW_LOC, "Invalid group classification\n");
...@@ -2809,9 +2868,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -2809,9 +2868,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
else if (min_score <= intm_score) { else if (min_score <= intm_score) {
route_to_fdest = true; route_to_fdest = true;
else { //Changing to a nonminimal path!
msg->path_type = NON_MINIMAL;
else { //HIGHER is better else { //HIGHER is better
if (adaptive_threshold > 0) if (adaptive_threshold > 0)
...@@ -2819,8 +2875,34 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -2819,8 +2875,34 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
if (min_score >= intm_score) { if (min_score >= intm_score) {
else { //changing to a nonminimal path! }
msg->path_type = NON_MINIMAL; }
if (msg->dfp_upward_channel_flag == 0) { //if the flag is 1, then only minimal hops are considered
if (s->params->source_leaf_consider_nonmin == false) { //then we aren't supposed to let the source leaves consider any routes that wouldn't also be minimal
if (my_group_id == origin_group_id) {
if (s->dfp_router_type == LEAF)
route_to_fdest = true; //we aren't supposed to consider nonmin routes as the source leaf with given config
if (s->params->int_spine_consider_min == false) { //then we aren't supposed to let spines in intermediate group route to minimal even if possible
if (in_intermediate_group) {
route_to_fdest = false;
if (s->params->dest_spine_consider_nonmin == false) { //then the destination spines aren't allowed to route to leaves that aren't the destination leaf
else {
assert(s->params->dest_spine_consider_nonmin == true); //then destination spines are allowed to route to non fdest leaves, but only if the dfp upward channel flag hasn't been set
...@@ -2834,13 +2916,19 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -2834,13 +2916,19 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
if (route_to_fdest){ if (route_to_fdest){
if (in_intermediate_group == true) if (in_intermediate_group == true)
msg->dfp_upward_channel_flag = 1; //if we're in an intermediate group and take a turn toward the dest group, we flip the flag! msg->dfp_upward_channel_flag = 1; //if we're in an intermediate group and take a turn toward the dest group, we flip the flag!
if ( (my_group_id == fdest_group_id) && (s->dfp_router_type == LEAF) && (my_router_id != fdest_router_id) )
msg->dfp_upward_channel_flag = 1; //if we're a dest leaf but not the fdest leaf we must route using vl 1
nextStopConn = best_min_conn; nextStopConn = best_min_conn;
else { else {
nextStopConn = best_intm_conn; nextStopConn = best_intm_conn;
if (nextStopConn.port == -1)
tw_error(TW_LOC, "DFP Prog Adaptive Routing: No valid next hop was chosen\n");
return nextStopConn; return nextStopConn;
Markdown is supported
0% or .
Please register or to comment
