Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
6b825141
Commit
6b825141
authored
Dec 08, 2016
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Removing excessive qhash memory allocation from network models
parent
9f8cb764
Changes
8
Hide whitespace changes
Inline
Side-by-side
Showing
8 changed files
with
40 additions
and
28 deletions
+40
-28
src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-custom.conf
...conf/dragonfly-custom/modelnet-test-dragonfly-custom.conf
+2
-2
src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-edison.conf
...conf/dragonfly-custom/modelnet-test-dragonfly-edison.conf
+2
-2
src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-theta.conf
.../conf/dragonfly-custom/modelnet-test-dragonfly-theta.conf
+2
-2
src/networks/model-net/dragonfly-custom.C
+8
-6
src/networks/model-net/dragonfly.c
+8
-6
src/networks/model-net/fattree.c
+6
-4
src/networks/model-net/slimfly.c
+10
-6
tests/Makefile.subdir
+2
-0
No files found.
View file @
6b825141
@@ -49,9 +49,9 @@ PARAMS
# number of global channels per router
num_global_channels
"10"
num_global_channels
"10"
# network config file for intra-group connections
intra
group
connections
/Users/mmubarak/Documents/software_development/dragonfly-cray/codes-conflict/scripts/gen-cray-topo
/intra-custom"
intra
group
connections
../src/network-workloads/conf/dragonfly-custom
/intra-custom"
# network config file for inter-group connections
inter
group
connections
/inter-custom"
inter
group
connections
/inter-custom"
# routing protocol to be used
routing
"prog-adaptive"
routing
"prog-adaptive"
View file @
6b825141
@@ -48,9 +48,9 @@ PARAMS
num_global_channels
"10"
num_global_channels
"10"
intra
group
connections
/intra-edison"
intra
group
connections
/intra-edison"
inter
group
connections
/inter-edison"
inter
group
connections
/inter-edison"
routing
"minimal"
routing
"minimal"
View file @
6b825141
num_global_channels
"10"
num_global_channels
"10"
intra
group
connections
/Users/mmubarak/Documents/software_development/test_versions/codes/scripts/gen-cray-topo
/intra-theta"
intra
group
connections
/intra-theta"
inter
group
connections
/inter-theta"
inter
group
connections
/inter-theta"
routing
"adaptive"
routing
"adaptive"
View file @
6b825141
@@ -22,7 +22,7 @@
@@ -22,7 +22,7 @@
#define DUMP_CONNECTIONS 0
#define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE
262144
5000
// debugging parameters
#define TRACK -1
#define TRACK -1
@@ -834,11 +834,8 @@ terminal_custom_init( terminal_state * s,
s
vc_occupancy
i
0
s
vc_occupancy
i
0
s
rank_tbl
qhash_init
dragonfly_rank_hash_compare
dragonfly_hash_func
if
s
rank_tbl
tw_error
TW_LOC
\n
Hash table not initialized! "
s
rank_tbl
NULL
s
terminal_msgs
s
terminal_msgs
terminal_custom_message_list
malloc
s
num_vcs
sizeof
malloc
s
num_vcs
sizeof
s
terminal_msgs_tail
s
terminal_msgs_tail
@@ -1479,6 +1476,9 @@ static void packet_arrive(terminal_state * s, tw_bf * bf, terminal_custom_messag
// NIC aggregation - should this be a separate function?
// Trigger an event on receiving server
if
s
rank_tbl
s
rank_tbl
qhash_init
dragonfly_hash_func
struct
dfly_hash_key
key
struct
dfly_hash_key
key
key
message_id
msg
message_id
key
message_id
msg
message_id
key
sender_id
msg
sender_lp
key
sender_id
msg
sender_lp
@@ -2026,8 +2026,10 @@ dragonfly_custom_terminal_final( terminal_state * s,
//if(s->packet_gen != s->packet_fin)
// printf("\n generated %d finished %d ", s->packet_gen, s->packet_fin);
if
s
rank_tbl
qhash_finalize
s
rank_tbl
qhash_finalize
s
rank_tbl
rc_stack_destroy
s
st
rc_stack_destroy
s
st
free
s
vc_occupancy
free
s
vc_occupancy
free
s
terminal_msgs
free
s
terminal_msgs
View file @
6b825141
@@ -33,7 +33,7 @@
@@ -33,7 +33,7 @@
#define COLLECTIVE_COMPUTATION_DELAY 5700
#define DRAGONFLY_FAN_OUT_DELAY 20.0
#define WINDOW_LENGTH 0
262144
5000
#define TRACK -1
#define TRACK -1
@@ -757,11 +757,8 @@ terminal_init( terminal_state * s,
s
vc_occupancy
i
0
s
vc_occupancy
i
0
s
rank_tbl
qhash_init
dragonfly_hash_func
if
s
rank_tbl
tw_error
TW_LOC
\n
s
rank_tbl
NULL
s
terminal_msgs
s
terminal_msgs
terminal_message_list
malloc
1
sizeof
malloc
1
sizeof
s
terminal_msgs_tail
s
terminal_msgs_tail
@@ -1491,6 +1488,9 @@ static void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg
if
s
rank_tbl
s
rank_tbl
qhash_init
dragonfly_hash_func
struct
dfly_hash_key
key
struct
dfly_hash_key
key
key
message_id
msg
message_id
key
message_id
msg
message_id
key
sender_id
msg
sender_lp
key
sender_id
msg
sender_lp
@@ -2363,8 +2363,10 @@ dragonfly_terminal_final( terminal_state * s,
if
s
rank_tbl
qhash_finalize
s
rank_tbl
qhash_finalize
s
rank_tbl
rc_stack_destroy
s
st
rc_stack_destroy
s
st
free
s
vc_occupancy
free
s
vc_occupancy
free
s
terminal_msgs
free
s
terminal_msgs
View file @
6b825141
@@ -17,7 +17,7 @@
@@ -17,7 +17,7 @@
#define MEAN_PROCESS 1.0
#define TERMINAL_GUID_PREFIX ((uint64_t)(64) << 32)
#define FTREE_HASH_TABLE_SIZE
262144
5000
#define TRACK_PKT -1
@@ -965,9 +965,9 @@ void ft_terminal_init( ft_terminal_state * s, tw_lp * lp )
s
in_send_loop
0
s
in_send_loop
0
s
issueIdle
0
s
issueIdle
0
s
rank_tbl
qhash_init
fattree_rank_hash_compare
fattree_hash_func
s
rank_tbl
NULL
if
s
rank_tbl
if(!s->rank_tbl)
tw_error
TW_LOC
\n
tw_error(TW_LOC, "\n Hash table not initialized! ");
s
params
num_terminals
codes_mapping_get_lp_count
lp_group_name
0
s
params
num_terminals
lp_group_name
0
LP_CONFIG_NM
s
anno
0
LP_CONFIG_NM
s
anno
0
@@ -2381,6 +2381,8 @@ void ft_packet_arrive_rc(ft_terminal_state * s, tw_bf * bf, fattree_message * ms
void
ft_packet_arrive
ft_terminal_state
s
tw_bf
bf
fattree_message
msg
void
ft_packet_arrive
ft_terminal_state
s
tw_bf
bf
fattree_message
msg
tw_lp
lp
tw_lp
lp
if
s
rank_tbl
s
rank_tbl
qhash_init
fattree_hash_func
//Establish msg hash keys
struct
ftree_hash_key
key
struct
ftree_hash_key
key
key
message_id
msg
message_id
key
message_id
msg
message_id
View file @
6b825141
@@ -25,7 +25,7 @@
@@ -25,7 +25,7 @@
/* collective specific parameters */
65536
5000
#define TRACK 4
#define TRACK 4
@@ -840,10 +840,9 @@ void slim_terminal_init( terminal_state * s,
s
vc_occupancy
i
0
s
vc_occupancy
i
0
s
rank_tbl
qhash_init
slimfly_rank_hash_compare
slimfly_hash_func
s
rank_tbl
NULL
// if(!s->rank_tbl)
if
s
rank_tbl
// tw_error(TW_LOC, "\n Hash table not initialized! ");
tw_error
TW_LOC
\n
s
terminal_msgs
s
terminal_msgs
slim_terminal_message_list
malloc
1
sizeof
malloc
1
sizeof
@@ -1664,6 +1663,9 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message *
if
s
rank_tbl
s
rank_tbl
qhash_init
slimfly_hash_func
tw_stime
ts
g_tw_lookahead
s
params
credit_delay
tw_rand_unif
lp
rng
tw_stime
ts
g_tw_lookahead
s
params
credit_delay
tw_rand_unif
lp
rng
if
msg
packet_ID
TRACK
if
msg
packet_ID
TRACK
@@ -1996,7 +1998,9 @@ void slimfly_terminal_final( terminal_state * s,
if
s
terminal_msgs
0
NULL
if
s
terminal_msgs
0
NULL
// printf("[%lu] leftover terminal messages \n", lp->gid);
qhash_finalize
s
rank_tbl
if
s
rank_tbl
qhash_finalize
s
rank_tbl
rc_stack_destroy
s
st
rc_stack_destroy
s
st
free
s
vc_occupancy
free
s
vc_occupancy
free
s
terminal_msgs
free
s
terminal_msgs
View file @
6b825141
@@ -12,6 +12,7 @@ check_PROGRAMS += tests/lp-io-test \
src/network-workloads/model-net-synthetic
src/network-workloads/model-net-synthetic-fattree
src/network-workloads/model-net-synthetic-slimfly
src/network-workloads/model-net-synthetic-custom-dfly
tests/concurrent-msg-recv tests/modelnet-simplep2p-test
tests/modelnet-test-collective
tests/modelnet-prio-sched-test
@@ -31,6 +32,7 @@ TESTS += tests/lp-io-test.sh \
tests/modelnet-test-dragonfly.sh
tests/modelnet-test-slimfly.sh
tests/modelnet-test-dragonfly-synthetic.sh
tests/modelnet-test-dragonfly-custom-synthetic.sh
tests/modelnet-test-fattree-synthetic.sh
tests/modelnet-test-slimfly-synthetic.sh
tests/modelnet-p2p-bw-loggp.sh
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
