Commit 6b307c92 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Merge branch 'master' into 'dfp-online-workloads'
Updating dfp-online-workloads with codes/codes origin/master
See merge request neil/codes!13
parents 4bf55ecf df4a02be
...@@ -631,6 +631,8 @@ const tw_lptype* model_net_get_lp_type(int net_id) ...@@ -631,6 +631,8 @@ const tw_lptype* model_net_get_lp_type(int net_id)
const st_model_types* model_net_get_model_stat_type(int net_id) const st_model_types* model_net_get_model_stat_type(int net_id)
if (!method_array[net_id]->mn_get_model_stat_types)
tw_error(TW_LOC, "mn_get_model_stat_types not defined for network model with net_id: %d\n", net_id);
return method_array[net_id]->mn_get_model_stat_types(); return method_array[net_id]->mn_get_model_stat_types();
...@@ -726,8 +726,6 @@ static void packet_generate(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * m ...@@ -726,8 +726,6 @@ static void packet_generate(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * m
} else { } else {
bf->c11 = 1; bf->c11 = 1;
s->issueIdle = 1; s->issueIdle = 1;
msg->saved_busy_time = s->last_buf_full;
s->last_buf_full = tw_now(lp);
if(s->in_send_loop == 0) { if(s->in_send_loop == 0) {
...@@ -777,7 +775,6 @@ static void packet_generate_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT ...@@ -777,7 +775,6 @@ static void packet_generate_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT
if(bf->c11) { if(bf->c11) {
s->issueIdle = 0; s->issueIdle = 0;
s->last_buf_full = msg->saved_busy_time;
if(bf->c5) { if(bf->c5) {
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
...@@ -801,24 +798,42 @@ static void packet_send(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * msg, ...@@ -801,24 +798,42 @@ static void packet_send(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * msg,
tw_lpid router_id; tw_lpid router_id;
std::vector<VC_Entry> entries; std::vector<VC_Entry> entries;
bool noEmptyVC = false;
for(int i = 0; i < s->params->num_vcs; i++) { for(int i = 0; i < s->params->num_vcs; i++) {
if(s->terminal_msgs[0][i] != NULL && if(s->terminal_msgs[0][i] != NULL) {
s->vc_occupancy[0][i] + s->params->chunk_size <= s->params->cn_vc_size) { if(s->vc_occupancy[0][i] + s->params->chunk_size <= s->params->cn_vc_size) {
VC_Entry tmp; VC_Entry tmp;
tmp.vc = i; tmp.entry = s->terminal_msgs[0][i]; tmp.vc = i; tmp.entry = s->terminal_msgs[0][i];
entries.push_back(tmp); entries.push_back(tmp);
} else {
noEmptyVC = true;
if(entries.size() == 0) { if(entries.size() == 0) {
bf->c1 = 1; bf->c1 = 1;
s->in_send_loop = 0; s->in_send_loop = 0;
if(noEmptyVC && !s->last_buf_full) {
msg->saved_busy_time = s->last_buf_full; bf->c3 = 1;
s->last_buf_full = tw_now(lp); msg->saved_busy_time = s->last_buf_full;
return; return;
if(s->last_buf_full > 0.0)
bf->c4 = 1;
msg->saved_total_time = s->busy_time;
msg->saved_sample_time = s->busy_time_sample;
s->busy_time += (tw_now(lp) - s->last_buf_full);
s->busy_time_sample += (tw_now(lp) - s->last_buf_full);
s->last_buf_full = 0.0;
//CHANGE: randomly pick the VC to send on (by default only VC 0 is filed); can be changed. //CHANGE: randomly pick the VC to send on (by default only VC 0 is filed); can be changed.
int pick = tw_rand_integer(lp->rng, 0, entries.size() - 1); int pick = tw_rand_integer(lp->rng, 0, entries.size() - 1);
...@@ -894,18 +909,6 @@ static void packet_send(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * msg, ...@@ -894,18 +909,6 @@ static void packet_send(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * msg,
ts += tw_rand_unif(lp->rng); ts += tw_rand_unif(lp->rng);
model_net_method_idle_event(ts, 0, lp); model_net_method_idle_event(ts, 0, lp);
bf->c6 = 1;
return; return;
...@@ -915,9 +918,18 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * ms ...@@ -915,9 +918,18 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * ms
if(bf->c1) { if(bf->c1) {
s->in_send_loop = 1; s->in_send_loop = 1;
s->last_buf_full = msg->saved_busy_time; if(bf->c3) {
return; return;
if(bf->c4)
s->busy_time = msg->saved_total_time;
s->busy_time_sample = msg->saved_sample_time;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
...@@ -942,12 +954,6 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * ms ...@@ -942,12 +954,6 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * ms
if(bf->c6)
return; return;
...@@ -1466,8 +1472,6 @@ router_packet_receive( router_state * s, ...@@ -1466,8 +1472,6 @@ router_packet_receive( router_state * s,
append_to_message_list(s->queued_msgs[next_port], append_to_message_list(s->queued_msgs[next_port],
s->queued_msgs_tail[next_port], next_vc, cur_chunk); s->queued_msgs_tail[next_port], next_vc, cur_chunk);
s->queued_count[next_port] += s->params->chunk_size; s->queued_count[next_port] += s->params->chunk_size;
msg->saved_busy_time = s->last_buf_full[next_port];
s->last_buf_full[next_port] = tw_now(lp);
msg->saved_vc = next_port; msg->saved_vc = next_port;
...@@ -1500,7 +1504,6 @@ static void router_packet_receive_rc(router_state * s, ...@@ -1500,7 +1504,6 @@ static void router_packet_receive_rc(router_state * s,
message_list *tail = return_tail(s->queued_msgs[next_port], message_list *tail = return_tail(s->queued_msgs[next_port],
s->queued_msgs_tail[next_port], next_vc); s->queued_msgs_tail[next_port], next_vc);
s->queued_count[next_port] -= s->params->chunk_size; s->queued_count[next_port] -= s->params->chunk_size;
s->last_buf_full[next_port] = msg->saved_busy_time;
delete_message_list(tail); delete_message_list(tail);
...@@ -1529,8 +1532,24 @@ router_packet_send( router_state * s, ...@@ -1529,8 +1532,24 @@ router_packet_send( router_state * s,
s->in_send_loop[output_port] = 0; s->in_send_loop[output_port] = 0;
if(!s->queued_count[output_port] && !s->last_buf_full[output_port]) {
bf->c2 = 1;
msg->saved_busy_time = s->last_buf_full[output_port];
s->last_buf_full[output_port] = tw_now(lp);
return; return;
if(s->last_buf_full[output_port])
bf->c3 = 1;
msg->saved_rcv_time = s->busy_time[output_port];
msg->saved_sample_time = s->busy_time_sample[output_port];
s->busy_time[output_port] += (tw_now(lp) - s->last_buf_full[output_port]);
s->busy_time_sample[output_port] += (tw_now(lp) - s->last_buf_full[output_port]);
s->last_buf_full[output_port] = 0.0;
//CHANGE: no priorities among VCs; can be changed. //CHANGE: no priorities among VCs; can be changed.
...@@ -1642,8 +1661,18 @@ static void router_packet_send_rc(router_state * s, ...@@ -1642,8 +1661,18 @@ static void router_packet_send_rc(router_state * s,
s->in_send_loop[output_port] = 1; s->in_send_loop[output_port] = 1;
if(bf->c2) {
s->last_buf_full[output_port] = msg->saved_busy_time;
return; return;
if(bf->c3)
s->busy_time[output_port] = msg->saved_rcv_time;
s->busy_time_sample[output_port] = msg->saved_sample_time;
...@@ -1677,17 +1706,6 @@ static void router_buf_update(router_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * m ...@@ -1677,17 +1706,6 @@ static void router_buf_update(router_state * s, tw_bf * bf, LOCAL_MSG_STRUCT * m
int output_chan = msg->output_chan; int output_chan = msg->output_chan;
s->vc_occupancy[indx][output_chan] -= s->params->chunk_size; s->vc_occupancy[indx][output_chan] -= s->params->chunk_size;
if(s->last_buf_full[indx])
bf->c3 = 1;
msg->saved_rcv_time = s->busy_time[indx];
msg->saved_busy_time = s->last_buf_full[indx];
msg->saved_sample_time = s->busy_time_sample[indx];
s->busy_time[indx] += (tw_now(lp) - s->last_buf_full[indx]);
s->busy_time_sample[indx] += (tw_now(lp) - s->last_buf_full[indx]);
s->last_buf_full[indx] = 0.0;
int max_vc_size = s->params->vc_size; int max_vc_size = s->params->vc_size;
if(indx < s->params->num_cn) { if(indx < s->params->num_cn) {
max_vc_size = s->params->cn_vc_size; max_vc_size = s->params->cn_vc_size;
...@@ -1729,12 +1747,6 @@ static void router_buf_update_rc(router_state * s, ...@@ -1729,12 +1747,6 @@ static void router_buf_update_rc(router_state * s,
int indx = msg->vc_index; int indx = msg->vc_index;
s->vc_occupancy[indx][output_chan] += s->params->chunk_size; s->vc_occupancy[indx][output_chan] += s->params->chunk_size;
if(bf->c3)
s->busy_time[indx] = msg->saved_rcv_time;
s->busy_time_sample[indx] = msg->saved_sample_time;
s->last_buf_full[indx] = msg->saved_busy_time;
message_list* head = return_tail(s->pending_msgs[indx], message_list* head = return_tail(s->pending_msgs[indx],
s->pending_msgs_tail[indx], output_chan); s->pending_msgs_tail[indx], output_chan);
...@@ -249,6 +249,7 @@ void update_compute_time(const dumpi_time* time, rank_mpi_context* my_ctx) ...@@ -249,6 +249,7 @@ void update_compute_time(const dumpi_time* time, rank_mpi_context* my_ctx)
wrkld_per_rank.start_time = my_ctx->last_op_time; wrkld_per_rank.start_time = my_ctx->last_op_time;
wrkld_per_rank.end_time = start; wrkld_per_rank.end_time = start;
wrkld_per_rank.u.delay.seconds = (start - my_ctx->last_op_time) / 1e9; wrkld_per_rank.u.delay.seconds = (start - my_ctx->last_op_time) / 1e9;
wrkld_per_rank.u.delay.nsecs = (start - my_ctx->last_op_time);
dumpi_insert_next_op(my_ctx->dumpi_mpi_array, &wrkld_per_rank); dumpi_insert_next_op(my_ctx->dumpi_mpi_array, &wrkld_per_rank);
my_ctx->last_op_time = stop; my_ctx->last_op_time = stop;
Markdown is supported
0% or .
Please register or to comment
