Commit 698e934f authored by Shane Snyder's avatar Shane Snyder
Browse files
Add quick debug support for resolving timing issue
parent bf6dc626
...@@ -33,6 +33,7 @@ struct bgp_params ...@@ -33,6 +33,7 @@ struct bgp_params
struct darshan_params struct darshan_params
FILE* stream;
char log_file_path[MAX_NAME_LENGTH_WKLD]; char log_file_path[MAX_NAME_LENGTH_WKLD];
int64_t aggregator_cnt; int64_t aggregator_cnt;
...@@ -41,6 +41,14 @@ struct rank_io_context ...@@ -41,6 +41,14 @@ struct rank_io_context
struct qhash_head hash_link; struct qhash_head hash_link;
struct darshan_io_dat_array
struct darshan_io_op *op_array;
int64_t op_arr_ndx;
int64_t op_arr_cnt;
/* Darshan workload generator's implementation of the CODES workload API */ /* Darshan workload generator's implementation of the CODES workload API */
static int darshan_io_workload_load(const char *params, int rank); static int darshan_io_workload_load(const char *params, int rank);
static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op); static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op);
...@@ -62,9 +70,10 @@ static void generate_psx_coll_file_events(struct darshan_file *file, ...@@ -62,9 +70,10 @@ static void generate_psx_coll_file_events(struct darshan_file *file,
int64_t nprocs, int64_t aggregator_cnt); int64_t nprocs, int64_t aggregator_cnt);
static double generate_psx_open_event(struct darshan_file *file, int create_flag, static double generate_psx_open_event(struct darshan_file *file, int create_flag,
double meta_op_time, double cur_time, double meta_op_time, double cur_time,
struct rank_io_context *io_context); struct rank_io_context *io_context, int insert_flag);
static double generate_psx_close_event(struct darshan_file *file, double meta_op_time, static double generate_psx_close_event(struct darshan_file *file, double meta_op_time,
double cur_time, struct rank_io_context *io_context); double cur_time, struct rank_io_context *io_context,
int insert_flag);
static double generate_barrier_event(struct darshan_file *file, int64_t root, double cur_time, static double generate_barrier_event(struct darshan_file *file, int64_t root, double cur_time,
struct rank_io_context *io_context); struct rank_io_context *io_context);
static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_ops_this_cycle, static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_ops_this_cycle,
...@@ -78,10 +87,16 @@ static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind ...@@ -78,10 +87,16 @@ static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind
static void determine_io_params(struct darshan_file *file, int write_flag, int coll_flag, static void determine_io_params(struct darshan_file *file, int write_flag, int coll_flag,
int64_t io_cycles, size_t *io_sz, off_t *io_off); int64_t io_cycles, size_t *io_sz, off_t *io_off);
static void calc_io_delays(struct darshan_file *file, int64_t num_opens, int64_t num_io_ops, static void calc_io_delays(struct darshan_file *file, int64_t num_opens, int64_t num_io_ops,
double delay_per_cycle, double *first_io_delay, double *close_delay, double total_delay, double *first_io_delay, double *close_delay,
double *inter_open_delay, double *inter_io_delay); double *inter_open_delay, double *inter_io_delay);
static void file_sanity_check(struct darshan_file *file, struct darshan_job *job); static void file_sanity_check(struct darshan_file *file, struct darshan_job *job);
void print_events(struct darshan_io_op *event_list,
int64_t event_list_cnt,
int rank,
FILE *log_stream);
/* workload method name and function pointers for the CODES workload API */ /* workload method name and function pointers for the CODES workload API */
struct codes_workload_method darshan_io_workload_method = struct codes_workload_method darshan_io_workload_method =
...@@ -152,6 +167,8 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -152,6 +167,8 @@ static int darshan_io_workload_load(const char *params, int rank)
/* generate collective i/o events and store them in the rank context */ /* generate collective i/o events and store them in the rank context */
generate_psx_coll_file_events(&next_file, my_ctx, job.nprocs, d_params->aggregator_cnt); generate_psx_coll_file_events(&next_file, my_ctx, job.nprocs, d_params->aggregator_cnt);
else
continue;
assert(next_file.counters[CP_POSIX_OPENS] == 0); assert(next_file.counters[CP_POSIX_OPENS] == 0);
assert(next_file.counters[CP_POSIX_READS] == 0); assert(next_file.counters[CP_POSIX_READS] == 0);
...@@ -177,6 +194,9 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -177,6 +194,9 @@ static int darshan_io_workload_load(const char *params, int rank)
qhash_add(rank_tbl, &(my_ctx->my_rank), &(my_ctx->hash_link)); qhash_add(rank_tbl, &(my_ctx->my_rank), &(my_ctx->hash_link));
rank_tbl_pop++; rank_tbl_pop++;
struct darshan_io_dat_array *arr = (struct darshan_io_dat_array *)my_ctx->io_op_dat;
print_events(arr->op_array, arr->op_arr_cnt, rank, d_params->stream);
return 0; return 0;
...@@ -249,6 +269,7 @@ static int darshan_rank_hash_compare( ...@@ -249,6 +269,7 @@ static int darshan_rank_hash_compare(
#define DARSHAN_IO_OP_INC_CNT 100000 #define DARSHAN_IO_OP_INC_CNT 100000
#if 0
/* dynamically allocated array data structure for storing darshan i/o events */ /* dynamically allocated array data structure for storing darshan i/o events */
struct darshan_io_dat_array struct darshan_io_dat_array
...@@ -256,6 +277,7 @@ struct darshan_io_dat_array ...@@ -256,6 +277,7 @@ struct darshan_io_dat_array
int64_t op_arr_ndx; int64_t op_arr_ndx;
int64_t op_arr_cnt; int64_t op_arr_cnt;
#endif
/* initialize the dynamic array data structure */ /* initialize the dynamic array data structure */
static void *darshan_init_io_op_dat() static void *darshan_init_io_op_dat()
...@@ -376,7 +398,7 @@ static void generate_psx_ind_file_events( ...@@ -376,7 +398,7 @@ static void generate_psx_ind_file_events(
int64_t io_ops_this_cycle; int64_t io_ops_this_cycle;
double cur_time = file->fcounters[CP_F_OPEN_TIMESTAMP]; double cur_time = file->fcounters[CP_F_OPEN_TIMESTAMP];
double delay_per_open; double total_delay;
double first_io_delay = 0.0; double first_io_delay = 0.0;
double close_delay = 0.0; double close_delay = 0.0;
double inter_open_delay = 0.0; double inter_open_delay = 0.0;
...@@ -390,15 +412,14 @@ static void generate_psx_ind_file_events( ...@@ -390,15 +412,14 @@ static void generate_psx_ind_file_events(
return; return;
/* determine delay available per open-io-close cycle */ /* determine delay available per open-io-close cycle */
delay_per_open = (file->fcounters[CP_F_CLOSE_TIMESTAMP] - file->fcounters[CP_F_OPEN_TIMESTAMP] - total_delay = file->fcounters[CP_F_CLOSE_TIMESTAMP] - file->fcounters[CP_F_OPEN_TIMESTAMP] -
file->fcounters[CP_F_POSIX_READ_TIME] - file->fcounters[CP_F_POSIX_WRITE_TIME] - file->fcounters[CP_F_POSIX_READ_TIME] - file->fcounters[CP_F_POSIX_WRITE_TIME] -
file->fcounters[CP_F_POSIX_META_TIME]) / file->counters[CP_POSIX_OPENS]; file->fcounters[CP_F_POSIX_META_TIME];
/* calculate synthetic delay values */ /* calculate synthetic delay values */
calc_io_delays(file, file->counters[CP_POSIX_OPENS], calc_io_delays(file, file->counters[CP_POSIX_OPENS],
file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES], file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES], total_delay,
delay_per_open, &first_io_delay, &close_delay, &first_io_delay, &close_delay, &inter_open_delay, &inter_io_delay);
/* calculate average meta op time (for i/o and opens/closes) */ /* calculate average meta op time (for i/o and opens/closes) */
/* TODO: this needs to be updated when we add in stat, seek, etc. */ /* TODO: this needs to be updated when we add in stat, seek, etc. */
...@@ -416,7 +437,8 @@ static void generate_psx_ind_file_events( ...@@ -416,7 +437,8 @@ static void generate_psx_ind_file_events(
for (i = 0; file->counters[CP_POSIX_OPENS]; i++, file->counters[CP_POSIX_OPENS]--) for (i = 0; file->counters[CP_POSIX_OPENS]; i++, file->counters[CP_POSIX_OPENS]--)
/* generate an open event */ /* generate an open event */
cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time, io_context); cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time,
io_context, 1);
create_flag = 0; create_flag = 0;
/* account for potential delay from first open to first io */ /* account for potential delay from first open to first io */
...@@ -434,7 +456,7 @@ static void generate_psx_ind_file_events( ...@@ -434,7 +456,7 @@ static void generate_psx_ind_file_events(
cur_time += close_delay; cur_time += close_delay;
/* generate a close for the open event at the start of the loop */ /* generate a close for the open event at the start of the loop */
cur_time = generate_psx_close_event(file, meta_op_time, cur_time, io_context); cur_time = generate_psx_close_event(file, meta_op_time, cur_time, io_context, 1);
/* account for potential interopen delay if more than one open */ /* account for potential interopen delay if more than one open */
if (file->counters[CP_POSIX_OPENS] > 1) if (file->counters[CP_POSIX_OPENS] > 1)
...@@ -466,7 +488,7 @@ void generate_psx_coll_file_events( ...@@ -466,7 +488,7 @@ void generate_psx_coll_file_events(
int64_t rank_cnt; int64_t rank_cnt;
int create_flag = 0; int create_flag = 0;
double delay_per_cycle; double total_delay;
double inter_cycle_delay = 0.0; double inter_cycle_delay = 0.0;
...@@ -483,6 +505,13 @@ void generate_psx_coll_file_events( ...@@ -483,6 +505,13 @@ void generate_psx_coll_file_events(
assert(file->counters[CP_POSIX_OPENS] >= nprocs); assert(file->counters[CP_POSIX_OPENS] >= nprocs);
total_delay = (file->fcounters[CP_F_CLOSE_TIMESTAMP] -
(file->fcounters[CP_F_POSIX_READ_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_WRITE_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_META_TIME] / nprocs));
if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS]) if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS])
extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] - extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] -
...@@ -490,13 +519,20 @@ void generate_psx_coll_file_events( ...@@ -490,13 +519,20 @@ void generate_psx_coll_file_events(
total_coll_opens = file->counters[CP_COLL_OPENS]; total_coll_opens = file->counters[CP_COLL_OPENS];
total_ind_opens = file->counters[CP_POSIX_OPENS] - total_coll_opens - extra_opens; total_ind_opens = file->counters[CP_POSIX_OPENS] - total_coll_opens - extra_opens;
if (total_coll_opens)
total_ind_io_ops = file->counters[CP_INDEP_READS] + file->counters[CP_INDEP_WRITES];
total_coll_io_ops = (file->counters[CP_COLL_READS] + file->counters[CP_COLL_WRITES]) / nprocs;
if (total_coll_opens && total_ind_opens)
open_cycles = total_coll_opens / nprocs;
else if (total_coll_opens)
open_cycles = total_coll_opens / nprocs; open_cycles = total_coll_opens / nprocs;
else else
open_cycles = ceil((double)total_ind_opens / nprocs); open_cycles = ceil((double)total_ind_opens / nprocs);
total_ind_io_ops = file->counters[CP_INDEP_READS] + file->counters[CP_INDEP_WRITES]; calc_io_delays(file, ceil(((double)(total_coll_opens + total_ind_opens)) / nprocs),
total_coll_io_ops = (file->counters[CP_COLL_READS] + file->counters[CP_COLL_WRITES]) / nprocs; total_coll_io_ops + ceil((double)total_ind_io_ops / nprocs), total_delay,
&first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay);
else else
...@@ -517,26 +553,20 @@ void generate_psx_coll_file_events( ...@@ -517,26 +553,20 @@ void generate_psx_coll_file_events(
total_coll_opens = 0; total_coll_opens = 0;
total_ind_opens = file->counters[CP_POSIX_OPENS] - extra_opens; total_ind_opens = file->counters[CP_POSIX_OPENS] - extra_opens;
total_ind_io_ops = total_io_ops - extra_io_ops; total_ind_io_ops = total_io_ops - extra_io_ops;
total_coll_io_ops = 0; total_coll_io_ops = 0;
calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay,
assert(extra_opens <= open_cycles); assert(extra_opens <= open_cycles);
/* determine delay information */
delay_per_cycle = (file->fcounters[CP_F_CLOSE_TIMESTAMP] -
(file->fcounters[CP_F_POSIX_META_TIME] / nprocs)) / open_cycles;
meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / ((2 * file->counters[CP_POSIX_OPENS]) + meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / ((2 * file->counters[CP_POSIX_OPENS]) +
file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES]); file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES]);
/* TODO calc delays */
/* it is rare to overwrite existing files, so set the create flag */ /* it is rare to overwrite existing files, so set the create flag */
if (file->counters[CP_BYTES_WRITTEN]) if (file->counters[CP_BYTES_WRITTEN])
...@@ -554,9 +584,8 @@ void generate_psx_coll_file_events( ...@@ -554,9 +584,8 @@ void generate_psx_coll_file_events(
if (extra_opens && !(i % (open_cycles / extra_opens))) if (extra_opens && !(i % (open_cycles / extra_opens)))
file->rank = 0; cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time,
io_context, (io_context->my_rank == 0));
if (!file->counters[CP_COLL_OPENS] && !file->counters[CP_INDEP_OPENS]) if (!file->counters[CP_COLL_OPENS] && !file->counters[CP_INDEP_OPENS])
...@@ -566,9 +595,8 @@ void generate_psx_coll_file_events( ...@@ -566,9 +595,8 @@ void generate_psx_coll_file_events(
extra_io_ops--; extra_io_ops--;
file->rank = -1;
file->counters[CP_POSIX_OPENS]--; file->counters[CP_POSIX_OPENS]--;
...@@ -579,21 +607,22 @@ void generate_psx_coll_file_events( ...@@ -579,21 +607,22 @@ void generate_psx_coll_file_events(
else else
rank_cnt = ind_opens_this_cycle; rank_cnt = ind_opens_this_cycle;
cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time,
cur_time, io_context); io_context, (io_context->my_rank < rank_cnt));
cur_time += first_io_delay; cur_time += first_io_delay;
ind_io_ops_this_cycle = ceil(((double)total_ind_io_ops / total_ind_opens) * rank_cnt); ind_io_ops_this_cycle = ceil(((double)total_ind_io_ops / total_ind_opens) * rank_cnt);
cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, 0, nprocs, cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, 0, nprocs,
rank_cnt, inter_io_delay, meta_op_time, nprocs, inter_io_delay, meta_op_time,
cur_time, io_context); cur_time, io_context);
total_ind_io_ops -= ind_io_ops_this_cycle; total_ind_io_ops -= ind_io_ops_this_cycle;
file->counters[CP_POSIX_OPENS] -= rank_cnt; file->counters[CP_POSIX_OPENS] -= rank_cnt;
ind_opens_this_cycle -= rank_cnt; ind_opens_this_cycle -= rank_cnt;
...@@ -610,7 +639,7 @@ void generate_psx_coll_file_events( ...@@ -610,7 +639,7 @@ void generate_psx_coll_file_events(
cur_time = generate_barrier_event(file, 0, cur_time, io_context); cur_time = generate_barrier_event(file, 0, cur_time, io_context);
cur_time, io_context); cur_time, io_context, 1);
...@@ -631,7 +660,7 @@ void generate_psx_coll_file_events( ...@@ -631,7 +660,7 @@ void generate_psx_coll_file_events(
file->counters[CP_POSIX_OPENS] -= nprocs; file->counters[CP_POSIX_OPENS] -= nprocs;
file->counters[CP_COLL_OPENS] -= nprocs; file->counters[CP_COLL_OPENS] -= nprocs;
...@@ -649,7 +678,7 @@ void generate_psx_coll_file_events( ...@@ -649,7 +678,7 @@ void generate_psx_coll_file_events(
/* fill in an open event structure and store it with the rank context */ /* fill in an open event structure and store it with the rank context */
static double generate_psx_open_event( static double generate_psx_open_event(
struct darshan_file *file, int create_flag, double meta_op_time, struct darshan_file *file, int create_flag, double meta_op_time,
double cur_time, struct rank_io_context *io_context) double cur_time, struct rank_io_context *io_context, int insert_flag)
struct darshan_io_op next_io_op = struct darshan_io_op next_io_op =
...@@ -664,7 +693,7 @@ static double generate_psx_open_event( ...@@ -664,7 +693,7 @@ static double generate_psx_open_event(
next_io_op.end_time = cur_time; next_io_op.end_time = cur_time;
/* store the open event (if this rank performed it) */ /* store the open event (if this rank performed it) */
if ((file->rank == io_context->my_rank) || (file->rank == -1)) if (insert_flag)
darshan_insert_next_io_op(io_context->io_op_dat, &next_io_op); darshan_insert_next_io_op(io_context->io_op_dat, &next_io_op);
return cur_time; return cur_time;
...@@ -673,7 +702,7 @@ static double generate_psx_open_event( ...@@ -673,7 +702,7 @@ static double generate_psx_open_event(
/* fill in a close event structure and store it with the rank context */ /* fill in a close event structure and store it with the rank context */
static double generate_psx_close_event( static double generate_psx_close_event(
struct darshan_file *file, double meta_op_time, double cur_time, struct darshan_file *file, double meta_op_time, double cur_time,
struct rank_io_context *io_context) struct rank_io_context *io_context, int insert_flag)
...@@ -687,7 +716,7 @@ static double generate_psx_close_event( ...@@ -687,7 +716,7 @@ static double generate_psx_close_event(
/* store the close event (if this rank performed it) */ /* store the close event (if this rank performed it) */
...@@ -709,7 +738,7 @@ static double generate_barrier_event( ...@@ -709,7 +738,7 @@ static double generate_barrier_event(
/* store the barrier event */ /* store the barrier event */
if ((file->rank == -1) || (file->rank == io_context->my_rank)) if (file->rank == -1)
...@@ -886,6 +915,28 @@ static double generate_psx_coll_io_events( ...@@ -886,6 +915,28 @@ static double generate_psx_coll_io_events(
rw = (file->fcounters[CP_F_READ_START_TIMESTAMP] < rw = (file->fcounters[CP_F_READ_START_TIMESTAMP] <
file->fcounters[CP_F_WRITE_START_TIMESTAMP]) ? 0 : 1; file->fcounters[CP_F_WRITE_START_TIMESTAMP]) ? 0 : 1;
/* determine how many io ops to do before next rw switch */
if (!rw)
if (file->counters[CP_COLL_OPENS])
io_ops_this_rw =
((file->counters[CP_COLL_READS] / nprocs) + file->counters[CP_INDEP_READS]) /
((file->counters[CP_RW_SWITCHES] / (2 * aggregator_cnt)) + 1);
else
io_ops_this_rw = file->counters[CP_POSIX_READS] /
else
io_ops_this_rw =
((file->counters[CP_COLL_WRITES] / nprocs) + file->counters[CP_INDEP_WRITES]) /
else
io_ops_this_rw = file->counters[CP_POSIX_WRITES] /
/* initialize the rd and wr bandwidth values using total io size and time */ /* initialize the rd and wr bandwidth values using total io size and time */
if (file->fcounters[CP_F_POSIX_READ_TIME]) if (file->fcounters[CP_F_POSIX_READ_TIME])
rd_bw = file->counters[CP_BYTES_READ] / file->fcounters[CP_F_POSIX_READ_TIME]; rd_bw = file->counters[CP_BYTES_READ] / file->fcounters[CP_F_POSIX_READ_TIME];
...@@ -893,28 +944,6 @@ static double generate_psx_coll_io_events( ...@@ -893,28 +944,6 @@ static double generate_psx_coll_io_events(
wr_bw = file->counters[CP_BYTES_WRITTEN] / file->fcounters[CP_F_POSIX_WRITE_TIME]; wr_bw = file->counters[CP_BYTES_WRITTEN] / file->fcounters[CP_F_POSIX_WRITE_TIME];
if (!rw)
io_ops_this_rw =
else
else
io_ops_this_rw =
else
if (coll_io_ops_this_cycle) if (coll_io_ops_this_cycle)
ind_ops_remaining = ceil((double)ind_io_ops_this_cycle / coll_io_ops_this_cycle); ind_ops_remaining = ceil((double)ind_io_ops_this_cycle / coll_io_ops_this_cycle);
else else
...@@ -953,7 +982,6 @@ static double generate_psx_coll_io_events( ...@@ -953,7 +982,6 @@ static double generate_psx_coll_io_events(
(file->counters[CP_COLL_WRITES] / nprocs)); (file->counters[CP_COLL_WRITES] / nprocs));
file->counters[CP_COLL_WRITES] -= nprocs; file->counters[CP_COLL_WRITES] -= nprocs;
assert(io_cnt <= io_ops_this_rw);
...@@ -1019,7 +1047,6 @@ static double generate_psx_coll_io_events( ...@@ -1019,7 +1047,6 @@ static double generate_psx_coll_io_events(
tmp_rank = 0; tmp_rank = 0;
cur_time = max_cur_time; cur_time = max_cur_time;
max_cur_time = 0.0;
io_ops_this_rw--; io_ops_this_rw--;
...@@ -1034,13 +1061,13 @@ static double generate_psx_coll_io_events( ...@@ -1034,13 +1061,13 @@ static double generate_psx_coll_io_events(
else else
if (tmp_rank == (nprocs - 1)) if (tmp_rank == (nprocs - 1) || (i == (total_io_ops_this_cycle - 1)))
if (i != (total_io_ops_this_cycle - 1)) if (i != (total_io_ops_this_cycle - 1))
cur_time += inter_io_delay; cur_time += inter_io_delay;
else }
/* determine whether to toggle between reads and writes */ /* determine whether to toggle between reads and writes */
...@@ -1318,7 +1345,7 @@ static void determine_io_params( ...@@ -1318,7 +1345,7 @@ static void determine_io_params(
/* calculate the simulated "delay" between different i/o events using delay info /* calculate the simulated "delay" between different i/o events using delay info
* from the file counters */ * from the file counters */
static void calc_io_delays( static void calc_io_delays(
struct darshan_file *file, int64_t num_opens, int64_t num_io_ops, double delay_per_cycle, struct darshan_file *file, int64_t num_opens, int64_t num_io_ops, double total_delay,
double *first_io_delay, double *close_delay, double *inter_open_delay, double *inter_io_delay) double *first_io_delay, double *close_delay, double *inter_open_delay, double *inter_io_delay)
double first_io_time, last_io_time; double first_io_time, last_io_time;
...@@ -1326,7 +1353,7 @@ static void calc_io_delays( ...@@ -1326,7 +1353,7 @@ static void calc_io_delays(
double total_delay_pct; double total_delay_pct;
double tmp_inter_io_pct, tmp_inter_open_pct; double tmp_inter_io_pct, tmp_inter_open_pct;
if (delay_per_cycle > 0.0) if (total_delay > 0.0)
