Commit 67e2834d authored by Philip Carns's avatar Philip Carns
Browse files
minor updates to README
parent 7871b28c
...@@ -20,13 +20,14 @@ machines. ...@@ -20,13 +20,14 @@ machines.
./prepare.sh ./prepare.sh
2- Configure codes-base. This can be done in the source directory or in a 2- Configure codes-base. This can be done in the source directory or in a
dedicated build directory if you prefer out-of-tree builds. dedicated build directory if you prefer out-of-tree builds. The CC
environment variable must refer to an MPI compiler.
./configure --with-ross=/path/to/ross/install ./configure --with-ross=/path/to/ross/install --prefix=/path/to/codes-base/install CC=mpicc
3 - Build codes-base 3 - Build codes-base
make clean && make make clean && make && make install
4 - codes-base uses flex and bison (or lex and yacc) to generate several parsers. 4 - codes-base uses flex and bison (or lex and yacc) to generate several parsers.
These tools auto-generate C source files. To remove all of the autogenerated These tools auto-generate C source files. To remove all of the autogenerated
Markdown is supported
0% or .
Please register or to comment
