Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
67d30ee0
Commit
67d30ee0
authored
Sep 17, 2013
by
Philip Carns
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
stub for example generator method
parent
11a81432
Changes
3
Show whitespace changes
Inline
Side-by-side
Showing
3 changed files
with
58 additions
and
4 deletions
+58
-4
src/Makefile.subdir
src/Makefile.subdir
+2
-1
src/workload/codes-workload-method.h
+6
-3
src/workload/test-workload-method.c
+50
-0
No files found.
src/Makefile.subdir
View file @
67d30ee0
@@ -101,4 +101,5 @@ src_libcodes_base_a_SOURCES = \
codes/timeline.h
codes/timeline.h
src/logging/timeline.c
src/workload/codes-workload.c
View file @
67d30ee0
@@ -15,9 +15,12 @@
@@ -15,9 +15,12 @@
#include "ross.h"
#include "ross.h"
#include "codes/codes-workload.h"
int
codes_workload_load
const
char
type
const
char
params
int
rank
struct
codes_workload_method
void
codes_workload_get_next
int
wkld_id
struct
codes_workload_op
op
char
method_name
/* name of the generator */
int
codes_workload_load
const
char
params
int
rank
void
int
wkld_id
struct
codes_workload_op
op
#endif
/* CODES_WORKLOAD_METHOD_H */
#endif
0 → 100644
View file @
67d30ee0
* Copyright (C) 2013 University of Chicago.
* See COPYRIGHT notice in top-level directory.
/* Example of a workload generator that plugs into the codes workload
* generator API. This example just produces a hard-coded pattern for
* testing/validation purposes.
#include "ross.h"
#include "codes-workload-method.h"
int
test_workload_load
const
char
params
int
rank
void
test_workload_get_next
int
wkld_id
struct
codes_workload_op
op
struct
test_workload_method
method_name
"test"
codes_workload_load
test_workload_load
int
test_workload_load
const
char
params
int
rank
/* just use the rank of the caller as the identifier */
/* no params in this case; this example will work with any number of
* ranks
return
rank
void
int
wkld_id
struct
codes_workload_op
op
/* TODO: fill in a more complex example... */
op
op_type
CODES_WK_END
return
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
