Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
64e2c33e
Commit
64e2c33e
authored
Mar 12, 2015
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
begone, unused bgp parameters
parent
436e5f8b
Changes
7
Hide whitespace changes
Inline
Side-by-side
Showing
7 changed files
with
17 additions
and
26 deletions
+17
-26
codes/codes-workload.h
+1
-1
src/iokernellang/CodesKernelHelpers.c
+14
-20
src/iokernellang/CodesKernelHelpers.h
+1
-1
src/workload/codes-workload-dump.c
+1
-1
src/workload/methods/codes-bgp-io-wrkld.c
+0
-1
tests/workload/codes-workload-mpi-replay.c
+0
-1
tests/workload/codes-workload-test.c
+0
-1
No files found.
View file @
64e2c33e
@@ -32,8 +32,8 @@ struct bgp_params
/* flag - use path to find kernel files relative to the metafile */
int
use_relpath
int
use_relpath
char
io_kernel_meta_path
MAX_NAME_LENGTH_WKLD
char
io_kernel_meta_path
/* set by config in the metadata path */
char
io_kernel_path
char
io_kernel_path
char
io_kernel_def_path
struct
darshan_params
struct
darshan_params
View file @
64e2c33e
@@ -110,8 +110,9 @@ static int convertKLInstToEvent(int inst)
return
CL_UNKNOWN
return
CL_UNKNOWN
static
void
codes_kernel_helper_parse_cf
char
io_kernel_path
char
static
void
char
io_kernel_path
io_kernel_def_path
char
io_kernel_meta_path
int
task_rank
int
max_ranks_default
codes_workload_info
task_info
int
use_relpath
char
io_kernel_meta_path
int
task_rank
int
max_ranks_default
codes_workload_info
task_info
int
use_relpath
int
foundit
0
int
foundit
0
char
line
CK_LINE_LIMIT
char
line
CK_LINE_LIMIT
@@ -193,18 +194,12 @@ static void codes_kernel_helper_parse_cf(char * io_kernel_path, char *
fclose
ikmp
fclose
ikmp
/* if we did not find the config file, set it to the default */
if
foundit
0
if
foundit
0
fprintf
stderr
/* default kernel */
"ERROR: Unable to find iolang workload file "
strcpy
io_kernel_path
io_kernel_def_path
"from given metadata file %s... exiting
\n
io_kernel_meta_path
/* default gid and task attrs */
exit
1
/* TODO can we detect the gaps instead of -1 */
task_info
group_id
CL_DEFAULT_GID
task_info
min_rank
1
task_info
max_rank
1
task_info
local_rank
1
task_info
num_lrank
1
return
return
@@ -301,11 +296,10 @@ int codes_kernel_helper_parse_input(CodesIOKernel_pstate * ps, CodesIOKernelCont
return
codes_inst
return
codes_inst
int
codes_kernel_helper_bootstrap
char
io_kernel_path
char
int
char
io_kernel_path
io_kernel_def_path
char
io_kernel_meta_path
char
io_kernel_meta_path
int
rank
int
num_ranks
int
use_relpath
int
rank
int
num_ranks
int
use_relpath
CodesIOKernelContext
c
c
ps
ps
codes_workload_info
task_info
codes_workload_info
task_info
codeslang_inst
next_event
codeslang_inst
next_event
int
t
CL_NOOP
int
t
CL_NOOP
int
ret
0
int
ret
0
@@ -316,7 +310,7 @@ int codes_kernel_helper_bootstrap(char * io_kernel_path, char *
temp_group_rank
rank
temp_group_rank
rank
/* get the kernel from the file */
io_kernel_path
io_kernel_def_path
io_kernel_path
io_kernel_meta_path
rank
num_ranks
task_info
use_relpath
io_kernel_meta_path
rank
num_ranks
task_info
use_relpath
temp_group_size
task_info
num_lrank
temp_group_size
task_info
num_lrank
/* stat the kernel file */
View file @
64e2c33e
@@ -61,7 +61,7 @@ typedef struct codeslang_inst
int
ps
int
ps
c
codeslang_inst
inst
c
codeslang_inst
inst
int
char
io_kernel_path
char
def_io_kernel_path
int
char
io_kernel_path
char
io_kernel_meta_path
int
rank
int
num_ranks
int
use_relpath
c
char
io_kernel_meta_path
int
rank
int
num_ranks
int
use_relpath
c
ps
codes_workload_info
task_info
ps
codes_workload_info
task_info
codeslang_inst
next_event
codeslang_inst
next_event
View file @
64e2c33e
@@ -12,7 +12,7 @@
@@ -12,7 +12,7 @@
static
char
type
128
'\0'
static
char
type
128
'\0'
static
darshan_params
d_params
0
static
darshan_params
d_params
0
static
bgp_params
b_params
0
0
static
bgp_params
b_params
0
0
static
recorder_params
r_params
0
static
recorder_params
r_params
0
static
int
n
1
static
int
n
1
View file @
64e2c33e
@@ -82,7 +82,6 @@ int bgp_io_workload_load(const char* params, int rank)
wrkld_per_rank
codes_pstate
CodesIOKernel_pstate_new
wrkld_per_rank
codes_pstate
wrkld_per_rank
rank
rank
wrkld_per_rank
rank
rank
t
b_param
io_kernel_path
t
b_param
io_kernel_path
b_param
io_kernel_def_path
b_param
io_kernel_meta_path
b_param
io_kernel_meta_path
rank
rank
num_ranks
num_ranks
View file @
64e2c33e
@@ -161,7 +161,6 @@ int load_workload(char *conf_path, int rank)
NULL
b_params
io_kernel_meta_path
NULL
b_params
io_kernel_meta_path
configuration_get_value
config
"PARAMS"
"rank_count"
NULL
rank_count
10
config
"PARAMS"
"rank_count"
NULL
rank_count
10
strcpy
b_params
io_kernel_path
strcpy
b_params
io_kernel_path
strcpy
b_params
io_kernel_def_path
b_params
num_cns
atoi
rank_count
b_params
num_cns
atoi
rank_count
b_params
use_relpath
1
b_params
use_relpath
1
View file @
64e2c33e
@@ -41,7 +41,6 @@ void workload_set_params()
if
strcmp
workload_type
"bgp_io_workload"
0
if
strcmp
workload_type
"bgp_io_workload"
0
strcpy
bgparams
io_kernel_path
strcpy
bgparams
io_kernel_path
strcpy
bgparams
io_kernel_def_path
bgparams
num_cns
NUM_CLIENTS
bgparams
num_cns
NUM_CLIENTS
config
"PARAMS"
"io_kernel_meta_path"
NULL
io_kernel_meta_path
config
"PARAMS"
NULL
io_kernel_meta_path
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
