Commit 62e1153b authored by Jonathan Jenkins's avatar Jonathan Jenkins
change map context to use canonical entity name ids
needed to be able to transfer mapping contexts between lps
parent 166c3ced
...@@ -37,13 +37,11 @@ enum codes_mctx_type { ...@@ -37,13 +37,11 @@ enum codes_mctx_type {
/* defines whether to specialize by destination annotation, and if so, which /* defines whether to specialize by destination annotation, and if so, which
* one. * one */
* NOTE: this structure does not "own" the annotation, and makes no attempt to
* clean it up. */
struct codes_mctx_annotation { struct codes_mctx_annotation {
char const * annotation; // see canonical name mapping api in codes_mapping.h. -1 is used for
bool ignore_annotations; // ignoring annotations
int cid;
/* parameters for each mapping context type */ /* parameters for each mapping context type */
...@@ -12,8 +12,7 @@ static struct codes_mctx const CODES_MCTX_DEFAULT_VAL = { ...@@ -12,8 +12,7 @@ static struct codes_mctx const CODES_MCTX_DEFAULT_VAL = {
.u = { .u = {
.group_modulo = { .group_modulo = {
.anno = { .anno = {
.annotation = NULL, .cid = -1,
.ignore_annotations = true
...@@ -34,8 +33,11 @@ struct codes_mctx codes_mctx_set_group_modulo( ...@@ -34,8 +33,11 @@ struct codes_mctx codes_mctx_set_group_modulo(
struct codes_mctx rtn; struct codes_mctx rtn;
rtn.type = CODES_MCTX_GROUP_MODULO; rtn.type = CODES_MCTX_GROUP_MODULO;
rtn.u.group_modulo.anno.annotation = annotation; if (ignore_annotations)
rtn.u.group_modulo.anno.ignore_annotations = ignore_annotations; rtn.u.group_modulo.anno.cid = -1;
else
codes_mapping_get_anno_cid_by_name(annotation);
return rtn; return rtn;
struct codes_mctx codes_mctx_set_group_direct( struct codes_mctx codes_mctx_set_group_direct(
...@@ -46,8 +48,11 @@ struct codes_mctx codes_mctx_set_group_direct( ...@@ -46,8 +48,11 @@ struct codes_mctx codes_mctx_set_group_direct(
rtn.type = CODES_MCTX_GROUP_DIRECT; rtn.type = CODES_MCTX_GROUP_DIRECT;
rtn.u.group_direct.offset = offset; rtn.u.group_direct.offset = offset;
rtn.u.group_direct.anno.annotation = annotation; if (ignore_annotations)
rtn.u.group_direct.anno.ignore_annotations = ignore_annotations; rtn.u.group_direct.anno.cid = -1;
else
...@@ -80,17 +85,23 @@ tw_lpid codes_mctx_to_lpid( ...@@ -80,17 +85,23 @@ tw_lpid codes_mctx_to_lpid(
codes_mapping_get_lp_info(sender_gid, sender_group, &unused, NULL, &unused, codes_mapping_get_lp_info(sender_gid, sender_group, &unused, NULL, &unused,
NULL, &rep_id, &offset); NULL, &rep_id, &offset);
char const * anno_str;
if (anno->cid < 0)
anno_str = NULL;
else
anno_str = codes_mapping_get_anno_name_by_cid(anno->cid);
int dest_offset; int dest_offset;
if (ctx->type == CODES_MCTX_GROUP_MODULO) { if (ctx->type == CODES_MCTX_GROUP_MODULO) {
int num_dest_lps = codes_mapping_get_lp_count(sender_group, 1, int num_dest_lps = codes_mapping_get_lp_count(sender_group, 1,
dest_lp_name, anno->annotation, anno->ignore_annotations); dest_lp_name, anno_str, anno->cid == -1);
if (num_dest_lps == 0) if (num_dest_lps == 0)
tw_error(TW_LOC, tw_error(TW_LOC,
"ERROR: Found no LPs of type %s in group %s " "ERROR: Found no LPs of type %s in group %s "
"(source lpid %lu) with annotation: %s\n", "(source lpid %lu) with annotation: %s\n",
dest_lp_name, sender_group, sender_gid, dest_lp_name, sender_group, sender_gid,
anno->ignore_annotations ? "ignored" : anno->cid == -1 ? "ignored" :
(anno->annotation ? anno->annotation : "none")); codes_mapping_get_anno_name_by_cid(anno->cid));
dest_offset = offset % num_dest_lps; dest_offset = offset % num_dest_lps;
...@@ -101,8 +112,8 @@ tw_lpid codes_mctx_to_lpid( ...@@ -101,8 +112,8 @@ tw_lpid codes_mctx_to_lpid(
assert(0); assert(0);
tw_lpid rtn; tw_lpid rtn;
codes_mapping_get_lp_id(sender_group, dest_lp_name, anno->annotation, codes_mapping_get_lp_id(sender_group, dest_lp_name, anno_str,
anno->ignore_annotations, rep_id, dest_offset, &rtn); anno->cid == -1, rep_id, dest_offset, &rtn);
...@@ -117,12 +128,14 @@ char const * codes_mctx_get_annotation( ...@@ -117,12 +128,14 @@ char const * codes_mctx_get_annotation(
case CODES_MCTX_GROUP_MODULO: case CODES_MCTX_GROUP_MODULO:
// if not ignoring the annotation, just return what's in the // if not ignoring the annotation, just return what's in the
// context // context
if (!ctx->u.group_modulo.anno.ignore_annotations) if (ctx->u.group_modulo.anno.cid >= 0)
return ctx->u.group_modulo.anno.annotation; return codes_mapping_get_anno_name_by_cid(
ctx->u.group_modulo.anno.cid);
break; break;
case CODES_MCTX_GROUP_DIRECT: case CODES_MCTX_GROUP_DIRECT:
if (!ctx->u.group_direct.anno.ignore_annotations) if (ctx->u.group_direct.anno.cid >= 0)
return ctx->u.group_direct.anno.annotation; return codes_mapping_get_anno_name_by_cid(
ctx->u.group_direct.anno.cid);
break; break;
default: default:
tw_error(TW_LOC, "unrecognized or uninitialized context type: %d", tw_error(TW_LOC, "unrecognized or uninitialized context type: %d",
Markdown is supported
0%
or
Please register or to comment
