Commit 62bd153b authored by Shane Snyder's avatar Shane Snyder
Browse files
Add optional profiling capability in replay tool
parent f5d74ad8
...@@ -24,7 +24,9 @@ ...@@ -24,7 +24,9 @@
#include "codes/quickhash.h" #include "codes/quickhash.h"
#include "codes/configuration.h" #include "codes/configuration.h"
#define WORKLOAD_DELAY_PCT 0.95 #define DEBUG_PROFILING 1
#define WORKLOAD_DELAY_PCT 1
/* hash table entry for looking up file descriptor of a workload file id */ /* hash table entry for looking up file descriptor of a workload file id */
struct file_info struct file_info
...@@ -48,6 +50,14 @@ static struct qhash_table *fd_table = NULL; ...@@ -48,6 +50,14 @@ static struct qhash_table *fd_table = NULL;
/* file stream to log rank events to, if verbose turned on */ /* file stream to log rank events to, if verbose turned on */
static FILE *log_stream = NULL; static FILE *log_stream = NULL;
/* global variables for profiling different portions of the replay, if enabled */
static double total_open_time = 0.0;
static double total_close_time = 0.0;
static double total_read_time = 0.0;
static double total_write_time = 0.0;
static double total_delay_time = 0.0;
static double total_barrier_time = 0.0;
void usage(char *exename) void usage(char *exename)
fprintf(stderr, "Usage: %s [OPTIONS] --conf <conf_file_path>\n " fprintf(stderr, "Usage: %s [OPTIONS] --conf <conf_file_path>\n "
...@@ -166,7 +176,7 @@ int load_workload(char *conf_path, int rank) ...@@ -166,7 +176,7 @@ int load_workload(char *conf_path, int rank)
else if (strcmp(workload_type, "recorder_io_workload") == 0) { else if (strcmp(workload_type, "recorder_io_workload") == 0) {
struct recorder_params r_params; struct recorder_params r_params;
/* get the darshan params from the config file */ /* get the recorder params from the config file */
configuration_get_value(&config, "PARAMS", "trace_dir_path", configuration_get_value(&config, "PARAMS", "trace_dir_path",
r_params.trace_dir_path, MAX_NAME_LENGTH_WKLD); r_params.trace_dir_path, MAX_NAME_LENGTH_WKLD);
...@@ -254,12 +264,17 @@ int main(int argc, char *argv[]) ...@@ -254,12 +264,17 @@ int main(int argc, char *argv[])
/* subtract the load time from any initial delay to be fair */ /* subtract the load time from any initial delay to be fair */
if (first_op && (next_op.op_type == CODES_WK_DELAY)) if (first_op && (next_op.op_type == CODES_WK_DELAY))
first_op = 0;
if (next_op.u.delay.seconds > (load_end - load_start)) if (next_op.u.delay.seconds > (load_end - load_start))
next_op.u.delay.seconds -= (load_end - load_start); next_op.u.delay.seconds -= (load_end - load_start);
else else
printf("Replay workload is %.4lf seconds behind original workload\n",
(double)(load_end - load_start));
continue; continue;
first_op = 0;
if (next_op.op_type != CODES_WK_END) if (next_op.op_type != CODES_WK_END)
...@@ -288,6 +303,12 @@ int main(int argc, char *argv[]) ...@@ -288,6 +303,12 @@ int main(int argc, char *argv[])
/* destroy and finalize the file descriptor hash table */ /* destroy and finalize the file descriptor hash table */
qhash_destroy_and_finalize(fd_table, struct file_info, hash_link, free); qhash_destroy_and_finalize(fd_table, struct file_info, hash_link, free);
#if DEBUG_PROFILING
printf("Rank %d:\td=%.4lf, b=%.4lf, o=%.4lf, c=%.4lf, r=%.4lf, w=%.4lf\n",
myrank, total_delay_time, total_barrier_time, total_open_time,
total_close_time, total_read_time, total_write_time);
#endif
error_exit: error_exit:
MPI_Finalize(); MPI_Finalize();
...@@ -305,6 +326,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -305,6 +326,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
struct qlist_head *hash_link = NULL; struct qlist_head *hash_link = NULL;
char *buf = NULL; char *buf = NULL;
int ret; int ret;
double start, end;
#if DEBUG_PROFILING
start = MPI_Wtime();
#endif
switch (replay_op.op_type) switch (replay_op.op_type)
...@@ -316,8 +342,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -316,8 +342,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
if (!opt_noop) if (!opt_noop)
/* satisfy delay using second delay then microsecond delay */ /* satisfy delay using second delay then microsecond delay */
secs = floor(replay_op.u.delay.seconds); secs = (unsigned int)replay_op.u.delay.seconds;
usecs = round((replay_op.u.delay.seconds - secs) * 1000 * 1000); usecs = (unsigned int)((replay_op.u.delay.seconds - secs) * 1000 * 1000);
ret = sleep(secs); ret = sleep(secs);
if (ret) if (ret)
...@@ -335,6 +361,10 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -335,6 +361,10 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
rank, op_number, strerror(errno)); rank, op_number, strerror(errno));
return -1; return -1;
#if DEBUG_PROFILING
end = MPI_Wtime();
total_delay_time += (end - start);
#endif
return 0; return 0;
case CODES_WK_BARRIER: case CODES_WK_BARRIER:
...@@ -352,6 +382,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -352,6 +382,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
rank, op_number, "Invalid communicator"); rank, op_number, "Invalid communicator");
#if DEBUG_PROFILING
end = MPI_Wtime();
total_barrier_time += (end - start);
#endif
return 0; return 0;
case CODES_WK_OPEN: case CODES_WK_OPEN:
...@@ -393,6 +428,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -393,6 +428,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
tmp_list->file_hash = replay_op.u.open.file_id; tmp_list->file_hash = replay_op.u.open.file_id;
tmp_list->file_descriptor = fildes; tmp_list->file_descriptor = fildes;
qhash_add(fd_table, &(replay_op.u.open.file_id), &(tmp_list->hash_link)); qhash_add(fd_table, &(replay_op.u.open.file_id), &(tmp_list->hash_link));
#if DEBUG_PROFILING
end = MPI_Wtime();
total_open_time += (end - start);
#endif
return 0; return 0;
case CODES_WK_CLOSE: case CODES_WK_CLOSE:
...@@ -417,6 +457,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -417,6 +457,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#if DEBUG_PROFILING
end = MPI_Wtime();
total_close_time += (end - start);
#endif
return 0; return 0;
case CODES_WK_WRITE: case CODES_WK_WRITE:
...@@ -449,6 +494,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -449,6 +494,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#if DEBUG_PROFILING
end = MPI_Wtime();
total_write_time += (end - start);
#endif
return 0; return 0;
case CODES_WK_READ: case CODES_WK_READ:
...@@ -480,6 +530,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -480,6 +530,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#if DEBUG_PROFILING
end = MPI_Wtime();
total_read_time += (end - start);
#endif
return 0; return 0;
default: default:
Markdown is supported
0% or .
Please register or to comment
