Commit 57314836 authored by Jonathan Jenkins's avatar Jonathan Jenkins
whoops, forgot to update print functions
parent 722c1fc4
...@@ -212,36 +212,36 @@ void codes_workload_print_op( ...@@ -212,36 +212,36 @@ void codes_workload_print_op(
break; break;
case CODES_WK_DELAY: case CODES_WK_DELAY:
fprintf(f, "op: app:%d rank:%d type:delay seconds:%lf\n", fprintf(f, "op: app:%d rank:%d type:delay seconds:%lf\n",
rank, op->u.delay.seconds); app_id, rank, op->u.delay.seconds);
break; break;
case CODES_WK_BARRIER: case CODES_WK_BARRIER:
fprintf(f, "op: app:%d rank:%d type:barrier count:%d root:%d\n", fprintf(f, "op: app:%d rank:%d type:barrier count:%d root:%d\n",
rank, op->u.barrier.count, op->u.barrier.root); app_id, rank, op->u.barrier.count, op->u.barrier.root);
break; break;
case CODES_WK_OPEN: case CODES_WK_OPEN:
fprintf(f, "op: app:%d rank:%d type:open file_id:%lu flag:%d\n", fprintf(f, "op: app:%d rank:%d type:open file_id:%lu flag:%d\n",
rank, op->u.open.file_id, op->u.open.create_flag); app_id, rank, op->u.open.file_id, op->u.open.create_flag);
break; break;
case CODES_WK_CLOSE: case CODES_WK_CLOSE:
fprintf(f, "op: app:%d rank:%d type:close file_id:%lu\n", fprintf(f, "op: app:%d rank:%d type:close file_id:%lu\n",
rank, op->u.close.file_id); app_id, rank, op->u.close.file_id);
break; break;
case CODES_WK_WRITE: case CODES_WK_WRITE:
fprintf(f, "op: app:%d rank:%d type:write " fprintf(f, "op: app:%d rank:%d type:write "
"file_id:%lu off:%lu size:%lu\n", "file_id:%lu off:%lu size:%lu\n",
rank, op->u.write.file_id, op->u.write.offset, app_id, rank, op->u.write.file_id, op->u.write.offset,
op->u.write.size); op->u.write.size);
break; break;
case CODES_WK_READ: case CODES_WK_READ:
fprintf(f, "op: app:%d rank:%d type:read " fprintf(f, "op: app:%d rank:%d type:read "
rank, op->u.read.file_id, op->u.read.offset, app_id, rank, op->u.read.file_id, op->u.read.offset,
op->u.read.size); op->u.read.size);
break; break;
case CODES_WK_SEND: case CODES_WK_SEND:
fprintf(f, "op: app:%d rank:%d type:send " fprintf(f, "op: app:%d rank:%d type:send "
"src:%d dst:%d bytes:%d type:%d count:%d tag:%d\n", "src:%d dst:%d bytes:%d type:%d count:%d tag:%d\n",
rank, app_id, rank,
op->u.send.source_rank, op->u.send.dest_rank, op->u.send.source_rank, op->u.send.dest_rank,
op->u.send.num_bytes, op->u.send.data_type, op->u.send.num_bytes, op->u.send.data_type,
op->u.send.count, op->u.send.tag); op->u.send.count, op->u.send.tag);
...@@ -249,7 +249,7 @@ void codes_workload_print_op( ...@@ -249,7 +249,7 @@ void codes_workload_print_op(
case CODES_WK_RECV: case CODES_WK_RECV:
fprintf(f, "op: app:%d rank:%d type:recv " fprintf(f, "op: app:%d rank:%d type:recv "
rank, app_id, rank,
op->u.recv.source_rank, op->u.recv.dest_rank, op->u.recv.source_rank, op->u.recv.dest_rank,
op->u.recv.num_bytes, op->u.recv.data_type, op->u.recv.num_bytes, op->u.recv.data_type,
op->u.recv.count, op->u.recv.tag); op->u.recv.count, op->u.recv.tag);
...@@ -257,7 +257,7 @@ void codes_workload_print_op( ...@@ -257,7 +257,7 @@ void codes_workload_print_op(
case CODES_WK_ISEND: case CODES_WK_ISEND:
fprintf(f, "op: app:%d rank:%d type:isend " fprintf(f, "op: app:%d rank:%d type:isend "
rank, app_id, rank,
...@@ -265,38 +265,38 @@ void codes_workload_print_op( ...@@ -265,38 +265,38 @@ void codes_workload_print_op(
case CODES_WK_IRECV: case CODES_WK_IRECV:
fprintf(f, "op: app:%d rank:%d type:irecv " fprintf(f, "op: app:%d rank:%d type:irecv "
rank, app_id, rank,
break; break;
case CODES_WK_BCAST: case CODES_WK_BCAST:
fprintf(f, "op: app:%d rank:%d type:bcast " fprintf(f, "op: app:%d rank:%d type:bcast "
"bytes:%d\n", rank, op->u.collective.num_bytes); "bytes:%d\n", app_id, rank, op->u.collective.num_bytes);
break; break;
case CODES_WK_ALLGATHER: case CODES_WK_ALLGATHER:
fprintf(f, "op: app:%d rank:%d type:allgather " fprintf(f, "op: app:%d rank:%d type:allgather "
break; break;
case CODES_WK_ALLGATHERV: case CODES_WK_ALLGATHERV:
fprintf(f, "op: app:%d rank:%d type:allgatherv " fprintf(f, "op: app:%d rank:%d type:allgatherv "
break; break;
case CODES_WK_ALLTOALL: case CODES_WK_ALLTOALL:
fprintf(f, "op: app:%d rank:%d type:alltoall " fprintf(f, "op: app:%d rank:%d type:alltoall "
break; break;
case CODES_WK_ALLTOALLV: case CODES_WK_ALLTOALLV:
fprintf(f, "op: app:%d rank:%d type:alltoallv " fprintf(f, "op: app:%d rank:%d type:alltoallv "
break; break;
case CODES_WK_REDUCE: case CODES_WK_REDUCE:
fprintf(f, "op: app:%d rank:%d type:reduce " fprintf(f, "op: app:%d rank:%d type:reduce "
break; break;
case CODES_WK_ALLREDUCE: case CODES_WK_ALLREDUCE:
fprintf(f, "op: app:%d rank:%d type:allreduce " fprintf(f, "op: app:%d rank:%d type:allreduce "
break; break;
case CODES_WK_COL: case CODES_WK_COL:
fprintf(f, "op: app:%d rank:%d type:collective " fprintf(f, "op: app:%d rank:%d type:collective "
...@@ -304,19 +304,19 @@ void codes_workload_print_op( ...@@ -304,19 +304,19 @@ void codes_workload_print_op(
break; break;
case CODES_WK_WAITALL: case CODES_WK_WAITALL:
fprintf(f, "op: app:%d rank:%d type:waitall " fprintf(f, "op: app:%d rank:%d type:waitall "
"num reqs: :%d\n", op->u.waits.count); "num reqs: :%d\n", app_id, rank, op->u.waits.count);
break; break;
case CODES_WK_WAIT: case CODES_WK_WAIT:
fprintf(f, "op: app:%d rank:%d type:wait " fprintf(f, "op: app:%d rank:%d type:wait "
"num reqs: :%d\n", op->u.wait.req_id); "num reqs: :%d\n", app_id, rank, op->u.wait.req_id);
break; break;
case CODES_WK_WAITSOME: case CODES_WK_WAITSOME:
fprintf(f, "op: app:%d rank:%d type:waitsome " fprintf(f, "op: app:%d rank:%d type:waitsome "
break; break;
case CODES_WK_WAITANY: case CODES_WK_WAITANY:
fprintf(f, "op: app:%d rank:%d type:waitany " fprintf(f, "op: app:%d rank:%d type:waitany "
break; break;
case CODES_WK_IGNORE: case CODES_WK_IGNORE:
break; break;
Markdown is supported
0%
or
Please register or to comment
