Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
549ca83d
Commit
549ca83d
authored
Jan 30, 2014
by
Shane Snyder
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'master' of git.mcs.anl.gov:radix/codes-base
parents
cdfe3c19
6518978f
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
47 additions
and
14 deletions
+47
-14
src/util/README.codes-mapping.txt
+10
-1
src/util/codes_mapping.c
+37
-13
No files found.
View file @
549ca83d
@@ -21,7 +21,6 @@ LPs to the PEs (PEs is an abstraction for MPI rank in ROSS) by placing 1 server
LP a total of 16 times. This configuration is useful if there is some form of communication involved
between the server and example_net LP types, in which case ROSS will place them on the same PE and
communication between server and example_net LPs will not involve remote messages.
The number of server and example_net LPs can be more than 1. Lets assume if we have two example_net
LPs for each server then the config file will have the following format:
@@ -76,3 +75,13 @@ For example, to query the number of repetitions in example-test2.conf file, call
num_repetitions = codes_mapping_get_group_reps("MODELNET_GRP");
will return 16.
=== LP to PE mapping for parallel simulations ===
In the case of parallel simulations using MPI, the LP mapping explained in Step
1 still holds. However, these LPs must also be mapped to PEs, which can be an
arbitrary mapping in ROSS. We simply assign the first N LPs to the first PE, the
second N to the second PE, and so forth, where N is the floor of the LP count
and the PE count. If the number of LPs is not divisible by the number of PEs,
then the first N+1 LPs are mapped to the first PE and so on, until the remainder
has been taken care of.
View file @
549ca83d
@@ -11,9 +11,16 @@
#define CODES_MAPPING_DEBUG 0
/* number of LPs assigned to the current PE (abstraction of MPI rank) */
static
int
lps_for_this_pe
0
/* number of LPs assigned to the current PE (abstraction of MPI rank).
* for lp counts which are not divisible by the number of ranks, keep
* modulus around */
static
int
lps_per_pe_floor
0
static
int
lps_leftover
0
static
int
mem_factor
1024
static
inline
int
mini
int
a
int
b
return
a
b
a
b
/* char arrays for holding lp type name and group name*/
char
local_grp_name
MAX_NAME_LENGTH
local_lp_name
MAX_NAME_LENGTH
@@ -21,13 +28,25 @@ config_lpgroups_t lpconf;
int
codes_mapping_get_lps_for_pe
return
lps_for_this_pe
int
rank
MPI_Comm_rank
MPI_COMM_WORLD
rank
#if CODES_MAPPING_DEBUG
printf
"%d lps for rank %d
\n
lps_per_pe_floor
g_tw_mynode
lps_leftover
rank
#endif
return
lps_per_pe_floor
g_tw_mynode
lps_leftover
/* Takes the global LP ID and returns the rank (PE id) on which the LP is mapped */
tw_peid
codes_mapping
tw_lpid
gid
return
gid
lps_for_this_pe
int
lps_on_pes_with_leftover
lps_leftover
lps_per_pe_floor
1
if
gid
return
gid
lps_per_pe_floor
1
else
return
gid
lps_per_pe_floor
lps_leftover
/*return gid / lps_per_pe_floor;*/
int
char
grp_name
@@ -187,20 +206,23 @@ static void codes_mapping_init(void)
for
kpid
0
kpid
nkp_per_pe
kpid
tw_kp_onpe
kpid
g_tw_pe
0
int
lp_init_range
g_tw_mynode
lps_for_this_pe
codes_mapping_get_lp_info
lp_init_range
grp_name
grp_id
lpt_id
lp_type_name
rep_id
offset
int
lp_start
g_tw_mynode
lps_per_pe_floor
mini
g_tw_mynode
lps_leftover
int
lp_end
g_tw_mynode
1
lps_per_pe_floor
mini
g_tw_mynode
1
lps_leftover
lp_start
grp_name
grp_id
lpt_id
lp_type_name
rep_id
offset
for
lpid
lp_
init_range
lpid
lp_init_range
lps_for_this_pe
lpid
for
lpid
lp_
start
lpid
lp_end
lpid
ross_gid
lpid
ross_lid
lpid
lp_
init_range
ross_lid
lpid
lp_
start
kpid
ross_lid
g_tw_nkp
pe
tw_getpe
kpid
g_tw_npe
ross_gid
grp_name
grp_id
lpt_id
lp_type_name
rep_id
offset
printf
"lp:%lu --> kp:%lu, pe:%llu
\n
ross_gid
kpid
pe
id
#endif
tw_lp_onpe
ross_lid
pe
ross_gid
tw_lp_onpe
ross_lid
pe
ross_gid
tw_lp_onkp
g_tw_lp
ross_lid
g_tw_kp
kpid
tw_lp_settype
ross_lid
lp_type_lookup
lp_type_name
@@ -212,7 +234,8 @@ static void codes_mapping_init(void)
* global LP IDs are unique across all PEs, local LP IDs are unique within a PE */
static
tw_lp
codes_mapping_to_lp
tw_lpid
lpid
int
index
lpid
g_tw_mynode
lps_for_this_pe
int
index
lpid
g_tw_mynode
lps_per_pe_floor
mini
g_tw_mynode
lps_leftover
// printf("\n global id %d index %d lps_before %d lps_offset %d local index %d ", lpid, index, lps_before, g_tw_mynode, local_index);
return
g_tw_lp
index
@@ -228,10 +251,11 @@ void codes_mapping_setup()
for
grp
0
grp
lpconf
lpgroups_count
grp
for
lpt
0
lpt
lpconf
lpgroups
grp
lptypes_count
lpt
lps_
for_this_pe
lpconf
lpgroups
grp
lptypes
lpt
count
lpconf
lpgroups
grp
repetitions
lps_
per_pe_floor
lpconf
lpgroups
grp
lptypes
lpt
count
lpconf
lpgroups
grp
repetitions
lps_for_this_pe
pes
//printf("\n LPs for this PE are %d reps %d ", lps_for_this_pe, lpconf.lpgroups[grp].repetitions);
lps_leftover
lps_per_pe_floor
pes
lps_per_pe_floor
pes
//printf("\n LPs for this PE are %d reps %d ", lps_per_pe_floor, lpconf.lpgroups[grp].repetitions);
g_tw_mapping
CUSTOM
g_tw_custom_initial_mapping
codes_mapping_init
g_tw_custom_lp_global_to_local_map
codes_mapping_to_lp
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
