Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
codes
codes
Commits
52816466
Commit
52816466
authored
Oct 30, 2014
by
Jonathan Jenkins
Browse files
added some scratch notes into best practices for later
parent
6514d8ab
Changes
1
Show whitespace changes
Inline
Side-by-side
doc/codes-best-practices.tex
View file @
52816466
@@ -641,6 +641,52 @@ event handlers are buggy).
strategies using it, tips on testing, common issues that come up, etc.
\item
put a pdf or latex2html version of this document on the codes web page
\item
when it's ready
when it's ready
\item
use msg
\_
header at the top of all message structs
\begin{itemize}
\item
makes debugging a lot easier if they share the same first few fields
\end{itemize}
\item
use different starting values for event type enums - along with
previous point, helps determine originating LP message
\item
use self suspend (this deserves its own section)
\item
separate register / configure functions for LPs
\begin{itemize}
\item
need to add lp type struct prior to codes
\_
mapping
\_
setup,
and it is often useful for LP-specific configuration to have
access to codes-mapping functionsk
\item
especially needed for global config schemes with multiple
annotations - need the annotations provided by
codes-mapping, configuration APIs to know what fields to
look for
\end{itemize}
\item
lp-io
\begin{itemize}
\item
use command-line to configure turning io on and off, and
where (dir) to place output. Use LP-specific options in the
configuration file to drive specific options for output within
the LP
\item
suggested command line options
\begin{itemize}
\item
"--lp-io-dir=DIR" : use DIR as the directory -
absence of option indicates no lp-io output
\item
"--lp-io-use-suffix=DUMMY" : add the PID of the root
rank to the directory name to avoid clashes between
multiple runs. If not specified, then the DIR option
will be exactly used, possibly leading to an assert.
\end{itemize}
\end{itemize}
\item
dealing with simulations with many 'destructive' operations and
mutable state (esp. state used/reset in multiple event sequences)
\begin{itemize}
\item
use self-suspend liberally!!!
\item
consider the *entire* sequence of events that affect a
piece of mutable/destructible state, esp. from different LPs.
You can get an event from the future on state that you've
rolled back, for example, or multiple equivalent events that
differ only in timestamp (e.g., event to remote -> roll back
-> event to remote)
\end{itemize}
\item
don't use tw
\_
now at finalize - gives inconsistent results
\end{itemize}
\end{itemize}
\begin{comment}
==== SCRATCH MATERIAL ====
\begin{comment}
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
