Commit 5022b2e6 authored by Elsa Gonsiorowski (Eris)'s avatar Elsa Gonsiorowski (Eris)
Browse files
merge with commit_f changes. Several whitespace changes due to my editor
parent 78745f23
...@@ -53,7 +53,7 @@ enum svr_event ...@@ -53,7 +53,7 @@ enum svr_event
LOCAL /* local event */ LOCAL /* local event */
/* this struct serves as the ***persistent*** state of the LP representing the /* this struct serves as the ***persistent*** state of the LP representing the
* server in question. This struct is setup when the LP initialization function * server in question. This struct is setup when the LP initialization function
* ptr is called */ * ptr is called */
struct svr_state struct svr_state
...@@ -107,7 +107,8 @@ tw_lptype svr_lp = { ...@@ -107,7 +107,8 @@ tw_lptype svr_lp = {
(pre_run_f) NULL, (pre_run_f) NULL,
(event_f) svr_event, (event_f) svr_event,
(revent_f) svr_rev_event, (revent_f) svr_rev_event,
(final_f) svr_finalize, (commit_f) NULL,
(map_f) codes_mapping, (map_f) codes_mapping,
sizeof(svr_state), sizeof(svr_state),
...@@ -193,9 +194,9 @@ int main( ...@@ -193,9 +194,9 @@ int main(
/* ROSS initialization function calls */ /* ROSS initialization function calls */
tw_opt_add(app_opt); /* add user-defined args */ tw_opt_add(app_opt); /* add user-defined args */
/* initialize ROSS and parse args. NOTE: tw_init calls MPI_Init */ /* initialize ROSS and parse args. NOTE: tw_init calls MPI_Init */
tw_init(&argc, &argv); tw_init(&argc, &argv);
if (!conf_file_name[0]) if (!conf_file_name[0])
fprintf(stderr, "Expected \"codes-config\" option, please see --help.\n"); fprintf(stderr, "Expected \"codes-config\" option, please see --help.\n");
MPI_Finalize(); MPI_Finalize();
...@@ -204,9 +205,9 @@ int main( ...@@ -204,9 +205,9 @@ int main(
MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &nprocs); MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
/* loading the config file into the codes-mapping utility, giving us the /* loading the config file into the codes-mapping utility, giving us the
* parsed config object in return. * parsed config object in return.
* "config" is a global var defined by codes-mapping */ * "config" is a global var defined by codes-mapping */
if (configuration_load(conf_file_name, MPI_COMM_WORLD, &config)){ if (configuration_load(conf_file_name, MPI_COMM_WORLD, &config)){
fprintf(stderr, "Error loading config file %s.\n", conf_file_name); fprintf(stderr, "Error loading config file %s.\n", conf_file_name);
...@@ -222,7 +223,7 @@ int main( ...@@ -222,7 +223,7 @@ int main(
/* Setup takes the global config object, the registered LPs, and /* Setup takes the global config object, the registered LPs, and
* generates/places the LPs as specified in the configuration file. * generates/places the LPs as specified in the configuration file.
* This should only be called after ALL LP types have been registered in * This should only be called after ALL LP types have been registered in
* codes */ * codes */
codes_mapping_setup(); codes_mapping_setup();
...@@ -233,7 +234,7 @@ int main( ...@@ -233,7 +234,7 @@ int main(
assert(num_nets==1); assert(num_nets==1);
net_id = *net_ids; net_id = *net_ids;
free(net_ids); free(net_ids);
/* in this example, we are using simplenet, which simulates point to point /* in this example, we are using simplenet, which simulates point to point
* communication between any two entities (other networks are trickier to * communication between any two entities (other networks are trickier to
* setup). Hence: */ * setup). Hence: */
if(net_id != SIMPLENET) if(net_id != SIMPLENET)
...@@ -242,7 +243,7 @@ int main( ...@@ -242,7 +243,7 @@ int main(
return 0; return 0;
/* calculate the number of servers in this simulation, /* calculate the number of servers in this simulation,
* ignoring annotations */ * ignoring annotations */
num_servers = codes_mapping_get_lp_count(group_name, 0, "server", NULL, 1); num_servers = codes_mapping_get_lp_count(group_name, 0, "server", NULL, 1);
...@@ -253,7 +254,7 @@ int main( ...@@ -253,7 +254,7 @@ int main(
configuration_get_value_int(&config, param_group_nm, num_reqs_key, NULL, &num_reqs); configuration_get_value_int(&config, param_group_nm, num_reqs_key, NULL, &num_reqs);
configuration_get_value_int(&config, param_group_nm, payload_sz_key, NULL, &payload_sz); configuration_get_value_int(&config, param_group_nm, payload_sz_key, NULL, &payload_sz);
/* begin simulation */ /* begin simulation */
tw_run(); tw_run();
/* model-net has the capability of outputting network transmission stats */ /* model-net has the capability of outputting network transmission stats */
...@@ -270,7 +271,7 @@ const tw_lptype* svr_get_lp_type() ...@@ -270,7 +271,7 @@ const tw_lptype* svr_get_lp_type()
static void svr_add_lp_type() static void svr_add_lp_type()
/* lp_type_register should be called exactly once per process per /* lp_type_register should be called exactly once per process per
* LP type */ * LP type */
lp_type_register("server", svr_get_lp_type()); lp_type_register("server", svr_get_lp_type());
...@@ -282,7 +283,7 @@ static void svr_init( ...@@ -282,7 +283,7 @@ static void svr_init(
tw_event *e; tw_event *e;
svr_msg *m; svr_msg *m;
tw_stime kickoff_time; tw_stime kickoff_time;
memset(ns, 0, sizeof(*ns)); memset(ns, 0, sizeof(*ns));
/* each server sends a dummy event to itself that will kick off the real /* each server sends a dummy event to itself that will kick off the real
...@@ -290,12 +291,12 @@ static void svr_init( ...@@ -290,12 +291,12 @@ static void svr_init(
/* skew each kickoff event slightly to help avoid event ties later on */ /* skew each kickoff event slightly to help avoid event ties later on */
kickoff_time = g_tw_lookahead + tw_rand_unif(lp->rng); kickoff_time = g_tw_lookahead + tw_rand_unif(lp->rng);
/* first create the event (time arg is an offset, not absolute time) */ /* first create the event (time arg is an offset, not absolute time) */
e = tw_event_new(lp->gid, kickoff_time, lp); e = tw_event_new(lp->gid, kickoff_time, lp);
/* after event is created, grab the allocated message and set msg-specific /* after event is created, grab the allocated message and set msg-specific
* data */ * data */
m = tw_event_data(e); m = tw_event_data(e);
m->svr_event_type = KICKOFF; m->svr_event_type = KICKOFF;
/* event is ready to be processed, send it off */ /* event is ready to be processed, send it off */
...@@ -324,7 +325,7 @@ static void svr_event( ...@@ -324,7 +325,7 @@ static void svr_event(
handle_kickoff_event(ns, b, m, lp); handle_kickoff_event(ns, b, m, lp);
break; break;
case LOCAL: case LOCAL:
handle_local_event(ns, b, m, lp); handle_local_event(ns, b, m, lp);
break; break;
default: default:
printf("\n Invalid message type %d ", m->svr_event_type); printf("\n Invalid message type %d ", m->svr_event_type);
...@@ -353,7 +354,7 @@ static void svr_rev_event( ...@@ -353,7 +354,7 @@ static void svr_rev_event(
handle_kickoff_rev_event(ns, b, m, lp); handle_kickoff_rev_event(ns, b, m, lp);
break; break;
handle_local_rev_event(ns, b, m, lp); handle_local_rev_event(ns, b, m, lp);
break; break;
default: default:
assert(0); assert(0);
...@@ -368,7 +369,7 @@ static void svr_finalize( ...@@ -368,7 +369,7 @@ static void svr_finalize(
svr_state * ns, svr_state * ns,
tw_lp * lp) tw_lp * lp)
printf("server %llu recvd %d bytes in %lf seconds, %lf MiB/s sent_count %d recvd_count %d local_count %d \n", printf("server %llu recvd %d bytes in %lf seconds, %lf MiB/s sent_count %d recvd_count %d local_count %d \n",
(unsigned long long)(lp->gid/2), (unsigned long long)(lp->gid/2),
payload_sz*ns->msg_recvd_count, payload_sz*ns->msg_recvd_count,
ns_to_s(ns->end_ts-ns->start_ts), ns_to_s(ns->end_ts-ns->start_ts),
...@@ -395,7 +396,7 @@ static tw_stime s_to_ns(tw_stime ns) ...@@ -395,7 +396,7 @@ static tw_stime s_to_ns(tw_stime ns)
tw_lpid get_next_server(tw_lpid sender_id) tw_lpid get_next_server(tw_lpid sender_id)
tw_lpid rtn_id; tw_lpid rtn_id;
/* first, get callers LP and group info from codes-mapping. Caching this /* first, get callers LP and group info from codes-mapping. Caching this
* info in the LP struct isn't a bad idea for preventing a huge number of * info in the LP struct isn't a bad idea for preventing a huge number of
* lookups */ * lookups */
char grp_name[MAX_NAME_LENGTH], lp_type_name[MAX_NAME_LENGTH], char grp_name[MAX_NAME_LENGTH], lp_type_name[MAX_NAME_LENGTH],
...@@ -404,8 +405,8 @@ tw_lpid get_next_server(tw_lpid sender_id) ...@@ -404,8 +405,8 @@ tw_lpid get_next_server(tw_lpid sender_id)
int dest_rep_id; int dest_rep_id;
codes_mapping_get_lp_info(sender_id, grp_name, &grp_id, lp_type_name, codes_mapping_get_lp_info(sender_id, grp_name, &grp_id, lp_type_name,
&lp_type_id, annotation, &grp_rep_id, &off); &lp_type_id, annotation, &grp_rep_id, &off);
/* in this example, we assume that, for our group of servers, each /* in this example, we assume that, for our group of servers, each
* "repetition" consists of a single server/NIC pair. Hence, we grab the * "repetition" consists of a single server/NIC pair. Hence, we grab the
* server ID for the next repetition, looping around if necessary */ * server ID for the next repetition, looping around if necessary */
num_reps = codes_mapping_get_group_reps(grp_name); num_reps = codes_mapping_get_group_reps(grp_name);
dest_rep_id = (grp_rep_id+1) % num_reps; dest_rep_id = (grp_rep_id+1) % num_reps;
...@@ -429,7 +430,7 @@ static void handle_kickoff_event( ...@@ -429,7 +430,7 @@ static void handle_kickoff_event(
/* normally, when using ROSS, events are allocated as a result of the event /* normally, when using ROSS, events are allocated as a result of the event
* creation process. However, since we are now asking model-net to * creation process. However, since we are now asking model-net to
* communicate with an entity on our behalf, we need to generate both the * communicate with an entity on our behalf, we need to generate both the
* message to the recipient and an optional callback message * message to the recipient and an optional callback message
* - thankfully, memory need not persist past the model_net_event call - it * - thankfully, memory need not persist past the model_net_event call - it
* copies the messages */ * copies the messages */
svr_msg m_local; svr_msg m_local;
...@@ -443,9 +444,9 @@ static void handle_kickoff_event( ...@@ -443,9 +444,9 @@ static void handle_kickoff_event(
/* record when transfers started on this server */ /* record when transfers started on this server */
ns->start_ts = tw_now(lp); ns->start_ts = tw_now(lp);
/* each server sends a request to the next highest server /* each server sends a request to the next highest server
* In this simulation, LP determination is simple: LPs are assigned * In this simulation, LP determination is simple: LPs are assigned
* round robin as in serv_1, net_1, serv_2, net_2, etc. * round robin as in serv_1, net_1, serv_2, net_2, etc.
* However, that may not always be the case, so we also show a more * However, that may not always be the case, so we also show a more
* complicated way to map through codes_mapping */ * complicated way to map through codes_mapping */
if (use_brute_force_map) if (use_brute_force_map)
...@@ -457,13 +458,13 @@ static void handle_kickoff_event( ...@@ -457,13 +458,13 @@ static void handle_kickoff_event(
/* model-net needs to know about (1) higher-level destination LP which is a neighboring server in this case /* model-net needs to know about (1) higher-level destination LP which is a neighboring server in this case
* (2) struct and size of remote message and (3) struct and size of local message (a local message can be null) */ * (2) struct and size of remote message and (3) struct and size of local message (a local message can be null) */
m->ret = model_net_event(net_id, "test", dest_id, payload_sz, 0.0, sizeof(svr_msg), m->ret = model_net_event(net_id, "test", dest_id, payload_sz, 0.0, sizeof(svr_msg),
(const void*)&m_remote, sizeof(svr_msg), (const void*)&m_local, lp); (const void*)&m_remote, sizeof(svr_msg), (const void*)&m_local, lp);
ns->msg_sent_count++; ns->msg_sent_count++;
/* at the moment, no need for local callbacks from model-net, so we maintain a /* at the moment, no need for local callbacks from model-net, so we maintain a
* count for debugging purposes */ * count for debugging purposes */
static void handle_local_event( static void handle_local_event(
tw_bf * b, tw_bf * b,
...@@ -492,7 +493,7 @@ static void handle_ack_event( ...@@ -492,7 +493,7 @@ static void handle_ack_event(
* destination server */ * destination server */
/* safety check that this request got to the right server, both with our /* safety check that this request got to the right server, both with our
* brute-force lp calculation and our more generic codes-mapping * brute-force lp calculation and our more generic codes-mapping
* calculation */ * calculation */
assert(m->src == (lp->gid + offset)%(num_servers*2) && assert(m->src == (lp->gid + offset)%(num_servers*2) &&
m->src == get_next_server(lp->gid)); m->src == get_next_server(lp->gid));
...@@ -509,11 +510,11 @@ static void handle_ack_event( ...@@ -509,11 +510,11 @@ static void handle_ack_event(
m_remote.src = lp->gid; m_remote.src = lp->gid;
/* send another request */ /* send another request */
m->ret = model_net_event(net_id, "test", m->src, payload_sz, 0.0, sizeof(svr_msg), m->ret = model_net_event(net_id, "test", m->src, payload_sz, 0.0, sizeof(svr_msg),
m->incremented_flag = 1; m->incremented_flag = 1;
else else
...@@ -541,7 +542,7 @@ static void handle_req_event( ...@@ -541,7 +542,7 @@ static void handle_req_event(
/* safety check that this request got to the right server */ /* safety check that this request got to the right server */
assert(lp->gid == (m->src + offset)%(num_servers*2) && assert(lp->gid == (m->src + offset)%(num_servers*2) &&
lp->gid == get_next_server(m->src)); lp->gid == get_next_server(m->src));
ns->msg_recvd_count++; ns->msg_recvd_count++;
...@@ -550,8 +551,8 @@ static void handle_req_event( ...@@ -550,8 +551,8 @@ static void handle_req_event(
/* simulated payload of 1 MiB */ /* simulated payload of 1 MiB */
/* also trigger a local event for completion of payload msg */ /* also trigger a local event for completion of payload msg */
/* remote host will get an ack event */ /* remote host will get an ack event */
return; return;
...@@ -582,7 +583,7 @@ static void handle_req_rev_event( ...@@ -582,7 +583,7 @@ static void handle_req_rev_event(
(void)b; (void)b;
(void)m; (void)m;
ns->msg_recvd_count--; ns->msg_recvd_count--;
/* model-net has its own reverse computation support */ /* model-net has its own reverse computation support */
model_net_event_rc2(lp, &m->ret); model_net_event_rc2(lp, &m->ret);
return; return;
...@@ -15,7 +15,7 @@ ...@@ -15,7 +15,7 @@
/**** BEGIN SIMULATION DATA STRUCTURES ****/ /**** BEGIN SIMULATION DATA STRUCTURES ****/
/* 'magic' numbers used as sanity check on events */ /* 'magic' numbers used as sanity check on events */
static int node_magic; static int node_magic;
static int forwarder_magic; static int forwarder_magic;
/* counts of the various types of nodes in the example system */ /* counts of the various types of nodes in the example system */
...@@ -55,8 +55,8 @@ enum forwarder_event ...@@ -55,8 +55,8 @@ enum forwarder_event
typedef struct forwarder_state_s { typedef struct forwarder_state_s {
int id; // index w.r.t. forwarders in my group int id; // index w.r.t. forwarders in my group
int is_in_foo; int is_in_foo;
int fwd_node_count; int fwd_node_count;
int fwd_forwarder_count; int fwd_forwarder_count;
} forwarder_state; } forwarder_state;
...@@ -98,7 +98,7 @@ void node_finalize( ...@@ -98,7 +98,7 @@ void node_finalize(
// messages // messages
int mult; int mult;
if (ns->is_in_foo){ if (ns->is_in_foo){
mult = 1; mult = 1;
else{ else{
mult = (num_foo_nodes / num_bar_nodes) + mult = (num_foo_nodes / num_bar_nodes) +
...@@ -197,7 +197,7 @@ void node_event_handler( ...@@ -197,7 +197,7 @@ void node_event_handler(
tw_lp * lp){ tw_lp * lp){
(void)b; (void)b;
assert(m->h.magic == node_magic); assert(m->h.magic == node_magic);
switch (m->h.event_type){ switch (m->h.event_type){
case NODE_KICKOFF: case NODE_KICKOFF:
// nodes from foo ping to nodes in bar // nodes from foo ping to nodes in bar
...@@ -223,7 +223,8 @@ static tw_lptype node_lp = { ...@@ -223,7 +223,8 @@ static tw_lptype node_lp = {
(event_f) node_event_handler, (event_f) node_event_handler,
(revent_f) NULL, (revent_f) NULL,
(final_f) node_finalize, (commit_f) NULL,
sizeof(node_state), sizeof(node_state),
...@@ -243,7 +244,7 @@ void node_register(){ ...@@ -243,7 +244,7 @@ void node_register(){
void forwarder_lp_init( void forwarder_lp_init(
forwarder_state * ns, forwarder_state * ns,
// like nodes, forwarders in this example are addressed logically // like nodes, forwarders in this example are addressed logically
ns->id = codes_mapping_get_lp_relative_id(lp->gid, 1, 0); ns->id = codes_mapping_get_lp_relative_id(lp->gid, 1, 0);
int id_all = codes_mapping_get_lp_relative_id(lp->gid, 0, 0); int id_all = codes_mapping_get_lp_relative_id(lp->gid, 0, 0);
ns->is_in_foo = (id_all < num_foo_forwarders); ns->is_in_foo = (id_all < num_foo_forwarders);
...@@ -261,7 +262,7 @@ void handle_forwarder_fwd( ...@@ -261,7 +262,7 @@ void handle_forwarder_fwd(
forwarder_msg * m, forwarder_msg * m,
// compute the forwarder lpid to forward to // compute the forwarder lpid to forward to
int mod; int mod;
const char * dest_group; const char * dest_group;
char * category; char * category;
...@@ -295,13 +296,13 @@ void handle_forwarder_recv( ...@@ -295,13 +296,13 @@ void handle_forwarder_recv(
tw_lp * lp) { tw_lp * lp) {
// compute the node to relay the message to // compute the node to relay the message to
const char * annotation; const char * annotation;
int net_id; int net_id;
dest_group = "FOO_CLUSTER"; dest_group = "FOO_CLUSTER";
annotation = "foo"; annotation = "foo";
category = "pong"; category = "pong";
net_id = net_id_foo; net_id = net_id_foo;
...@@ -354,7 +355,8 @@ static tw_lptype forwarder_lp = { ...@@ -354,7 +355,8 @@ static tw_lptype forwarder_lp = {
(event_f) forwarder_event_handler, (event_f) forwarder_event_handler,
(final_f) forwarder_finalize, (commit_f) NULL,
sizeof(forwarder_state), sizeof(forwarder_state),
...@@ -395,16 +397,16 @@ int main(int argc, char *argv[]) ...@@ -395,16 +397,16 @@ int main(int argc, char *argv[])
if (!conf_file_name[0]) { if (!conf_file_name[0]) {
tw_error(TW_LOC, tw_error(TW_LOC,
"Expected \"codes-config\" option, please see --help.\n"); "Expected \"codes-config\" option, please see --help.\n");
return 1; return 1;
tw_error(TW_LOC, "Error loading config file %s.\n", conf_file_name); tw_error(TW_LOC, "Error loading config file %s.\n", conf_file_name);
...@@ -470,7 +472,7 @@ int main(int argc, char *argv[]) ...@@ -470,7 +472,7 @@ int main(int argc, char *argv[])
tw_run(); tw_run();
tw_end(); tw_end();
...@@ -99,6 +99,7 @@ tw_lptype svr_lp = { ...@@ -99,6 +99,7 @@ tw_lptype svr_lp = {
(commit_f) NULL,
(final_f) svr_finalize, (final_f) svr_finalize,
...@@ -169,11 +170,11 @@ static void handle_kickoff_rev_event( ...@@ -169,11 +170,11 @@ static void handle_kickoff_rev_event(
if(b->c1) if(b->c1)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
model_net_event_rc(net_id, lp, PAYLOAD_SZ); model_net_event_rc(net_id, lp, PAYLOAD_SZ);
ns->msg_sent_count--; ns->msg_sent_count--;
static void handle_kickoff_event( static void handle_kickoff_event(
...@@ -190,7 +191,7 @@ static void handle_kickoff_event( ...@@ -190,7 +191,7 @@ static void handle_kickoff_event(
char anno[MAX_NAME_LENGTH]; char anno[MAX_NAME_LENGTH];
tw_lpid local_dest = -1, global_dest = -1; tw_lpid local_dest = -1, global_dest = -1;
svr_msg * m_local = malloc(sizeof(svr_msg)); svr_msg * m_local = malloc(sizeof(svr_msg));
svr_msg * m_remote = malloc(sizeof(svr_msg)); svr_msg * m_remote = malloc(sizeof(svr_msg));
...@@ -215,7 +216,7 @@ static void handle_kickoff_event( ...@@ -215,7 +216,7 @@ static void handle_kickoff_event(
local_dest = (local_id + num_nodes_per_grp) % num_nodes; local_dest = (local_id + num_nodes_per_grp) % num_nodes;
//printf("\n LP %ld sending to %ld num nodes %d ", local_id, local_dest, num_nodes); //printf("\n LP %ld sending to %ld num nodes %d ", local_id, local_dest, num_nodes);
else if(traffic == NEAREST_NEIGHBOR) else if(traffic == NEAREST_NEIGHBOR)
local_dest = (local_id + 1) % num_nodes; local_dest = (local_id + 1) % num_nodes;
...@@ -226,13 +227,13 @@ static void handle_kickoff_event( ...@@ -226,13 +227,13 @@ static void handle_kickoff_event(
global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0); global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0);
model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp); model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp);
issue_event(ns, lp); issue_event(ns, lp);
return; return;
static void handle_remote_rev_event( static void handle_remote_rev_event(
svr_state * ns,
