Commit 4f50e629 authored by Nikhil's avatar Nikhil
Browse files
Bug fix: use the correct time stamps
Change-Id: I4aa8fb074b9142a0bc2a2311c158a356f12f79cb
parent 19782842
...@@ -26,7 +26,7 @@ ...@@ -26,7 +26,7 @@
#define DEBUG_RC 0 #define DEBUG_RC 0
//Data Collection Output Files //Data Collection Output Files
#define PARAMS_LOG 1 #define PARAMS_LOG 0
#define LP_CONFIG_NM (model_net_lp_config_names[FATTREE]) #define LP_CONFIG_NM (model_net_lp_config_names[FATTREE])
#define LP_METHOD_NM (model_net_method_names[FATTREE]) #define LP_METHOD_NM (model_net_method_names[FATTREE])
...@@ -1238,10 +1238,22 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1238,10 +1238,22 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
return; return;
// Each packet is broken into chunks and then sent over the channel uint64_t num_chunks = cur_entry->msg.packet_size/s->params->chunk_size;
if(cur_entry->msg.packet_size % s->params->chunk_size)
num_chunks++;
if(!num_chunks)
num_chunks = 1;
ts = g_tw_lookahead + + g_tw_lookahead * tw_rand_unif(lp->rng);
if((cur_entry->msg.packet_size % s->params->chunk_size) && (cur_entry->msg.chunk_id == num_chunks - 1)) {
ts += s->params->cn_delay * (cur_entry->msg.packet_size % s->params->chunk_size);
} else {
bf->c12 = 1;
ts += s->params->cn_delay * s->params->chunk_size;
msg->saved_available_time = s->terminal_available_time; msg->saved_available_time = s->terminal_available_time;
ts = g_tw_lookahead + s->params->cn_delay * cur_entry->msg.packet_size
s->terminal_available_time = maxd(s->terminal_available_time, tw_now(lp)); s->terminal_available_time = maxd(s->terminal_available_time, tw_now(lp));
s->terminal_available_time += ts; s->terminal_available_time += ts;
...@@ -1267,13 +1279,6 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1267,13 +1279,6 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
//printf("[%d] pack send Send to %d\n", lp->gid, s->switch_lp); //printf("[%d] pack send Send to %d\n", lp->gid, s->switch_lp);
tw_event_send(e); tw_event_send(e);
num_chunks++;
if(!num_chunks)
num_chunks = 1;
/* local completion message */ /* local completion message */
if(cur_entry->msg.chunk_id == num_chunks - 1 && (cur_entry->msg.local_event_size_bytes > 0)) if(cur_entry->msg.chunk_id == num_chunks - 1 && (cur_entry->msg.local_event_size_bytes > 0))
...@@ -1513,7 +1518,13 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1513,7 +1518,13 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg,
if(!num_chunks) if(!num_chunks)
num_chunks = 1; num_chunks = 1;
double bytetime = delay; double bytetime;
bytetime = delay * (cur_entry->msg.packet_size % s->params->chunk_size);
} else {
bf->c12 = 1;
bytetime = delay * s->params->chunk_size;
ts = g_tw_lookahead + g_tw_lookahead * tw_rand_unif( lp->rng) + bytetime + s->params->router_delay; ts = g_tw_lookahead + g_tw_lookahead * tw_rand_unif( lp->rng) + bytetime + s->params->router_delay;
msg->saved_available_time = s->next_output_available_time[output_port]; msg->saved_available_time = s->next_output_available_time[output_port];
Markdown is supported
0% or .
Please register or to comment
