Commit 4bf55ecf authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly Plus: Changing prog-adaptive defaults and minimal routing choice
parent 24d16769
...@@ -446,6 +446,7 @@ struct router_state ...@@ -446,6 +446,7 @@ struct router_state
router_type dfp_router_type; // Enum to specify whether this router is a spine or a leaf router_type dfp_router_type; // Enum to specify whether this router is a spine or a leaf
ConnectionManager *connMan; ConnectionManager *connMan;
int *gc_usage;
int *global_channel; int *global_channel;
...@@ -765,8 +766,8 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -765,8 +766,8 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
int int_spn_cons_choice; int int_spn_cons_choice;
rc = configuration_get_value_int(&config, "PARAMS", "int_spine_consider_min", anno, &int_spn_cons_choice); rc = configuration_get_value_int(&config, "PARAMS", "int_spine_consider_min", anno, &int_spn_cons_choice);
if (rc) { if (rc) {
printf("Int spine consideration of min ports not specified. Defaulting to True\n"); printf("Int spine consideration of min ports not specified. Defaulting to False\n");
p->int_spine_consider_min = true; p->int_spine_consider_min = false;
else if (int_spn_cons_choice == 1) { else if (int_spn_cons_choice == 1) {
p->int_spine_consider_min = true; p->int_spine_consider_min = true;
...@@ -790,8 +791,8 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -790,8 +791,8 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
int dst_spn_gcons_choice; int dst_spn_gcons_choice;
rc = configuration_get_value_int(&config, "PARAMS", "dest_spine_consider_global_nonmin", anno, &dst_spn_gcons_choice); rc = configuration_get_value_int(&config, "PARAMS", "dest_spine_consider_global_nonmin", anno, &dst_spn_gcons_choice);
if (rc) { if (rc) {
printf("Dest spine consideration of global nonmin ports not specified. Defaulting to False"); printf("Dest spine consideration of global nonmin ports not specified. Defaulting to True");
p->dest_spine_consider_global_nonmin = false; p->dest_spine_consider_global_nonmin = true;
else if (dst_spn_gcons_choice == 1) { else if (dst_spn_gcons_choice == 1) {
p->dest_spine_consider_global_nonmin = true; p->dest_spine_consider_global_nonmin = true;
...@@ -1235,6 +1236,8 @@ void router_plus_setup(router_state *r, tw_lp *lp) ...@@ -1235,6 +1236,8 @@ void router_plus_setup(router_state *r, tw_lp *lp)
r->connMan = &connManagerList[r->router_id]; r->connMan = &connManagerList[r->router_id];
r->gc_usage = (int *) calloc(p->num_global_connections, sizeof(int));
r->global_channel = (int *) calloc(p->num_global_connections, sizeof(int)); r->global_channel = (int *) calloc(p->num_global_connections, sizeof(int));
r->next_output_available_time = (tw_stime *) calloc(p->radix, sizeof(tw_stime)); r->next_output_available_time = (tw_stime *) calloc(p->radix, sizeof(tw_stime));
r->link_traffic = (int64_t *) calloc(p->radix, sizeof(int64_t)); r->link_traffic = (int64_t *) calloc(p->radix, sizeof(int64_t));
...@@ -2380,6 +2383,33 @@ void dragonfly_plus_terminal_final(terminal_state *s, tw_lp *lp) ...@@ -2380,6 +2383,33 @@ void dragonfly_plus_terminal_final(terminal_state *s, tw_lp *lp)
void dragonfly_plus_router_final(router_state *s, tw_lp *lp) void dragonfly_plus_router_final(router_state *s, tw_lp *lp)
// int max_gc_usage = 0;
// int min_gc_usage = INT_MAX;
// int running_sum = 0;
// for(int i = 0; i < s->params->num_global_connections; i++)
// int gc_val = s->gc_usage[i];
// running_sum += gc_val;
// if (gc_val > max_gc_usage)
// max_gc_usage = gc_val;
// if (gc_val < min_gc_usage)
// min_gc_usage = gc_val;
// double mean_gc_usage = (double) running_sum / (double) s->params->num_global_connections;
// if (s->dfp_router_type == SPINE) {
// printf("Router %d in group %d: Min GC Usage= %d Max GC Usage= %d Mean GC Usage= %.2f", s->router_id, s->router_id / s->params->num_routers, min_gc_usage, max_gc_usage, mean_gc_usage);
// printf("\t[");
// printf("%d ",s->gc_usage[i]);
// printf("]\n");
free(s->global_channel); free(s->global_channel);
int i, j; int i, j;
for (i = 0; i < s->params->radix; i++) { for (i = 0; i < s->params->radix; i++) {
...@@ -2987,15 +3017,18 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2987,15 +3017,18 @@ static Connection do_dfp_routing(router_state *s,
if (poss_next_stops.size() < 1) if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "MINIMAL DEAD END\n"); tw_error(TW_LOC, "MINIMAL DEAD END\n");
ConnectionType conn_type = poss_next_stops[0].conn_type; int rand_sel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1 );
Connection best_min_conn; return poss_next_stops[rand_sel];
if (conn_type == CONN_GLOBAL) {
int rand_sel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1); // ConnectionType conn_type = poss_next_stops[0].conn_type;
return poss_next_stops[rand_sel]; // Connection best_min_conn;
} // if (conn_type == CONN_GLOBAL) {
else // int rand_sel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1);
best_min_conn = get_absolute_best_connection_from_conns(s, bf, msg, lp, poss_next_stops); //gets absolute best // return poss_next_stops[rand_sel];
return best_min_conn; // }
// else
// best_min_conn = get_absolute_best_connection_from_conns(s, bf, msg, lp, poss_next_stops); //gets absolute best
// return best_min_conn;
else { //routing algorithm is specified in routing else { //routing algorithm is specified in routing
...@@ -3242,6 +3275,11 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3242,6 +3275,11 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
max_vc_size = s->params->cn_vc_size; max_vc_size = s->params->cn_vc_size;
// if (port_type == CONN_GLOBAL) {
// int gc_num = output_port - s->params->intra_grp_radix;
// s->gc_usage[gc_num]++;
cur_chunk->msg.output_chan = output_chan; cur_chunk->msg.output_chan = output_chan;
cur_chunk->msg.my_N_hop++; cur_chunk->msg.my_N_hop++;
Markdown is supported
0%
or
Please register or to comment
