Commit 4a1599b2 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
Initial 'simplewan' implementation
parent dd369556
...@@ -17,6 +17,7 @@ ...@@ -17,6 +17,7 @@
#define CATEGORY_MAX 12 #define CATEGORY_MAX 12
typedef struct simplenet_param simplenet_param; typedef struct simplenet_param simplenet_param;
typedef struct simplewan_param simplewan_param;
typedef struct dragonfly_param dragonfly_param; typedef struct dragonfly_param dragonfly_param;
typedef struct torus_param torus_param; typedef struct torus_param torus_param;
typedef struct loggp_param loggp_param; typedef struct loggp_param loggp_param;
...@@ -25,6 +26,7 @@ typedef struct mn_stats mn_stats; ...@@ -25,6 +26,7 @@ typedef struct mn_stats mn_stats;
enum NETWORKS enum NETWORKS
SIMPLENET, SIMPLENET,
SIMPLEWAN,
TORUS, TORUS,
DRAGONFLY, DRAGONFLY,
LOGGP, LOGGP,
...@@ -58,6 +60,12 @@ struct simplenet_param ...@@ -58,6 +60,12 @@ struct simplenet_param
int num_nics; int num_nics;
char bw_filename[MAX_NAME_LENGTH];
char startup_filename[MAX_NAME_LENGTH];
struct dragonfly_param struct dragonfly_param
int num_routers; /*Number of routers in a group*/ int num_routers; /*Number of routers in a group*/
...@@ -12,5 +12,5 @@ src_libcodes_net_a_SOURCES = \ ...@@ -12,5 +12,5 @@ src_libcodes_net_a_SOURCES = \
src/models/networks/model-net/simplenet-upd.c \ src/models/networks/model-net/simplenet-upd.c \
src/models/networks/model-net/torus.c \ src/models/networks/model-net/torus.c \
src/models/networks/model-net/dragonfly.c \ src/models/networks/model-net/dragonfly.c \
src/models/networks/model-net/loggp.c src/models/networks/model-net/loggp.c \
src/models/networks/model-net/simplewan.c
"Simplewan"
Model overview:
Simplewan is an extension of simplenet to allow for arbitrary point-to-point
capacities.
Simplewan has nearly the same duplex queued transmission semantics as
simplenet, though with a few important differences. First, point-to-point
latencies and bandwidths are different. Second, each unique link is given its
own queue that do not interfere with the others. The use case for this model is
a set of sites with internal networks, with each site communicating via
simplewan; we assume the internal network is capable of servicing all
outgoing/incoming WAN transmissions at their full capacities.
Additional configuration is needed to initialize the link latencies/capacities.
In the codes-configuration file, the variables "net_startup_ns_file" and
"net_bw_mbps_file" must be set under the PARAMS group. They point (in a path
relative to the configuration file) to configurations for the startup and
bandwidth costs, respectively.
Each of the latency/bandwidth configuration files have the same format, based
on a triangular matrix. Given N modelnet LPs, it has the format:
1:2 1:3 ... 1:N
2:3 2:4 ... 2:N
N-1:N
where x:y is the latency or bandwidth between components x and y. Whitespace is
ignored, but linebreaks are not, and delimit rows of the matrix. The relative
simplewan identifiers 1..N are assigned to simplewan LPs in the order of
their appearance in the codes-configuration file. In the future, a full NxN
matrix may be used to facilitate asymmetric link capacities if the need arises.
* Copyright (C) 2014 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#include <string.h>
#include <assert.h>
#include <ross.h>
#include "codes/lp-io.h"
#include "codes/jenkins-hash.h"
#include "codes/model-net-method.h"
#include "codes/model-net.h"
#include "codes/codes_mapping.h"
#include "codes/codes.h"
#define CATEGORY_NAME_MAX 16
/*Define simplewan data types and structs*/
typedef struct sw_message sw_message;
typedef struct sw_state sw_state;
/* types of events that will constitute triton requests */
enum sw_event_type
MSG_READY = 1, /* sender has transmitted msg to receiver */
MSG_START, /* initiate a transmission */
typedef struct category_idles_s category_idles;
struct category_idles_s{
/* each simplewan "NIC" actually has N connections, so we need to track
* idle times across all of them to correctly do stats */
tw_stime send_next_idle_all;
tw_stime send_prev_idle_all;
tw_stime recv_next_idle_all;
tw_stime recv_prev_idle_all;
char category[CATEGORY_NAME_MAX];
struct sw_state
/* next idle times for network card, both inbound and outbound */
tw_stime *send_next_idle;
tw_stime *recv_next_idle;
int id; /* logical id for matrix lookups */
/* Each simplewan "NIC" actually has N connections, so we need to track
* idle times across all of them to correctly do stats.
* Additionally need to track different idle times across different
* categories */
category_idles idle_times_cat[CATEGORY_MAX];
struct mn_stats sw_stats_array[CATEGORY_MAX];
struct sw_message
int magic; /* magic number */
enum sw_event_type event_type;
tw_lpid src_gid; /* who transmitted this msg? */
tw_lpid final_dest_gid; /* who is eventually targetted with this msg? */
/* relative ID of the sending simplewan message (for latency/bandwidth lookup) */
int src_mn_rel_id;
int dest_mn_rel_id; /* included to make rc easier */
int net_msg_size_bytes; /* size of modeled network message */
int event_size_bytes; /* size of simulator event message that will be tunnelled to destination */
int local_event_size_bytes; /* size of simulator event message that delivered locally upon local completion */
char category[CATEGORY_NAME_MAX]; /* category for communication */
/* for reverse computation */
tw_stime send_next_idle_saved;
tw_stime recv_next_idle_saved;
tw_stime send_time_saved;
tw_stime recv_time_saved;
tw_stime send_next_idle_all_saved;
tw_stime send_prev_idle_all_saved;
tw_stime recv_next_idle_all_saved;
tw_stime recv_prev_idle_all_saved;
/* net startup cost, ns */
static double *global_net_startup_ns = NULL;
/* net bw, MB/s */
static double *global_net_bw_mbs = NULL;
/* number of simplewan lps, used for addressing the network parameters
* set by the first LP to init per process */
static int num_lps = -1;
static int sw_magic = 0;
/* returns a pointer to the lptype struct to use for simplewan LPs */
static const tw_lptype* sw_get_lp_type(void);
/* set model parameters:
* - startup_fname - path containing triangular matrix of net latencies, in ns
* - bw_fname - path containing triangular matrix of bandwidths in MB/s.
* note that this merely stores the files, they will be parsed later
static void sw_set_params(char * startup_fname, char * bw_fname);
/* retrieve the size of the portion of the event struct that is consumed by
* the simplewan module. The caller should add this value to the size of
* its own event structure to get the maximum total size of a message.
static int sw_get_msg_sz(void);
/* Returns the simplewan magic number */
static int sw_get_magic();
/* given two simplewan logical ids, do matrix lookups to get the point-to-point
* latency/bandwidth */
static double sw_get_bw(int from_id, int to_id);
static double sw_get_startup(int from_id, int to_id);
/* category lookup */
static category_idles* sw_get_category_idles(
char * category, category_idles *idles);
/* allocate a new event that will pass through simplewan to arriave at its
* destination:
* - category: category name to associate with this communication
* - final_dest_gid: the LP that the message should be delivered to.
* - event_size_bytes: size of event msg that will be delivered to
* final_dest_gid.
* - local_event_size_byte: size of event message that will delivered to
* local LP upon local send comletion (set to 0 if not used)
* - net_msg_size_bytes: size of simulated network message in bytes.
* - sender: LP calling this function.
/* Modelnet interface events */
/* sets up the simplewan parameters through modelnet interface */
static void sw_setup(const void* net_params);
/* Issues a simplewan packet event call */
static tw_stime simplewan_packet_event(
char* category,
tw_lpid final_dest_lp,
int packet_size,
tw_stime offset,
int remote_event_size,
const void* remote_event,
int self_event_size,
const void* self_event,
tw_lp *sender,
int is_last_pckt);
static void simplewan_packet_event_rc(tw_lp *sender);
static void sw_report_stats();
static tw_lpid sw_find_local_device(tw_lp *sender);
/* data structure for model-net statistics */
struct model_net_method simplewan_method =
.method_name = "simplewan",
.mn_setup = sw_setup,
.model_net_method_packet_event = simplewan_packet_event,
.model_net_method_packet_event_rc = simplewan_packet_event_rc,
.mn_get_lp_type = sw_get_lp_type,
.mn_get_msg_sz = sw_get_msg_sz,
.mn_report_stats = sw_report_stats,
.model_net_method_find_local_device = sw_find_local_device,
static void sw_init(
sw_state * ns,
tw_lp * lp);
static void sw_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
static void sw_rev_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
static void sw_finalize(
sw_state * ns,
tw_lp * lp);
tw_lptype sw_lp = {
(init_f) sw_init,
(event_f) sw_event,
(revent_f) sw_rev_event,
(final_f) sw_finalize,
(map_f) codes_mapping,
sizeof(sw_state),
static tw_stime rate_to_ns(unsigned int bytes, double MB_p_s);
static void handle_msg_ready_rev_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
static void handle_msg_ready_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
static void handle_msg_start_rev_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
static void handle_msg_start_event(
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp);
/* returns pointer to LP information for simplewan module */
static const tw_lptype* sw_get_lp_type()
return(&sw_lp);
/* returns number of bytes that the simplewan module will consume in event
* messages
return(sizeof(sw_message));
static double * parse_tri_mat(char * buf, int *nvals_first, int *nvals_total){
int bufn = 128;
double *vals = malloc(bufn*sizeof(double));
*nvals_first = 0;
*nvals_total = 0;
/* parse the files by line */
int line_ct, line_ct_prev;
char * line_save;
char * line = strtok_r(buf, "\r\n", &line_save);
while (line != NULL){
line_ct = 0;
char * tok_save;
char * tok = strtok_r(line, " \t", &tok_save);
while (tok != NULL){
if (line_ct + *nvals_total >= bufn){
bufn<<=1;
vals = realloc(vals, bufn*sizeof(double));
vals[line_ct+*nvals_total] = atof(tok);
line_ct++;
tok = strtok_r(NULL, " \t", &tok_save);
/* first line check - number of tokens = the matrix dim */
if (*nvals_first == 0) {
*nvals_first = line_ct;
else if (line_ct != line_ct_prev-1){
fprintf(stderr, "ERROR: tokens in line don't match triangular matrix format\n");
exit(1);
*nvals_total += line_ct;
line_ct_prev = line_ct;
line = strtok_r(NULL, "\r\n", &line_save);
return vals;
static void fill_tri_mat(int N, double *mat, double *tri){
int i, j, p = 0;
/* first fill in triangular mat entries */
for (i = 0; i < N; i++){
double *row = mat + i*N;
row[i] = 0.0;
for (j = i+1; j < N; j++){
row[j] = tri[p++];
/* now fill in remaining entries (basically a transpose) */
for (i = 1; i < N; i++){
for (j = 0; j < i; j++){
mat[i*N+j] = mat[j*N+i];
/* lets caller specify model parameters to use */
static void sw_set_params(char * startup_fname, char * bw_fname){
long int fsize_s, fsize_b;
/* slurp the files */
FILE *sf = fopen(startup_fname, "r");
FILE *bf = fopen(bw_fname, "r");
fseek(sf, 0, SEEK_END);
fsize_s = ftell(sf);
fseek(sf, 0, SEEK_SET);
fseek(bf, 0, SEEK_END);
fsize_b = ftell(bf);
fseek(bf, 0, SEEK_SET);
char *sbuf = malloc(fsize_s+1);
sbuf[fsize_s] = '\0';
char *bbuf = malloc(fsize_b+1);
bbuf[fsize_b] = '\0';
fread(sbuf, 1, fsize_s, sf);
fread(bbuf, 1, fsize_b, bf);
fclose(sf);
fclose(bf);
int nvals_first_s, nvals_first_b, nvals_total_s, nvals_total_b;
double *startup_tmp = parse_tri_mat(sbuf, &nvals_first_s,
&nvals_total_s);
double *bw_tmp = parse_tri_mat(bbuf, &nvals_first_b, &nvals_total_b);
/* convert tri mat into a regular mat */
assert(nvals_first_s == nvals_first_b);
int N = nvals_first_s + 1;
global_net_startup_ns = malloc(N*N*sizeof(double));
global_net_bw_mbs = malloc(N*N*sizeof(double));
/* first fill in mat, then fill opposites */
fill_tri_mat(N, global_net_startup_ns, startup_tmp);
fill_tri_mat(N, global_net_bw_mbs, bw_tmp);
free(startup_tmp);
free(bw_tmp);
/* done */
/* report network statistics */
/* TODO: Do we have some simplewan statistics to report like we have for torus and dragonfly? */
return;
sw_state * ns,
tw_lp * lp)
uint32_t h1 = 0, h2 = 0;
memset(ns, 0, sizeof(*ns));
bj_hashlittle2("simplewan", strlen("simplewan"), &h1, &h2);
sw_magic = h1+h2;
/* printf("\n sw_magic %d ", sw_magic); */
/* inititalize logical ID */
ns->id = codes_mapping_get_lp_global_rel_id(lp->gid);
/* get the total number of simplewans */
if (num_lps == -1){
num_lps = codes_mapping_get_global_lp_count("modelnet_simplewan");
assert(num_lps > 0);
/* all devices are idle to begin with */
ns->send_next_idle = malloc(num_lps * sizeof(ns->send_next_idle));
ns->recv_next_idle = malloc(num_lps * sizeof(ns->recv_next_idle));
tw_stime st = tw_now(lp);
int i;
for (i = 0; i < num_lps; i++){
ns->send_next_idle[i] = st;
ns->recv_next_idle[i] = st;
for (i = 0; i < CATEGORY_MAX; i++){
ns->idle_times_cat[i].send_next_idle_all = 0.0;
ns->idle_times_cat[i].send_prev_idle_all = 0.0;
ns->idle_times_cat[i].recv_next_idle_all = 0.0;
ns->idle_times_cat[i].recv_prev_idle_all = 0.0;
ns->idle_times_cat[i].category[0] = '\0';
return;
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp)
assert(m->magic == sw_magic);
switch (m->event_type)
case MSG_START:
handle_msg_start_event(ns, b, m, lp);
break;
case MSG_READY:
handle_msg_ready_event(ns, b, m, lp);
break;
default:
assert(0);
break;
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp)
case MSG_START:
handle_msg_start_rev_event(ns, b, m, lp);
break;
case MSG_READY:
handle_msg_ready_rev_event(ns, b, m, lp);
break;
default:
assert(0);
break;
return;
sw_state * ns,
tw_lp * lp)
/* first need to add last known active-range times (they aren't added
* until afterwards) */
int i;
for (i = 0;
i < CATEGORY_MAX && strlen(ns->idle_times_cat[i].category) > 0;
i++){
category_idles *id = ns->idle_times_cat + i;
mn_stats *st = ns->sw_stats_array + i;
st->send_time += id->send_next_idle_all - id->send_prev_idle_all;
st->recv_time += id->recv_next_idle_all - id->recv_prev_idle_all;
model_net_print_stats(lp->gid, &ns->sw_stats_array[0]);
return;
int sw_get_magic()
return sw_magic;
/* convert MiB/s and bytes to ns */
tw_stime time;
/* bytes to MB */
time = ((double)bytes)/(1024.0*1024.0);
/* MB to s */
time = time / MB_p_s;
/* s to ns */
time = time * 1000.0 * 1000.0 * 1000.0;
return(time);
/* reverse computation for msg ready event */
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp)
struct mn_stats* stat;
category_idles * idles;
stat = model_net_find_stats(m->category, ns->sw_stats_array);
stat->recv_count--;
stat->recv_bytes -= m->net_msg_size_bytes;
stat->recv_time = m->recv_time_saved;
ns->recv_next_idle[m->src_mn_rel_id] = m->recv_next_idle_saved;
idles = sw_get_category_idles(m->category, ns->idle_times_cat);
idles->recv_next_idle_all = m->recv_next_idle_all_saved;
idles->recv_prev_idle_all = m->recv_prev_idle_all_saved;
return;
/* handler for msg ready event. This indicates that a message is available
* to recv, but we haven't checked to see if the recv queue is available yet
sw_state * ns,
tw_bf * b,
sw_message * m,
tw_lp * lp)
tw_stime recv_queue_time = 0;
tw_event *e_new;
sw_message *m_new;
/* get source->me network stats */
double bw = sw_get_bw(m->src_mn_rel_id, ns->id);
double startup = sw_get_startup(m->src_mn_rel_id, ns->id);
if (bw <= 0.0 || startup < 0.0){
fprintf(stderr,
"Invalid link from Rel. id %d to LP %lu (rel. id %d)\n",
m->src_mn_rel_id, lp->gid, ns->id);
abort();
/* are we available to recv the msg? */
/* were we available when the transmission was started? */
if(ns->recv_next_idle[m->src_mn_rel_id] > tw_now(lp))
recv_queue_time +=
ns->recv_next_idle[m->src_mn_rel_id] - tw_now(lp);
/* calculate transfer time based on msg size and bandwidth */
recv_queue_time += rate_to_ns(m->net_msg_size_bytes, bw);
/* bump up input queue idle time accordingly */
m->recv_next_idle_saved = ns->recv_next_idle[m->src_mn_rel_id];
ns->recv_next_idle[m->src_mn_rel_id] = recv_queue_time + tw_now(lp);
/* get stats, save state (TODO: smarter save state than param dump?) */
category_idles *idles =
