Commit 4047d77b authored by Misbah Mubarak's avatar Misbah Mubarak
Adding map based approach for intra-group search. Row/column computation may generate duplicates.
parent 8b491087
...@@ -2137,7 +2137,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des ...@@ -2137,7 +2137,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des
/* If no direct connection exists then find an intermediate connection */ /* If no direct connection exists then find an intermediate connection */
if(curMap.find(dest_rel_id) == curMap.end()) if(curMap.find(dest_rel_id) == curMap.end())
int src_col = src_rel_id % s->params->num_router_cols; /*int src_col = src_rel_id % s->params->num_router_cols;
int src_row = src_rel_id / s->params->num_router_cols; int src_row = src_rel_id / s->params->num_router_cols;
int dest_col = dest_rel_id % s->params->num_router_cols; int dest_col = dest_rel_id % s->params->num_router_cols;
...@@ -2147,7 +2147,24 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des ...@@ -2147,7 +2147,24 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des
int choice1 = src_row * s->params->num_router_cols + dest_col; int choice1 = src_row * s->params->num_router_cols + dest_col;
int choice2 = dest_row * s->params->num_router_cols + src_col; int choice2 = dest_row * s->params->num_router_cols + src_col;
intersection.push_back(offset + choice1); intersection.push_back(offset + choice1);
intersection.push_back(offset + choice2); intersection.push_back(offset + choice2);*/
map<int, vector<Link> > &destMap = intraGroupLinks[dest_rel_id];
map< int, vector<Link> >::iterator it_dest = destMap.begin();
while(it_src != curMap.end() && it_dest != destMap.end())
if(it_src->first < it_dest->first)
it_src++;
else
if(it_dest->first < it_src->first)
it_dest++;
else {
intersection.push_back(offset + it_src->first);
it_src++;
it_dest++;
else else
Markdown is supported
0%
or
Please register or to comment
