Commit 3b03ff6b authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
tweaked install instructions
parent 5896b5b0
NOTE: see bottom of this file for suggested configurations on particular ANL NOTE: see bottom of this file for suggested configurations on particular ANL
machines. machines.
0 - Checkout, build, and install the trunk version of ROSS 0 - Checkout, build, and install the trunk version of ROSS. At the time of
release (0.3.0), ROSS's latest commit hash was c04babe, so this revision is
"safe" in the unlikely case incompatible changes come along in the future.
git clone http://github.com/carothersc/ROSS.git git clone http://github.com/carothersc/ROSS.git
# optional: git checkout c04babe
cd ROSS cd ROSS
mkdir build mkdir build
cd build cd build
# note: other options for ARCH include i386 (for 32 bit machines), # note: other options for ARCH include i386 (for 32 bit machines),
# bgp, and bgq (for Blue Gene systems) # bgp, and bgq (for Blue Gene systems)
ARCH=x86_64 CC=mpicc CXX=mpicxx cmake -DCMAKE_INSTALL_PREFIX=../install ../ ARCH=x86_64 CC=mpicc CXX=mpicxx cmake -DCMAKE_INSTALL_PREFIX=../install ../
make -j 3 make -j 3
make install make install
...@@ -16,27 +19,30 @@ machines. ...@@ -16,27 +19,30 @@ machines.
<the result should be that the latest version of ROSS is installed in the <the result should be that the latest version of ROSS is installed in the
ROSS/install/ directory> ROSS/install/ directory>
1 - If this is the first time you are building codes-base, run 1 - If you are building codes-base directly from the repository, run
./prepare.sh ./prepare.sh
2- Configure codes-base. This can be done in the source directory or in a 2 - Configure codes-base. This can be done in the source directory or in a
dedicated build directory if you prefer out-of-tree builds. The CC dedicated build directory if you prefer out-of-tree builds. The CC
environment variable must refer to an MPI compiler. environment variable must refer to an MPI compiler.
./configure --with-ross=/path/to/ross/install --prefix=/path/to/codes-base/install CC=mpicc mkdir build
cd build
../configure --with-ross=/path/to/ross/install --prefix=/path/to/codes-base/install CC=mpicc
3 - Build codes-base 3 - Build and install codes-base
make clean && make && make install && make tests make && make install
4 - (optional) run test programs 4 - (optional) run test programs
make check make tests && make check
5 - codes-base uses flex and bison (or lex and yacc) to generate several parsers. 5 - codes-base uses flex and bison (or lex and yacc) to generate several
These tools auto-generate C source files. To remove all of the autogenerated parsers. These tools auto-generate C source files. To get around versioning
files for these parsers, execute issues, we've distributed the auto-generated sources directly. To remove
all of the autogenerated files for these parsers, execute
make maintainer-clean-local make maintainer-clean-local
Markdown is supported
0% or .
Please register or to comment
