Commit 33e9acd8 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Dragonfly Plus Script: Update Usage Docs
parent 158ad33c
...@@ -4,7 +4,7 @@ ...@@ -4,7 +4,7 @@
# In hindsight this was a lot more complicated than I intended. It was looking to solve a complex problem that turned out to be invalid from the beginning. # In hindsight this was a lot more complicated than I intended. It was looking to solve a complex problem that turned out to be invalid from the beginning.
### USAGE ### ### USAGE ###
# Correct usage: python3 script.py <num_groups> <num_spine_pg> <num_leaf_pg> <router_radix> <intra-file> <inter-file> # Correct usage: python3 script.py <num_groups> <num_spine_pg> <num_leaf_pg> <router_radix> <num_terminal_per_leaf> <intra-file> <inter-file>
import sys import sys
Markdown is supported
0% or .
Please register or to comment
