Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
2ecbc4bf
Commit
2ecbc4bf
authored
Aug 01, 2014
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Added new example program showing new codes features
parent
f1bd727f
Changes
4
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
4 changed files
with
552 additions
and
0 deletions
+552
-0
doc/example_heterogeneous/Makefile
+20
-0
doc/example_heterogeneous/README
+14
-0
doc/example_heterogeneous/example.c
+461
-0
doc/example_heterogeneous/example.conf
+57
-0
No files found.
0 → 100644
View file @
2ecbc4bf
ifndef
CODESBASE
$(error
CODESBASE
is
undefined,
see
README.txt)
endif
ifndef
CODESNET
$(error
CODESNET
is
undefined,
see
README.txt)
endif
ifndef
ROSS
$(error
ROSS
is
undefined,
see
README.txt)
endif
# ross conflates CFLAGS with CPPFLAGS, so use just this one
override
CPPFLAGS
shell
$(ROSS)
/bin/ross-config
--cflags
-I
$(CODESBASE)
/include
-I
$(CODESNET)
/include/codes
CC
shell
$(ROSS)
/bin/ross-config
--cc
LDFLAGS
shell
$(ROSS)
/bin/ross-config
--ldflags
-L
$(CODESBASE)
/lib
-L
$(CODESNET)
/lib
LDLIBS
shell
$(ROSS)
/bin/ross-config
--libs
-lcodes-net
-lcodes-base
example
example.c
clean
rm
-f
example
0 → 100644
View file @
2ecbc4bf
This example program shows some features enabled by the new annotation-based
configuration and mapping APIs in codes-base, as well as support for them in
codes-net. The example does not exhaustively show all new features added - for
more details, see configuration.h, codes-mapping.h, and model-net.h in
codes-net.
Specifically, some features shown are:
* Use of annotated configuration to initialize three separate network models.
Note that they are all the same network model, just with different
parameterizations. This includes both the configuration file itself as well as
interaction in the code between components with different annotations.
* Addressing at various levels in both LP type-specific namespaces and
model-net namespaces (network id, annotation tuples).
* The updated registration/configuration sequence in main.
0 → 100644
View file @
2ecbc4bf
This diff is collapsed.
0 → 100644
View file @
2ecbc4bf
LPGROUPS
## cluster foo
FOO_CLUSTER
repetitions
"12"
node
"1"
modelnet_simplenet
foo
"1"
FOO_FORWARDERS
repetitions
"4"
forwarder
"1"
modelnet_simplenet
foo
"1"
modelnet_simplenet
"1"
## cluster bar
BAR_CLUSTER
repetitions
"12"
node
"1"
modelnet_simplenet
bar
"1"
BAR_FORWARDERS
repetitions
"4"
forwarder
"1"
modelnet_simplenet
bar
"1"
modelnet_simplenet
"1"
PARAMS
## ROSS parameters
message_size
"256"
## global modelnet parameters
modelnet_order
"simplenet"
## foo cluster network parameters
packet_size
foo
"8192"
modelnet_scheduler
foo
"fcfs"
net_startup_ns
foo
"1.5"
net_bw_mbps
foo
"10000"
## bar cluster network parameters
packet_size
bar
"2048"
modelnet_scheduler
bar
"round-robin"
net_startup_ns
bar
"3.0"
net_bw_mbps
bar
"15000"
## forwarding network parameters
packet_size
"4096"
modelnet_scheduler
"fcfs"
net_startup_ns
"8.0"
net_bw_mbps
"5000"
run_params
num_reqs
"5"
payload_sz
"16384"
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
