Commit 2ba8b69d authored by Philip Carns's avatar Philip Carns
Browse files
report full output from mpptest
- also tweak temporary hard-coded network parameters in loggp method to
  look somewhat like Tukey IB network for quick sanity checking of
  output
parent e53237db
...@@ -58,9 +58,9 @@ struct loggp_message ...@@ -58,9 +58,9 @@ struct loggp_message
* replace with real loggp parameters. * replace with real loggp parameters.
/* net startup cost, ns */ /* net startup cost, ns */
static double global_net_startup_ns = 5; static double global_net_startup_ns = 2000;
/* net bw, MB/s */ /* net bw, MB/s */
static double global_net_bw_mbs = 100; static double global_net_bw_mbs = 2000;
static int loggp_magic = 0; static int loggp_magic = 0;
...@@ -9,7 +9,9 @@ ...@@ -9,7 +9,9 @@
* This test program will execute a one way, point to point bandwidth test * This test program will execute a one way, point to point bandwidth test
* between two hosts using the specified modelnet method. The intention is * between two hosts using the specified modelnet method. The intention is
* to roughly mimic the behavior of a standard bandwidth test such as * to roughly mimic the behavior of a standard bandwidth test such as
* mpptest. * mpptest. Output is presented in the same format as the default mpptest
* parameters with two nodes, testing a range of sizes from 4 bytes to 64
* MiB.
#include <string.h> #include <string.h>
...@@ -93,9 +95,7 @@ tw_lptype svr_lp = { ...@@ -93,9 +95,7 @@ tw_lptype svr_lp = {
extern const tw_lptype* svr_get_lp_type(); extern const tw_lptype* svr_get_lp_type();
static void svr_add_lp_type(); static void svr_add_lp_type();
#if 0
static tw_stime ns_to_s(tw_stime ns); static tw_stime ns_to_s(tw_stime ns);
#endif
static tw_stime s_to_ns(tw_stime ns); static tw_stime s_to_ns(tw_stime ns);
static void handle_pong_event( static void handle_pong_event(
svr_state * ns, svr_state * ns,
...@@ -264,17 +264,37 @@ static void svr_finalize( ...@@ -264,17 +264,37 @@ static void svr_finalize(
tw_lp * lp) tw_lp * lp)
/* TODO: print results on server 0 */ int i;
double avg_time_us;
double rate_b_s;
double elapsed_s;
if(ns->svr_idx != 0)
return;
printf("#p0\tp1\tdist\tlen\tave time (us)\trate\n");
for(i=0; i<NUM_SZS; i++)
avg_time_us = stat_array[i].end_time - stat_array[i].start_time;
avg_time_us /= 1000.0; /* ns to us */
avg_time_us /= (double)NUM_PINGPONGS; /* avg */
avg_time_us /= 2.0; /* divide by 2, to replicate scaling factor as in mpptest */
/* rate is reported in bytes/s */
elapsed_s = ns_to_s(stat_array[i].end_time - stat_array[i].start_time);
rate_b_s = (double)stat_array[i].msg_sz * (double)NUM_PINGPONGS * 2.0;
rate_b_s /= elapsed_s;
printf("0\t1\t1\t%d\t%f\t%e\n", stat_array[i].msg_sz, avg_time_us, rate_b_s);
return; return;
#if 0
/* convert ns to seconds */ /* convert ns to seconds */
static tw_stime ns_to_s(tw_stime ns) static tw_stime ns_to_s(tw_stime ns)
return(ns / (1000.0 * 1000.0 * 1000.0)); return(ns / (1000.0 * 1000.0 * 1000.0));
#endif
/* convert seconds to ns */ /* convert seconds to ns */
static tw_stime s_to_ns(tw_stime ns) static tw_stime s_to_ns(tw_stime ns)
...@@ -338,7 +358,7 @@ static void handle_pong_event( ...@@ -338,7 +358,7 @@ static void handle_pong_event(
if(msg_sz_idx < NUM_SZS) if(msg_sz_idx < NUM_SZS)
stat_array[msg_sz_idx].start_time = tw_now(lp); stat_array[msg_sz_idx].start_time = tw_now(lp);
if(msg_sz_idx > 0) if(msg_sz_idx > 0)
stat_array[msg_sz_idx].end_time = tw_now(lp); stat_array[msg_sz_idx-1].end_time = tw_now(lp);
if(msg_sz_idx >= NUM_SZS) if(msg_sz_idx >= NUM_SZS)
Markdown is supported
0% or .
Please register or to comment
