Commit 2756fd6f authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Some bug fixes to mpi sim layer
parent cfe0d6f4
...@@ -2,9 +2,9 @@ LPGROUPS ...@@ -2,9 +2,9 @@ LPGROUPS
MODELNET_GRP MODELNET_GRP
repetitions="114"; repetitions="36";
nw-lp="3"; nw-lp="2";
modelnet_dragonfly="3"; modelnet_dragonfly="2";
dragonfly_router="1"; dragonfly_router="1";
...@@ -17,7 +17,7 @@ PARAMS ...@@ -17,7 +17,7 @@ PARAMS
chunk_size="512"; chunk_size="512";
# modelnet_scheduler="round-robin"; # modelnet_scheduler="round-robin";
num_vcs="1"; num_vcs="1";
num_routers="6"; num_routers="4";
local_vc_size="32768"; local_vc_size="32768";
global_vc_size="65536"; global_vc_size="65536";
cn_vc_size="32768"; cn_vc_size="32768";
...@@ -25,5 +25,5 @@ PARAMS ...@@ -25,5 +25,5 @@ PARAMS
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="544"; message_size="544";
routing="adaptive"; routing="minimal";
...@@ -13,7 +13,7 @@ ...@@ -13,7 +13,7 @@
#include "codes/model-net.h" #include "codes/model-net.h"
#include "codes/rc-stack.h" #include "codes/rc-stack.h"
#define TRACE 0 #define TRACE -1
#define TRACK 0 #define TRACK 0
char workload_type[128]; char workload_type[128];
...@@ -822,14 +822,8 @@ static void codes_exec_comp_delay( ...@@ -822,14 +822,8 @@ static void codes_exec_comp_delay(
tw_stime ts; tw_stime ts;
nw_message* msg; nw_message* msg;
if (disable_delay) { s->compute_time += s_to_ns(mpi_op->u.delay.seconds);
ts = 0.0; // no compute time sim ts = s_to_ns(mpi_op->u.delay.seconds);
else {
ts += g_tw_lookahead + 0.1 + tw_rand_exponential(lp->rng, noise); ts += g_tw_lookahead + 0.1 + tw_rand_exponential(lp->rng, noise);
e = tw_event_new( lp->gid, ts , lp ); e = tw_event_new( lp->gid, ts , lp );
...@@ -1200,10 +1194,10 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t ...@@ -1200,10 +1194,10 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t
case CODES_WK_DELAY: case CODES_WK_DELAY:
s->num_delays--; s->num_delays--;
if (!disable_delay) { tw_rand_reverse_unif(lp->rng);
s->compute_time -= s_to_ns(mpi_op->u.delay.seconds); if (!disable_delay)
} s->compute_time -= s_to_ns(mpi_op->u.delay.seconds);
break; break;
case CODES_WK_BCAST: case CODES_WK_BCAST:
...@@ -1256,9 +1250,8 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1256,9 +1250,8 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
s->nw_id, s->num_completed); s->nw_id, s->num_completed);
m->u.rc.saved_op = mpi_op; m->u.rc.saved_op = mpi_op;
if(mpi_op->op_type == CODES_WK_END && s->num_completed == 50000) if(mpi_op->op_type == CODES_WK_END)
//rc_stack_push(lp, mpi_op, free, s->st);
s->elapsed_time = tw_now(lp) - s->start_time; s->elapsed_time = tw_now(lp) - s->start_time;
return; return;
...@@ -1283,7 +1276,10 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1283,7 +1276,10 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
s->num_delays++; s->num_delays++;
codes_exec_comp_delay(s, lp, mpi_op); if(!disable_delay)
else
codes_issue_next_event(lp);
break; break;
...@@ -1295,13 +1291,19 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1295,13 +1291,19 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
case CODES_WK_REDUCE: case CODES_WK_REDUCE:
case CODES_WK_ALLREDUCE: case CODES_WK_ALLREDUCE:
case CODES_WK_COL: case CODES_WK_COL:
case CODES_WK_WAITSOME:
case CODES_WK_WAITANY:
s->num_cols++; s->num_cols++;
codes_exec_mpi_col(s, lp); codes_exec_mpi_col(s, lp);
break; break;
s->num_waitsome++;
break;
case CODES_WK_WAIT: case CODES_WK_WAIT:
s->num_wait++; s->num_wait++;
...@@ -1311,10 +1311,10 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1311,10 +1311,10 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
total_msg_sz -= msg->total_size; total_msg_sz -= msg->total_size;
N_finished_msgs--; N_finished_msgs--;
stat->recv_time -= msg->saved_start_time; stat->recv_time = msg->saved_start_time;
s->total_msg_time -= msg->saved_start_time; s->total_msg_time = msg->saved_start_time;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
dragonfly_total_time -= msg->saved_avg_time; dragonfly_total_time = msg->saved_avg_time;
struct dfly_qhash_entry * d_entry_pop = (struct dfly_qhash_entry*)rc_stack_pop(s->st); struct dfly_qhash_entry * d_entry_pop = (struct dfly_qhash_entry*)rc_stack_pop(s->st);
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
...@@ -1532,14 +1532,17 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1532,14 +1532,17 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
N_finished_msgs++; N_finished_msgs++;
total_msg_sz += msg->total_size; total_msg_sz += msg->total_size;
msg->saved_avg_time = tw_now( lp ) - msg->travel_start_time; msg->saved_avg_time = dragonfly_total_time;
dragonfly_total_time += msg->saved_avg_time; dragonfly_total_time += tw_now( lp ) - msg->travel_start_time;
msg->saved_start_time = (tw_now(lp) - msg->msg_start_time);
stat->recv_time += msg->saved_start_time; msg->saved_start_time = s->total_msg_time;
s->finished_msgs++; stat->recv_time += (tw_now(lp) - msg->msg_start_time);
s->total_msg_time += msg->saved_start_time;
s->total_msg_time += (tw_now(lp) - msg->msg_start_time);
s->total_msg_size += msg->total_size; s->total_msg_size += msg->total_size;
s->finished_msgs++;
if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) { if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) {
bf->c3 = 1; bf->c3 = 1;
msg->saved_available_time = dragonfly_max_latency; msg->saved_available_time = dragonfly_max_latency;
Markdown is supported
0% or .
Please register or to comment
