Commit 213897b2 authored by Misbah Mubarak's avatar Misbah Mubarak
Updating readme for python scripts
parent 1f3adff1
...@@ -19,4 +19,5 @@ configuration file (Example in config_alloc-upd) will then look like: ...@@ -19,4 +19,5 @@ configuration file (Example in config_alloc-upd) will then look like:
1st line: allocation policy, must be rand 1st line: allocation policy, must be rand
2nd line: the total terminal number of nodes in the system 2nd line: the total terminal number of nodes in the system
3rd line: the number of random allocations to generate 3rd line: the number of random allocations to generate
4th line: number of ranks for each application.] 4th line: the number of cores per node
5th line: number of ranks for each application.]
Markdown is supported
0%
or
Please register or to comment
