Commit 1df69451 authored by Philip Carns's avatar Philip Carns
codeslexer.h is generated
automake rules could probably be cleaner, just getting it to
build/install for now
parent 40ad2ec9
#ifndef CodesIOKernel_HEADER_H
#define CodesIOKernel_HEADER_H 1
#define CodesIOKernel_IN_HEADER 1
#line 6 "src/iokernellang/codeslexer.h"
#line 8 "src/iokernellang/codeslexer.h"
#define YY_INT_ALIGNED short int
/* A lexical scanner generated by flex */
#define FLEX_SCANNER
#define YY_FLEX_MAJOR_VERSION 2
#define YY_FLEX_MINOR_VERSION 5
#define YY_FLEX_SUBMINOR_VERSION 35
#if YY_FLEX_SUBMINOR_VERSION > 0
#define FLEX_BETA
#endif
/* First, we deal with platform-specific or compiler-specific issues. */
/* begin standard C headers. */
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <stdlib.h>
/* end standard C headers. */
/* flex integer type definitions */
#ifndef FLEXINT_H
#define FLEXINT_H
/* C99 systems have <inttypes.h>. Non-C99 systems may or may not. */
#if defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L
/* C99 says to define __STDC_LIMIT_MACROS before including stdint.h,
* if you want the limit (max/min) macros for int types.
#ifndef __STDC_LIMIT_MACROS
#define __STDC_LIMIT_MACROS 1
#endif
#include <inttypes.h>
typedef int8_t flex_int8_t;
typedef uint8_t flex_uint8_t;
typedef int16_t flex_int16_t;
typedef uint16_t flex_uint16_t;
typedef int32_t flex_int32_t;
typedef uint32_t flex_uint32_t;
#else
typedef signed char flex_int8_t;
typedef short int flex_int16_t;
typedef int flex_int32_t;
typedef unsigned char flex_uint8_t;
typedef unsigned short int flex_uint16_t;
typedef unsigned int flex_uint32_t;
/* Limits of integral types. */
#ifndef INT8_MIN
#define INT8_MIN (-128)
#endif
#ifndef INT16_MIN
#define INT16_MIN (-32767-1)
#endif
#ifndef INT32_MIN
#define INT32_MIN (-2147483647-1)
#endif
#ifndef INT8_MAX
#define INT8_MAX (127)
#endif
#ifndef INT16_MAX
#define INT16_MAX (32767)
#endif
#ifndef INT32_MAX
#define INT32_MAX (2147483647)
#endif
#ifndef UINT8_MAX
#define UINT8_MAX (255U)
#endif
#ifndef UINT16_MAX
#define UINT16_MAX (65535U)
#endif
#ifndef UINT32_MAX
#define UINT32_MAX (4294967295U)
#endif
#endif /* ! C99 */
#endif /* ! FLEXINT_H */
#ifdef __cplusplus
/* The "const" storage-class-modifier is valid. */
#define YY_USE_CONST
#else /* ! __cplusplus */
/* C99 requires __STDC__ to be defined as 1. */
#if defined (__STDC__)
#endif /* defined (__STDC__) */
#endif /* ! __cplusplus */
#ifdef YY_USE_CONST
#define yyconst const
#else
#define yyconst
#endif
/* An opaque pointer. */
#ifndef YY_TYPEDEF_YY_SCANNER_T
#define YY_TYPEDEF_YY_SCANNER_T
typedef void* yyscan_t;
#endif
/* For convenience, these vars (plus the bison vars far below)
are macros in the reentrant scanner. */
#define yyin yyg->yyin_r
#define yyout yyg->yyout_r
#define yyextra yyg->yyextra_r
#define yyleng yyg->yyleng_r
#define yytext yyg->yytext_r
#define yylineno (YY_CURRENT_BUFFER_LVALUE->yy_bs_lineno)
#define yycolumn (YY_CURRENT_BUFFER_LVALUE->yy_bs_column)
#define yy_flex_debug yyg->yy_flex_debug_r
/* Size of default input buffer. */
#ifndef YY_BUF_SIZE
#ifdef __ia64__
/* On IA-64, the buffer size is 16k, not 8k.
* Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
* Ditto for the __ia64__ case accordingly.
#define YY_BUF_SIZE 32768
#else
#define YY_BUF_SIZE 16384
#endif /* __ia64__ */
#endif
#ifndef YY_TYPEDEF_YY_BUFFER_STATE
#define YY_TYPEDEF_YY_BUFFER_STATE
typedef struct yy_buffer_state *YY_BUFFER_STATE;
#endif
#ifndef YY_TYPEDEF_YY_SIZE_T
#define YY_TYPEDEF_YY_SIZE_T
typedef size_t yy_size_t;
#endif
#ifndef YY_STRUCT_YY_BUFFER_STATE
#define YY_STRUCT_YY_BUFFER_STATE
FILE *yy_input_file;
char *yy_ch_buf; /* input buffer */
char *yy_buf_pos; /* current position in input buffer */
/* Size of input buffer in bytes, not including room for EOB
* characters.
yy_size_t yy_buf_size;
/* Number of characters read into yy_ch_buf, not including EOB
* characters.
int yy_n_chars;
/* Whether we "own" the buffer - i.e., we know we created it,
* and can realloc() it to grow it, and should free() it to
* delete it.
int yy_is_our_buffer;
/* Whether this is an "interactive" input source; if so, and
* if we're using stdio for input, then we want to use getc()
* instead of fread(), to make sure we stop fetching input after
* each newline.
int yy_is_interactive;
/* Whether we're considered to be at the beginning of a line.
* If so, '^' rules will be active on the next match, otherwise
* not.
int yy_at_bol;
int yy_bs_lineno; /**< The line count. */
int yy_bs_column; /**< The column count. */
/* Whether to try to fill the input buffer when we reach the
* end of it.
int yy_fill_buffer;
int yy_buffer_status;
#endif /* !YY_STRUCT_YY_BUFFER_STATE */
void CodesIOKernel_restart (FILE *input_file ,yyscan_t yyscanner );
void CodesIOKernel__switch_to_buffer (YY_BUFFER_STATE new_buffer ,yyscan_t yyscanner );
YY_BUFFER_STATE CodesIOKernel__create_buffer (FILE *file,int size ,yyscan_t yyscanner );
void CodesIOKernel__delete_buffer (YY_BUFFER_STATE b ,yyscan_t yyscanner );
void CodesIOKernel__flush_buffer (YY_BUFFER_STATE b ,yyscan_t yyscanner );
void CodesIOKernel_push_buffer_state (YY_BUFFER_STATE new_buffer ,yyscan_t yyscanner );
void CodesIOKernel_pop_buffer_state (yyscan_t yyscanner );
YY_BUFFER_STATE CodesIOKernel__scan_buffer (char *base,yy_size_t size ,yyscan_t yyscanner );
YY_BUFFER_STATE CodesIOKernel__scan_string (yyconst char *yy_str ,yyscan_t yyscanner );
YY_BUFFER_STATE CodesIOKernel__scan_bytes (yyconst char *bytes,int len ,yyscan_t yyscanner );
void *CodesIOKernel_alloc (yy_size_t ,yyscan_t yyscanner );
void *CodesIOKernel_realloc (void *,yy_size_t ,yyscan_t yyscanner );
void CodesIOKernel_free (void * ,yyscan_t yyscanner );
/* Begin user sect3 */
#define CodesIOKernel_wrap(n) 1
#define YY_SKIP_YYWRAP
#define yytext_ptr yytext_r
#ifdef YY_HEADER_EXPORT_START_CONDITIONS
#define INITIAL 0
#endif
#ifndef YY_NO_UNISTD_H
/* Special case for "unistd.h", since it is non-ANSI. We include it way
* down here because we want the user's section 1 to have been scanned first.
* The user has a chance to override it with an option.
#include <unistd.h>
#endif
#ifndef YY_EXTRA_TYPE
#define YY_EXTRA_TYPE void *
#endif
int CodesIOKernel_lex_init (yyscan_t* scanner);
int CodesIOKernel_lex_init_extra (YY_EXTRA_TYPE user_defined,yyscan_t* scanner);
/* Accessor methods to globals.
These are made visible to non-reentrant scanners for convenience. */
int CodesIOKernel_lex_destroy (yyscan_t yyscanner );
int CodesIOKernel_get_debug (yyscan_t yyscanner );
void CodesIOKernel_set_debug (int debug_flag ,yyscan_t yyscanner );
YY_EXTRA_TYPE CodesIOKernel_get_extra (yyscan_t yyscanner );
void CodesIOKernel_set_extra (YY_EXTRA_TYPE user_defined ,yyscan_t yyscanner );
FILE *CodesIOKernel_get_in (yyscan_t yyscanner );
void CodesIOKernel_set_in (FILE * in_str ,yyscan_t yyscanner );
FILE *CodesIOKernel_get_out (yyscan_t yyscanner );
void CodesIOKernel_set_out (FILE * out_str ,yyscan_t yyscanner );
int CodesIOKernel_get_leng (yyscan_t yyscanner );
char *CodesIOKernel_get_text (yyscan_t yyscanner );
int CodesIOKernel_get_lineno (yyscan_t yyscanner );
void CodesIOKernel_set_lineno (int line_number ,yyscan_t yyscanner );
YYSTYPE * CodesIOKernel_get_lval (yyscan_t yyscanner );
void CodesIOKernel_set_lval (YYSTYPE * yylval_param ,yyscan_t yyscanner );
YYLTYPE *CodesIOKernel_get_lloc (yyscan_t yyscanner );
void CodesIOKernel_set_lloc (YYLTYPE * yylloc_param ,yyscan_t yyscanner );
/* Macros after this point can all be overridden by user definitions in
* section 1.
#ifndef YY_SKIP_YYWRAP
#ifdef __cplusplus
extern "C" int CodesIOKernel_wrap (yyscan_t yyscanner );
#else
extern int CodesIOKernel_wrap (yyscan_t yyscanner );
#endif
#endif
#ifndef yytext_ptr
static void yy_flex_strncpy (char *,yyconst char *,int ,yyscan_t yyscanner);
#endif
#ifdef YY_NEED_STRLEN
static int yy_flex_strlen (yyconst char * ,yyscan_t yyscanner);
#endif
#ifndef YY_NO_INPUT
#endif
/* Amount of stuff to slurp up with each read. */
#ifndef YY_READ_BUF_SIZE
#ifdef __ia64__
/* On IA-64, the buffer size is 16k, not 8k */
#define YY_READ_BUF_SIZE 16384
#else
#define YY_READ_BUF_SIZE 8192
#endif
/* Number of entries by which start-condition stack grows. */
#ifndef YY_START_STACK_INCR
#define YY_START_STACK_INCR 25
#endif
/* Default declaration of generated scanner - a define so the user can
* easily add parameters.
#ifndef YY_DECL
#define YY_DECL_IS_OURS 1
extern int CodesIOKernel_lex \
(YYSTYPE * yylval_param,YYLTYPE * yylloc_param ,yyscan_t yyscanner);
#define YY_DECL int CodesIOKernel_lex \
(YYSTYPE * yylval_param, YYLTYPE * yylloc_param , yyscan_t yyscanner)
#endif /* !YY_DECL */
/* yy_get_previous_state - get the state just before the EOB char was reached */
#undef YY_NEW_FILE
#undef YY_FLUSH_BUFFER
#undef yy_set_bol
#undef yy_new_buffer
#undef yy_set_interactive
#undef YY_DO_BEFORE_ACTION
#ifdef YY_DECL_IS_OURS
#undef YY_DECL_IS_OURS
#undef YY_DECL
#endif
#line 111 "src/iokernellang/codeslexer.l"
#line 358 "src/iokernellang/codeslexer.h"
#undef CodesIOKernel_IN_HEADER
#endif /* CodesIOKernel_HEADER_H */
...@@ -17,6 +17,7 @@ maintainer-clean-local:: ...@@ -17,6 +17,7 @@ maintainer-clean-local::
-rm -f src/iokernellang/codesparser.y -rm -f src/iokernellang/codesparser.y
-rm -f src/iokernellang/codeslexer.c -rm -f src/iokernellang/codeslexer.c
-rm -f src/iokernellang/codeslexer.h -rm -f src/iokernellang/codeslexer.h
-rm -f codes/codeslexer.h
-rm -f src/modelconfig/configlex.h -rm -f src/modelconfig/configlex.h
-rm -f src/modelconfig/configlex.c -rm -f src/modelconfig/configlex.c
-rm -f src/modelconfig/configparser.h -rm -f src/modelconfig/configparser.h
...@@ -28,12 +29,17 @@ src/modelconfig/configlex.h: src/modelconfig/configlex.l ...@@ -28,12 +29,17 @@ src/modelconfig/configlex.h: src/modelconfig/configlex.l
BUILT_SOURCES += src/iokernellang/codesparser.h \ BUILT_SOURCES += src/iokernellang/codesparser.h \
src/iokernellang/codesparser.c \ src/iokernellang/codesparser.c \
src/iokernellang/codeslexer.h src/iokernellang/codeslexer.h \
codes/codeslexer.h
#src/iokernellang/codesparser.y: src/iokernellang/codesparser.y.in Makefile #src/iokernellang/codesparser.y: src/iokernellang/codesparser.y.in Makefile
src/iokernellang/codesparser.c src/iokernellang/codesparser.h: src/iokernellang/codesparser.y src/iokernellang/codesparser.c src/iokernellang/codesparser.h: src/iokernellang/codesparser.y
codes/codeslexer.h: src/iokernellang/codeslexer.h
mkdir -p codes
cp src/iokernellang/codeslexer.h codes/codeslexer.h
EXTRA_DIST += src/iokernellang/codesparser.y EXTRA_DIST += src/iokernellang/codesparser.y
nobase_include_HEADERS = \ nobase_include_HEADERS = \
Markdown is supported
0%
or
Please register or to comment
