Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
1d46dc5d
Commit
1d46dc5d
authored
Aug 10, 2015
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'map-context-api'
parents
e2c478a9
ee48256f
Changes
14
Expand all
Show whitespace changes
Inline
Side-by-side
Showing
14 changed files
with
675 additions
and
567 deletions
+675
-567
codes/codes-callback.h
+17
-0
codes/codes-mapping-context.h
+109
-0
codes/local-storage-model.h
+25
-46
codes/resource-lp.h
codes/resource-lp.h
+30
-41
src/Makefile.subdir
src/Makefile.subdir
+3
-1
src/util/codes-mapping-context.c
+151
-0
src/util/local-storage-model.c
+47
-155
src/util/resource-lp.c
+92
-196
tests/Makefile.subdir
+9
-2
tests/conf/map-ctx-test.conf
+16
-0
tests/local-storage-model-test.c
+41
-111
tests/map-ctx-test.c
+110
-0
tests/map-ctx-test.sh
+8
-0
tests/resource-test.c
+17
-15
No files found.
View file @
1d46dc5d
@@ -52,6 +52,23 @@ struct codes_cb_params {
(_cb_info_ptr)->cb_ret_offset = offsetof(_event_type, _cb_ret_field); \
} while (0)
#define CB_HO(_cb_params_ptr) ((_cb_params_ptr)->info.header_offset)
#define CB_TO(_cb_params_ptr) ((_cb_params_ptr)->info.tag_offset)
#define CB_RO(_cb_params_ptr) ((_cb_params_ptr)->info.cb_ret_offset)
/* Declare return variables at the right byte offsets from a codes_cb_params.
* Additionally, set the header and tag vars */
#define GET_INIT_CB_PTRS(_cb_params_ptr, _data_ptr, _sender_gid_val, _header_nm, _tag_nm, _rtn_name, _rtn_type) \
msg_header * _header_nm = \
(msg_header*)((char*)(_data_ptr) + CB_HO(_cb_params_ptr)); \
int * _tag_nm = \
(int*)((char*)(_data_ptr) + CB_TO(_cb_params_ptr));\
_rtn_type * _rtn_name = \
(_rtn_type*)((char*)(_data_ptr) + CB_RO(_cb_params_ptr)); \
msg_set_header((_cb_params_ptr)->h.magic, (_cb_params_ptr)->h.event_type, \
_sender_gid_val, _header_nm); \
*_tag_nm = (_cb_params_ptr)->tag
#define SANITY_CHECK_CB(_cb_info_ptr, _ret_type) \
do { \
int _total_size = sizeof(_ret_type) + sizeof(int) + sizeof(msg_header);\
0 → 100644
View file @
1d46dc5d
* Copyright (C) 2015 University of Chicago.
* See COPYRIGHT notice in top-level directory.
/* SUMMARY - data structure and utilities to direct LP mappings. As opposed to
* the codes-mapping API, this defines metadata necessary to allow implicit
* mappings based on LP type and configuration specification
* (see modelnet, LSM, etc)
* mctx stands for mapping context */
#ifndef CODES_MAPPING_CONTEXT_H
#define CODES_MAPPING_CONTEXT_H
#include <stdbool.h>
#include <ross.h>
/* for convenience - an annotation-ignoring "group_modulo" context,
* matching previous mapping behavior in most interfaces (modelnet and such) */
extern
struct
codes_mctx
const
const
CODES_MCTX_DEFAULT
/* types of map contexts */
enum
codes_mctx_type
// instructs those using the context to map directly to an LP
CODES_MCTX_GLOBAL_DIRECT
// instructs those using the context to map into the same group/repetition
// and compute the callee offset as the modulus of the caller offset and
// the number of callees in the group, to provide simple wraparound
// behaviour
CODES_MCTX_GROUP_MODULO
// and directly to a callee offset
CODES_MCTX_GROUP_DIRECT
// unknown/uninitialized context
CODES_MCTX_UNKNOWN
/* defines whether to specialize by destination annotation, and if so, which
* one.
* NOTE: this structure does not "own" the annotation, and makes no attempt to
* clean it up. */
struct
codes_mctx_annotation
char
const
annotation
bool
ignore_annotations
/* parameters for each mapping context type */
struct
codes_mctx_global_direct
tw_lpid
lpid
struct
codes_mctx_group_modulo
struct
anno
struct
codes_mctx_group_direct
struct
anno
int
offset
struct
codes_mctx
enum
codes_mctx_type
type
union
struct
global_direct
struct
group_modulo
struct
group_direct
u
/* simple setter functions */
struct
codes_mctx
codes_mctx_set_global_direct
tw_lpid
lpid
struct
codes_mctx
codes_mctx_set_group_modulo
char
const
annotation
bool
ignore_annotations
struct
codes_mctx
codes_mctx_set_group_direct
int
offset
char
const
annotation
bool
ignore_annotations
/* helper function to do a codes mapping - this function is subject to change
* based on what types of ctx exist
* NOTE: in GLOBAL_DIRECT mode, dest_lp_name and sender_gid are ignored */
tw_lpid
codes_mctx_to_lpid
struct
codes_mctx
const
ctx
char
const
dest_lp_name
tw_lpid
sender_gid
/* helper function to extract which annotation a various map context maps to.
* annotation is allocated or NULL if unused */
char
const
codes_mctx_get_annotation
struct
codes_mctx
const
ctx
char
const
dest_lp_name
tw_lpid
sender_id
#endif
/* end of include guard: CODES_MAPPING_CONTEXT_H */
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* indent-tabs-mode: nil
* End:
* vim: ts=8 sts=4 sw=4 expandtab
View file @
1d46dc5d
@@ -9,6 +9,9 @@
#include <ross.h>
#include "codes-callback.h"
#include "codes-mapping-context.h"
#define LSM_NAME "lsm"
/* HACK: problems arise when some LP sends multiple messages as part of an
@@ -38,73 +41,58 @@ typedef enum lsm_event_e
LSM_READ_COMPLETION
4
lsm_event_t
* return type for lsm events (in the codes-callback sense)
typedef
struct
int
rc
lsm_return_t
* Prototypes
/* given LP sender, find the LSM device LP in the same group */
tw_lpid
lsm_find_local_device
const
char
annotation
int
ignore_annotations
struct
codes_mctx
const
map_ctx
tw_lpid
sender_gid
* lsm_
event_new
* lsm_
io_event
* - creates a new event that is targeted for the corresponding
* LSM LP.
* - this event will allow wrapping the callers completion event
category: string name to identify the traffic category
- dest_gid: the gid to send the callers event t
o
lp_io_category: string name to identify the traffic category for use in
lp-i
o
* - gid_offset: relative offset of the LSM LP to the originating LP
* - io_object: id of byte stream the caller will modify
* - io_offset: offset into byte stream
* - io_size_bytes: size in bytes of IO request
* - io_type: read or write request
* - message_bytes: size of the event message the caller will have
* - sender: id of the sender
tw_event
lsm_event_new
const
char
category
tw_lpid
dest_gid
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
/* equivalent to lsm_event_new, except it allows to specify an annotation to
* filter by. If ignore_annotations is nonzero, A null annotation parameter
* indicates that the lsm LP to issue to has no annotation */
tw_event
lsm_event_new_annotated
const
char
category
tw_lpid
dest_gid
void
lsm_io_event
const
char
lp_io_category
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
const
char
annotation
int
ignore_annotations
void
lsm_event_new_reverse
tw_lp
sender
* lsm_event_data
* - returns the pointer to the message data for the callers data
* - event: a lsm_event_t event
void
lsm_event_data
tw_event
event
tw_lp
sender
struct
codes_mctx
const
map_ctx
int
return_tag
msg_header
const
return_header
struct
codes_cb_info
const
cb
void
lsm_io_event_rc
tw_lp
sender
/* get the priority count for the LSM scheduler.
* returns 0 if priorities aren't being used, -1 if no LSMs were configured,
* and >0 otherwise.
* This should not be called before lsm_configure */
int
lsm_get_num_priorities
char
const
annotation
int
ignore_annotations
struct
codes_mctx
const
map_ctx
tw_lpid
sender_id
/* set a request priority for the following lsm_event_*.
* - tw_error will be called if the priority ends up being out-of-bounds
@@ -120,15 +108,6 @@ void lsm_register(void);
/* configures the LSM model(s) */
void
lsm_configure
void
* Macros
#define lsm_write_event_new(cat,gid,obj,off,sz,mb,s) \
lsm_event_new((cat),(gid),(obj),(off),(sz),LSM_WRITE_REQUEST,(mb),(s),0.0)
#define lsm_read_event_new(cat,gid,obj,off,sz,mb,s) \
lsm_event_new((cat),(gid),(obj),(off),(sz),LSM_READ_REQUEST,(mb),(s),0.0)
#define LSM_DEBUG 0
#endif
codes/resource-lp.h
View file @
1d46dc5d
@@ -11,11 +11,14 @@
#ifndef RESOURCE_LP_H
#define RESOURCE_LP_H
#include "ross.h"
#include "codes/lp-msg.h"
#include "codes/resource.h"
#include <ross.h>
#include <stdint.h>
#include "lp-msg.h"
#include "resource.h"
#define RESOURCE_MAX_CALLBACK_PAYLOAD 64
#define RESOURCE_LP_NM "resource"
@@ -24,7 +27,7 @@ typedef struct {
int
ret
/* in the case of a reserve, need to return the token */
resource_token_t
tok
resource_
callback
resource_
return
/* registers the resource LP with CODES/ROSS */
@@ -42,57 +45,43 @@ void resource_lp_configure();
* block_on_unavail - flag whether to wait to message the requester if
* request cannot be satisfied
* msg_size - size of the requester event structure
* msg_header_offset - offset in the requester event to place the resource's
* msg_header
* msg_callback_offset - offset in the requester event struct to place the
* resource-provided resource_callback data
* msg_callback_misc_size - size of requester-provided callback data
* msg_callback_misc_offset - offset in the requester event struct to place the
* requester-provided callback data
* msg_callback_misc_data - requester-provided callback data
* return_tag, return_header - set in the return client event, using the offsets in cb
void
resource_lp_get
msg_header
header
uint64_t
req
int
block_on_unavail
int
msg_size
int
msg_header_offset
int
msg_callback_offset
int
int
void
tw_lp
sender
tw_lp
sender
struct
codes_mctx
const
map_ctx
int
return_tag
msg_header
const
return_header
struct
codes_cb_info
const
cb
/* no callback for frees thus far */
void
resource_lp_free
uint64_t
req
tw_lp
sender
void
resource_lp_free
uint64_t
req
tw_lp
sender
struct
codes_mctx
const
map_ctx
void
resource_lp_reserve
msg_header
header
uint64_t
req
int
block_on_unavail
int
msg_size
int
msg_header_offset
int
msg_callback_offset
int
int
void
tw_lp
sender
tw_lp
sender
struct
codes_mctx
const
map_ctx
int
return_tag
msg_header
const
return_header
struct
codes_cb_info
const
cb
void
resource_lp_get_reserved
msg_header
header
uint64_t
req
resource_token_t
tok
int
block_on_unavail
int
msg_size
int
msg_header_offset
int
msg_callback_offset
int
int
void
tw_lp
sender
tw_lp
sender
struct
codes_mctx
const
map_ctx
int
return_tag
msg_header
const
return_header
struct
codes_cb_info
const
cb
void
resource_lp_free_reserved
uint64_t
req
resource_token_t
tok
tw_lp
sender
tw_lp
sender
struct
codes_mctx
const
map_ctx
/* rc functions - thankfully, they only use codes-local-latency, so no need
* to pass in any arguments */
src/Makefile.subdir
View file @
1d46dc5d
@@ -59,7 +59,8 @@ nobase_include_HEADERS = \
codes/rc-stack.h
codes/codes-jobmap.h
#codes/codes-nw-workload.h
@@ -102,6 +103,7 @@ src_libcodes_base_a_SOURCES = \
src/util/jobmap-impl/jobmap-dummy.c
src/util/jobmap-impl/jobmap-list.c
src/util/jobmap-impl/jobmap-identity.c
src/workload/codes-workload.c
src/workload/codes-workload-method.h
src/workload/methods/codes-iolang-wrkld.c
0 → 100644
View file @
1d46dc5d
#include <codes/codes-mapping-context.h>
#include <codes/codes_mapping.h>
static
struct
codes_mctx
const
CODES_MCTX_DEFAULT_VAL
type
u
group_modulo
anno
annotation
NULL
ignore_annotations
true
struct
codes_mctx
const
const
CODES_MCTX_DEFAULT
struct
codes_mctx
tw_lpid
lpid
struct
codes_mctx
rtn
rtn
type
rtn
u
global_direct
lpid
lpid
return
rtn
struct
codes_mctx
char
const
annotation
bool
ignore_annotations
struct
codes_mctx
rtn
rtn
type
rtn
u
group_modulo
anno
annotation
annotation
rtn
u
group_modulo
anno
ignore_annotations
ignore_annotations
return
rtn
struct
codes_mctx
int
offset
char
const
annotation
bool
ignore_annotations
struct
codes_mctx
rtn
rtn
type
rtn
u
group_direct
offset
offset
rtn
u
group_direct
anno
annotation
annotation
rtn
u
group_direct
anno
ignore_annotations
ignore_annotations
return
rtn
* based on what types of ctx exist */
tw_lpid
codes_mctx_to_lpid
struct
codes_mctx
const
ctx
char
const
dest_lp_name
tw_lpid
sender_gid
struct
const
anno
// short circuit for direct mappings
switch
ctx
type
case
return
ctx
u
global_direct
lpid
case
anno
ctx
u
group_modulo
anno
break
case
anno
ctx
u
group_direct
anno
break
default:
assert
0
char
sender_group
MAX_NAME_LENGTH
int
unused
rep_id
offset
// get sender info
codes_mapping_get_lp_info
sender_gid
sender_group
unused
NULL
unused
NULL
rep_id
offset
int
dest_offset
if
ctx
type
int
num_dest_lps
codes_mapping_get_lp_count
sender_group
1
dest_lp_name
anno
annotation
anno
ignore_annotations
if
num_dest_lps
0
tw_error
TW_LOC
"ERROR: Found no LPs of type %s in group %s "
"(source lpid %lu) with annotation: %s
\n
dest_lp_name
sender_group
sender_gid
anno
ignore_annotations
"ignored"
anno
annotation
anno
annotation
"none"
dest_offset
offset
num_dest_lps
else
if
ctx
type
dest_offset
ctx
u
group_direct
offset
else
assert
0
tw_lpid
rtn
codes_mapping_get_lp_id
sender_group
dest_lp_name
anno
annotation
anno
ignore_annotations
rep_id
dest_offset
rtn
return
rtn
char
const
struct
codes_mctx
const
ctx
char
const
dest_lp_name
tw_lpid
sender_id
switch
ctx
type
case
return
codes_mapping_get_annotation_by_lpid
sender_id
case
// if not ignoring the annotation, just return what's in the
// context
if
ctx
u
group_modulo
anno
ignore_annotations
return
ctx
u
group_modulo
anno
annotation
break
case
if
ctx
u
group_direct
anno
ignore_annotations
return
ctx
u
group_direct
anno
annotation
break
default:
tw_error
TW_LOC
"unrecognized or uninitialized context type: %d"
ctx
type
return
NULL
// at this point, we must be a group-wise mapping ignoring annotations
char
group
MAX_NAME_LENGTH
int
dummy
// only need the group name
sender_id
group
dummy
NULL
dummy
NULL
dummy
dummy
return
codes_mapping_get_annotation_by_name
group
dest_lp_name
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
View file @
1d46dc5d
@@ -21,18 +21,6 @@
int
lsm_in_sequence
0
tw_stime
lsm_msg_offset
0
0
* wrapped_event_t
* - holds the callers event and data they want sent upon
* completion of a IO operation.
typedef
struct
wrapped_event_s
tw_lpid
id
size_t
size
char
message
1
wrapped_event_t
/* holds statistics about disk traffic on each LP */
typedef
struct
lsm_stats_s
@@ -143,7 +131,7 @@ typedef struct lsm_message_s
int64_t
prev_offset
uint64_t
prev_object
lsm_message_data_t
data
wrapped_event_t
wrap
struct
codes_cb_params
cb
lsm_message_t
@@ -266,82 +254,55 @@ static tw_stime transfer_time_table (lsm_state_t *ns,
return
time
void
lsm_
event_new_reverse
tw_lp
sender
void
lsm_
io_event_rc
tw_lp
sender
codes_local_latency_reverse
sender
return
static
tw_lpid
lsm_find_local_device_default
const
char
annotation
int
ignore_annotations
tw_lpid
sender_gid
char
group_name
MAX_NAME_LENGTH
int
dummy
mapping_rep
mapping_offset
int
num_lsm_lps
tw_lpid
rtn
sender_gid
group_name
dummy
NULL
dummy
NULL
mapping_rep
mapping_offset
num_lsm_lps
group_name
1
LSM_NAME
annotation
ignore_annotations
group_name
LSM_NAME
annotation
ignore_annotations
mapping_rep
mapping_offset
num_lsm_lps
rtn
return
rtn
tw_lpid
const
char
annotation
int
ignore_annotations
tw_lpid
sender_gid
return
annotation
ignore_annotations
sender_gid
struct
codes_mctx
const
map_ctx
tw_lpid
sender_gid
return
codes_mctx_to_lpid
map_ctx
LSM_NAME
sender_gid
static
tw_event
lsm_event_new_base
const
char
category
tw_lpid
dest_gid
void
lsm_io_event
const
char
lp_io_category
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
const
char
annotation
int
ignore_annotations
tw_lp
sender
struct
codes_mctx
const
map_ctx
int
return_tag
msg_header
const
return_header
struct
codes_cb_info
const
cb
tw_event
e
lsm_message_t
m
tw_lpid
lsm_gid
tw_stime
delta
assert
strlen
category
CATEGORY_NAME_MAX
1
assert
strlen
category
0
assert
strlen
lp_io_category
CATEGORY_NAME_MAX
1
assert
strlen
lp_io_category
0
SANITY_CHECK_CB
cb
lsm_return_t
/* Generate an event for the local storage model, and send the
* event to an lsm LP.
lsm_gid
annotation
ignore_annotations
sender
gid
tw_lpid
lsm_id
codes_mctx_to_lpid
map_ctx
LSM_NAME
sender
gid
delta
codes_local_latency
sender
delay
tw_stime
delta
delay
codes_local_latency
sender
if
lsm_in_sequence
tw_stime
tmp
lsm_msg_offset
lsm_msg_offset
delta
delta
tmp
e
codes_event_new
lsm_gid
delta
sender
m
lsm_message_t
tw_event_data
e
tw_event
e
tw_event_new
lsm_id
delta
sender
lsm_message_t
m
tw_event_data
e
m
magic
lsm_magic
m
event
lsm_event_t
io_type
m
event
lsm_event_t
io_type
m
data
object
io_object
m
data
offset
io_offset
m
data
size
io_size_bytes
strcpy
m
data
category
category
strcpy
m
data
category
lp_io_
category
// get the priority count for checking
int
num_prios
annotation
ignore_annotations
int
num_prios
map_ctx
sender
gid
// prio checks and sets
if
num_prios
0
// disabled scheduler - ignore
m
data
prio
0
@@ -352,105 +313,34 @@ static tw_event* lsm_event_new_base(
else
tw_error
TW_LOC
"LP %lu, LSM LP %lu: Bad priority (%d supplied, %d lanes)
\n
sender
gid
dest_g
id
temp_prio
num_prios
sender
gid
lsm_
id
temp_prio
num_prios
// reset temp_prio
temp_prio
1
/* save callers dest_gid and message size */
m
wrap
id
dest_gid
m
wrap
size
message_bytes
return
e
* lsm_event_new
* LSM LP.
* - category: string name to identify the traffic category
* - dest_gid: the gid to send the callers event to
tw_event
lsm_event_new
const
char
category
tw_lpid
dest_gid
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
return
lsm_event_new_base
category
dest_gid
io_object
io_offset
io_size_bytes
io_type
message_bytes
sender
delay
NULL
1
tw_event
const
char
category
tw_lpid
dest_gid
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
const
char
annotation
int
ignore_annotations
return
lsm_event_new_base
category
dest_gid
io_object
io_offset
io_size_bytes
io_type
message_bytes
sender
delay
annotation
ignore_annotations
* lsm_event_data
