Commit 1b2810b6 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
removing VC reset (not tested at the moment)
parent 023bdbe2
......@@ -3287,23 +3287,24 @@ if(cur_chunk->msg.path_type == NON_MINIMAL)
output_chan = 0;
if(output_port < s->params->intra_grp_radix) {
if(DF_DALLY == 1)
if(cur_chunk->msg.my_g_hop == 1) {
output_chan = 1;
} else if (cur_chunk->msg.my_g_hop == 2) {
output_chan = 3;
else {
output_chan = msg->my_l_hop;
// if(DF_DALLY == 1)
// if(cur_chunk->msg.my_g_hop == 1 && cur_chunk->msg.last_hop == GLOBAL) {
// output_chan = 1;
// } else if (cur_chunk->msg.my_g_hop == 2) {
// output_chan = 3;
//else {
/* TODO: Recheck VC count after things are in order for a 2-D dragonfly. */
output_chan = 2;
output_chan = 6;
// output_chan = 2;
// else if (cur_chunk->msg.my_g_hop == 2 && cur_chunk->msg.last_hop == GLOBAL) {
// output_chan = 6;
max_vc_size = s->params->local_vc_size;
cur_chunk->msg.my_l_hop++;
} else if(output_port < (s->params->intra_grp_radix +
Markdown is supported
0% or .
Please register or to comment
