Commit 1ad10977 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
more info in debug printing
parent 33ac100a
...@@ -198,8 +198,9 @@ void fcfs_add ( ...@@ -198,8 +198,9 @@ void fcfs_add (
else { q->local_event = NULL; } else { q->local_event = NULL; }
mn_sched_queue *s = sched; mn_sched_queue *s = sched;
qlist_add_tail(&q->ql, &s->reqs); qlist_add_tail(&q->ql, &s->reqs);
dprintf("%lu (mn): adding request from %lu to %lu\n", lp->gid, dprintf("%lu (mn): adding %srequest from %lu to %lu, size %lu, at %lf\n",
req->src_lp, req->final_dest_lp); lp->gid, req->is_pull ? "pull " : "", req->src_lp,
req->final_dest_lp, req->msg_size, tw_now(lp));
void fcfs_add_rc(void *sched, model_net_sched_rc *rc, tw_lp *lp){ void fcfs_add_rc(void *sched, model_net_sched_rc *rc, tw_lp *lp){
...@@ -243,8 +244,9 @@ int fcfs_next( ...@@ -243,8 +244,9 @@ int fcfs_next(
if (s->is_recv_queue){ if (s->is_recv_queue){
dprintf("%lu (mn): receiving message of size %lu (of %lu) " dprintf("%lu (mn): receiving message of size %lu (of %lu) "
"from %lu to %lu\n", "from %lu to %lu at %lf\n",
lp->gid, psize, q->rem, q->req.src_lp, q->req.final_dest_lp); lp->gid, psize, q->rem, q->req.src_lp, q->req.final_dest_lp,
tw_now(lp));
*poffset = s->method->model_net_method_recv_msg_event(q->req.category, *poffset = s->method->model_net_method_recv_msg_event(q->req.category,
q->req.final_dest_lp, psize, q->req.is_pull, q->req.msg_size, q->req.final_dest_lp, psize, q->req.is_pull, q->req.msg_size,
0.0, q->req.remote_event_size, q->remote_event, q->req.src_lp, 0.0, q->req.remote_event_size, q->remote_event, q->req.src_lp,
...@@ -252,8 +254,9 @@ int fcfs_next( ...@@ -252,8 +254,9 @@ int fcfs_next(
else{ else{
dprintf("%lu (mn): issuing packet of size %lu (of %lu) " dprintf("%lu (mn): issuing packet of size %lu (of %lu) "
tw_now(lp));
*poffset = s->method->model_net_method_packet_event(q->req.category, *poffset = s->method->model_net_method_packet_event(q->req.category,
0.0, &q->sched_params, q->req.remote_event_size, q->remote_event, 0.0, &q->sched_params, q->req.remote_event_size, q->remote_event,
...@@ -445,7 +448,6 @@ void prio_add ( ...@@ -445,7 +448,6 @@ void prio_add (
// sched_msg_params is simply an int // sched_msg_params is simply an int
mn_sched_prio *ss = sched; mn_sched_prio *ss = sched;
int prio = sched_params->prio; int prio = sched_params->prio;
dprintf("%lu (mn): adding with prio %d\n", lp->gid, prio);
if (prio == -1){ if (prio == -1){
// default prio - lowest possible // default prio - lowest possible
prio = ss->params.num_prios-1; prio = ss->params.num_prios-1;
...@@ -454,6 +456,7 @@ void prio_add ( ...@@ -454,6 +456,7 @@ void prio_add (
tw_error(TW_LOC, "sched for lp %lu: invalid prio (%d vs [%d,%d))", tw_error(TW_LOC, "sched for lp %lu: invalid prio (%d vs [%d,%d))",
lp->gid, prio, 0, ss->params.num_prios); lp->gid, prio, 0, ss->params.num_prios);
ss->sub_sched_iface->add(req, sched_params, remote_event_size, ss->sub_sched_iface->add(req, sched_params, remote_event_size,
remote_event, local_event_size, local_event, ss->sub_scheds[prio], remote_event, local_event_size, local_event, ss->sub_scheds[prio],
rc, lp); rc, lp);
Markdown is supported
0% or .
Please register or to comment
