Commit 1925ef59 authored by Shane Snyder's avatar Shane Snyder
Browse files
Further optimizations to collective timing
parent 6e7ff905
...@@ -505,13 +505,6 @@ void generate_psx_coll_file_events( ...@@ -505,13 +505,6 @@ void generate_psx_coll_file_events(
assert(file->counters[CP_POSIX_OPENS] >= nprocs); assert(file->counters[CP_POSIX_OPENS] >= nprocs);
total_delay = (file->fcounters[CP_F_CLOSE_TIMESTAMP] -
file->fcounters[CP_F_OPEN_TIMESTAMP] -
(file->fcounters[CP_F_POSIX_READ_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_WRITE_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_META_TIME] / nprocs));
if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS]) if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS])
extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] - extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] -
...@@ -523,16 +516,31 @@ void generate_psx_coll_file_events( ...@@ -523,16 +516,31 @@ void generate_psx_coll_file_events(
total_ind_io_ops = file->counters[CP_INDEP_READS] + file->counters[CP_INDEP_WRITES]; total_ind_io_ops = file->counters[CP_INDEP_READS] + file->counters[CP_INDEP_WRITES];
total_coll_io_ops = (file->counters[CP_COLL_READS] + file->counters[CP_COLL_WRITES]) / nprocs; total_coll_io_ops = (file->counters[CP_COLL_READS] + file->counters[CP_COLL_WRITES]) / nprocs;
if (total_coll_opens && total_ind_opens) if (file->counters[CP_COLL_OPENS])
open_cycles = total_coll_opens / nprocs; {
else if (total_coll_opens) total_delay = (file->fcounters[CP_F_CLOSE_TIMESTAMP] -
(file->fcounters[CP_F_POSIX_READ_TIME] / in_agg_cnt) -
(file->fcounters[CP_F_POSIX_WRITE_TIME] / in_agg_cnt) -
(file->fcounters[CP_F_POSIX_META_TIME] / in_agg_cnt));
open_cycles = total_coll_opens / nprocs; open_cycles = total_coll_opens / nprocs;
calc_io_delays(file, ceil(((double)(total_coll_opens + total_ind_opens)) / nprocs),
total_coll_io_ops + ceil((double)total_ind_io_ops / nprocs), total_delay,
&first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay);
else else
open_cycles = ceil((double)total_ind_opens / nprocs); {
calc_io_delays(file, ceil(((double)(total_coll_opens + total_ind_opens)) / nprocs), open_cycles = ceil((double)total_ind_opens / nprocs);
total_coll_io_ops + ceil((double)total_ind_io_ops / nprocs), total_delay, calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay,
&first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay); &first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay);
else else
...@@ -557,6 +565,12 @@ void generate_psx_coll_file_events( ...@@ -557,6 +565,12 @@ void generate_psx_coll_file_events(
total_ind_io_ops = total_io_ops - extra_io_ops; total_ind_io_ops = total_io_ops - extra_io_ops;
total_coll_io_ops = 0; total_coll_io_ops = 0;
open_cycles = ceil((double)total_ind_opens / nprocs); open_cycles = ceil((double)total_ind_opens / nprocs);
calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay, calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay,
Markdown is supported
0% or .
Please register or to comment
