Commit 18afbc3a authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
updated codes-mapping documentation
parent ded76aad
Codes Mapping API Overview
- The codes-mapping.h header file contains the function definitions for the codes LP mapping. - The codes-mapping.h header file contains the function definitions for the codes LP mapping.
Step 1: Specifying the LP types in the config file: Step 1: Specifying the LP types in the config file:
...@@ -56,13 +59,15 @@ file. ...@@ -56,13 +59,15 @@ file.
codes_mapping_setup(); codes_mapping_setup();
Step 5: Querying number of LPs in a repetition Step 5: Querying number of LPs in a group/repetition.
int codes_mapping_get_lp_count(group_name, lp_type_name); int codes_mapping_get_lp_count(group_name, 1, lp_type_name, NULL, 0);
For example, to query the number of server LPs in example-test2.conf file, calling The second argument indicates whether to include the number of repetitions into
the count or not (the NULL, 0 arguments will be discussed later). For example,
num_servers = codes_mapping_get_lp_count("MODELNET_GRP", "server"); num_servers = codes_mapping_get_lp_count("MODELNET_GRP", 1, "server", NULL, 0);
will return 2. will return 2.
...@@ -85,3 +90,53 @@ second N to the second PE, and so forth, where N is the floor of the LP count ...@@ -85,3 +90,53 @@ second N to the second PE, and so forth, where N is the floor of the LP count
and the PE count. If the number of LPs is not divisible by the number of PEs, and the PE count. If the number of LPs is not divisible by the number of PEs,
then the first N+1 LPs are mapped to the first PE and so on, until the remainder then the first N+1 LPs are mapped to the first PE and so on, until the remainder
has been taken care of. has been taken care of.
=== Namespaces supported by codes mapping API ===
The configuration scheme suppports "annotation"-based specifications. For
example:
LPGROUPS
GROUP_1
repetitions="16";
server@foo="1";
example_net@foo="1";
SWITCH
repetitions="1";
example_net@bar="1";
GROUP_2
repetitions="16";
server@bar="1";
PARAMS
net_bandwidth@foo="100";
net_bandwidth@bar="50";
In this example, the example_net LP will be configured corresponding to their
annotations "foo" and "bar". Not only does this allow specialization of
otherwise identical models, this also presents the opportunity to provide
namespace functionality to the mapping API.
Current namespace support includes (see codes_mapping.h for more details)
- Global (e.g., LPs). Additional specializations for doing lookups corresponding
to a specific annotation, to support use cases such as the two example_net's
in the SWITCH group.
- LP-specific namespace (0..N) where N is the number of LPs of a specific type
(codes_mapping_get_lp_relative_id and codes_mapping_get_lpid_from_relative)
- relative IDs can be with respect to a particular group, a particular
annotation, both, or neither
...@@ -281,8 +281,8 @@ tw_lpid codes_mapping_get_lpid_from_relative( ...@@ -281,8 +281,8 @@ tw_lpid codes_mapping_get_lpid_from_relative(
local_rel_id_count += lpt->count; local_rel_id_count += lpt->count;
// is our relative id within this group? // is our relative id within this group?
if (relative_id < rel_id_count + if (relative_id < rel_id_count +
lpg->repetitions * local_rel_id_count){ lpg->repetitions * local_rel_id_count){
tw_lpid gid = gid_count; tw_lpid gid = gid_count;
int rem = relative_id - rel_id_count; int rem = relative_id - rel_id_count;
...@@ -293,13 +293,13 @@ tw_lpid codes_mapping_get_lpid_from_relative( ...@@ -293,13 +293,13 @@ tw_lpid codes_mapping_get_lpid_from_relative(
for (int l = 0; l < lpg->lptypes_count; l++){ for (int l = 0; l < lpg->lptypes_count; l++){
config_lptype_t *lpt = &lpg->lptypes[l]; config_lptype_t *lpt = &lpg->lptypes[l];
if ( strcmp(lp_type_name, lpt->name) == 0 && if ( strcmp(lp_type_name, lpt->name) == 0 &&
(!annotation_wise || (!annotation_wise ||
cmp_anno(annotation, lpt->anno))){ cmp_anno(annotation, lpt->anno))){
if (rem < (int) lpt->count){ if (rem < (int) lpt->count){
return gid + (tw_lpid) rem; return gid + (tw_lpid) rem;
else{ else{
rem -= lpt->count; rem -= lpt->count;
gid += lpt->count; gid += lpt->count;
...@@ -323,7 +323,7 @@ tw_lpid codes_mapping_get_lpid_from_relative( ...@@ -323,7 +323,7 @@ tw_lpid codes_mapping_get_lpid_from_relative(
local_gid_count += lpg->lptypes[l].count; local_gid_count += lpg->lptypes[l].count;
gid_count += local_gid_count * lpg->repetitions; gid_count += local_gid_count * lpg->repetitions;
NOT_FOUND: NOT_FOUND:
Markdown is supported
0% or .
Please register or to comment
