Commit 171757e0 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Dragonfly Plus: Local routing uses best choice
parent c3b8f7c8
...@@ -2740,14 +2740,16 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2740,14 +2740,16 @@ static Connection do_dfp_routing(router_state *s,
vector< Connection > poss_next_stops = s->connMan->get_connections_to_gid(msg->dfp_dest_terminal_id, CONN_TERMINAL); vector< Connection > poss_next_stops = s->connMan->get_connections_to_gid(msg->dfp_dest_terminal_id, CONN_TERMINAL);
if (poss_next_stops.size() < 1) if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "Destination Router: No connection to destination terminal\n"); tw_error(TW_LOC, "Destination Router: No connection to destination terminal\n");
return poss_next_stops[0]; Connection best_min_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops);
return best_min_conn;
else if (my_group_id == fdest_group_id) { //then we just route minimally else if (my_group_id == fdest_group_id) { //then we just route minimally
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id);
tw_error(TW_LOC, "DEAD END WHEN ROUTING LOCALLY\n"); tw_error(TW_LOC, "DEAD END WHEN ROUTING LOCALLY\n");
//------------ END LOCAL GROUP ROUTING --------- //------------ END LOCAL GROUP ROUTING ---------
// from here we can assume that we are not in the destination group // from here we can assume that we are not in the destination group
Markdown is supported
0% or .
Please register or to comment
