Commit 14a299b8 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
update to next packet generate event time
parent 5574637a
...@@ -141,6 +141,9 @@ struct terminal_state ...@@ -141,6 +141,9 @@ struct terminal_state
const char * anno; const char * anno;
const dragonfly_param *params; const dragonfly_param *params;
/* self suspend mode to the dragonfly */
int suspend;
/* terminal event type (1-4) */ /* terminal event type (1-4) */
...@@ -727,7 +730,7 @@ static void packet_generate_send(terminal_state * s, ...@@ -727,7 +730,7 @@ static void packet_generate_send(terminal_state * s,
void * m_gen_data; void * m_gen_data;
/* Keep the packet generate event a little behind packet send */ /* Keep the packet generate event a little behind packet send */
ts = ts + codes_local_latency(lp); ts = codes_local_latency(lp);
e_gen = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY, (void**)&m_gen,(void**)&m_gen_data); e_gen = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY, (void**)&m_gen,(void**)&m_gen_data);
Markdown is supported
0% or .
Please register or to comment
