Commit 1203794b authored by Caitlin Ross's avatar Caitlin Ross
Browse files
adding event type collection to fat tree synthetic workload LP
parent ac24d4e7
...@@ -133,3 +133,4 @@ Any other LPs built off of the model net LP, can be changed in the same way. ...@@ -133,3 +133,4 @@ Any other LPs built off of the model net LP, can be changed in the same way.
- dfly server LP (model-net-synthetic.c) - dfly server LP (model-net-synthetic.c)
- fat tree terminal and switch LPs (fattree.c) - fat tree terminal and switch LPs (fattree.c)
- model-net-base-lp (model-net-lp.c) - model-net-base-lp (model-net-lp.c)
- fat tree server LP (model-net-synthetic-fattree.c)
...@@ -120,6 +120,34 @@ tw_lptype svr_lp = { ...@@ -120,6 +120,34 @@ tw_lptype svr_lp = {
sizeof(svr_state), sizeof(svr_state),
/* setup for the ROSS event tracing
* can have a different function for rbev_trace_f and ev_trace_f
* but right now it is set to the same function for both
void ft_svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer)
int type = (int) m->svr_event_type;
memcpy(buffer, &type, sizeof(type));
st_trace_type ft_svr_trace_types[] = {
{(rbev_trace_f) ft_svr_event_collect,
sizeof(int),
(ev_trace_f) ft_svr_event_collect,
sizeof(int)},
{0}
static const st_trace_type *ft_svr_get_trace_types(void)
return(&ft_svr_trace_types[0]);
void ft_svr_register_trace()
trace_type_register("server", ft_svr_get_trace_types());
const tw_optdef app_opt [] = const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ), TWOPT_GROUP("Model net synthetic traffic " ),
...@@ -408,6 +436,9 @@ int main( ...@@ -408,6 +436,9 @@ int main(
svr_add_lp_type(); svr_add_lp_type();
if (g_st_ev_trace)
ft_svr_register_trace();
codes_mapping_setup(); codes_mapping_setup();
Markdown is supported
0% or .
Please register or to comment
