Skip to content
GitLab
Menu
Projects
Groups
Snippets
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
codes
codes
Commits
11959e72
Commit
11959e72
authored
Dec 09, 2014
by
Jonathan Jenkins
Browse files
stripped out network workload from build
parent
a847aac5
Changes
1
Hide whitespace changes
Inline
Side-by-side
src/Makefile.subdir
View file @
11959e72
@@ -8,15 +8,15 @@ EXTRA_DIST += src/iokernellang/codesparser.y.in \
src/modelconfig/configparser.y
src/modelconfig/configlex.l
src/modelconfig/README.txt
src/network-workload/README
src/network-workload/offsets
src/network-workload/scala-trace-data
src/util/templates/README.txt
src/util/README.codes-mapping.txt
src/util/README.lp-io.txt
src/workload/README.codes-workload
src/workload/TODO.codes-workload
#src/network-workload/README
#src/network-workload/offsets
#src/network-workload/scala-trace-data
PHONY
maintainer-clean-local
@@ -118,12 +118,13 @@ src_libcodes_base_a_SOURCES = \
src/workload/codes-bgp-io-wrkld.c
src/workload/test-workload-method.c
codes/codes-nw-workload.h
src/network-workload/codes-nw-workload.c
src/network-workload/codes-nw-workload-method.h
src/network-workload/codes-scala-trace-nw-wrkld.c
codes/rc-stack.h
src/util/rc-stack.c
#src/network-workload/codes-nw-workload.c
#src/network-workload/codes-nw-workload-method.h
#src/network-workload/codes-scala-trace-nw-wrkld.c
# stealth testing of the template code (actual test is not run, just compiled as
# a program - Make error signifies test failure)
check_PROGRAMS
src/util/templates/lp_template_dummy_main
@@ -142,12 +143,12 @@ src_workload_codes_workload_dump_SOURCES = \
src_workload_codes_workload_dump_LDADD
$(testlib)
${DARSHAN_LIBS}
${ROSS_LIBS}
src_workload_codes_workload_dump_LDFLAGS
${DARSHAN_LDFLAGS}
${ROSS_LDFLAGS}
bin_PROGRAMS
src/network-workload/codes-nw-test
bin_PROGRAMS += src/network-workload/codes-nw-test
src_network_workload_codes_nw_test_SOURCES
src/network-workload/codes-nw-test.c
src_network_workload_codes_nw_test_LDADD
$(testlib)
${ROSS_LIBS}
${DUMPI_LIBS}
src_network_workload_codes_nw_test_LDFLAGS
${ROSS_LDFLAGS}
src_network_workload_codes_nw_test_SOURCES = \
src_network_workload_codes_nw_test_LDADD = $(testlib) ${ROSS_LIBS} ${DUMPI_LIBS}
src_network_workload_codes_nw_test_LDFLAGS = ${ROSS_LDFLAGS}
#bin_PROGRAMS += src/network-workload/codes-dumpi-wrkld
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
