Commit 0cd2daad authored by Misbah Mubarak's avatar Misbah Mubarak Committed by Neil McGlohon
Browse files
Adding fixes to dragonfly-plus reverse handler
parent 27e8637a
...@@ -2931,6 +2931,7 @@ int modelnet_mpi_replay(MPI_Comm comm, int* argc, char*** argv ) ...@@ -2931,6 +2931,7 @@ int modelnet_mpi_replay(MPI_Comm comm, int* argc, char*** argv )
group_ratio = codes_mctx_set_group_ratio(NULL, true); group_ratio = codes_mctx_set_group_ratio(NULL, true);
if(enable_sampling) if(enable_sampling)
model_net_enable_sampling(sampling_interval, sampling_end_time); model_net_enable_sampling(sampling_interval, sampling_end_time);
...@@ -1144,7 +1144,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess ...@@ -1144,7 +1144,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess
int num_term_rc_wins = s->num_term_rc_windows; int num_term_rc_wins = s->num_term_rc_windows;
/* dynamically reallocate array if index has reached max-size */ /* dynamically reallocate array if index has reached max-size */
if(s->rc_index == s->num_term_rc_windows) if(s->rc_index >= s->num_term_rc_windows)
s->num_term_rc_windows *= 2; s->num_term_rc_windows *= 2;
int * tmp1 = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int)); int * tmp1 = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
...@@ -1225,7 +1225,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me ...@@ -1225,7 +1225,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me
int num_rtr_rc_windows = s->num_rtr_rc_windows; int num_rtr_rc_windows = s->num_rtr_rc_windows;
/* dynamically reallocate the array.. */ /* dynamically reallocate the array.. */
if(s->rc_index == s->num_rtr_rc_windows) if(s->rc_index >= s->num_rtr_rc_windows)
s->num_rtr_rc_windows *= 2; s->num_rtr_rc_windows *= 2;
int * tmp1 = (int*)calloc(s->num_rtr_rc_windows * s->params->radix * num_qos_levels, sizeof(int)); int * tmp1 = (int*)calloc(s->num_rtr_rc_windows * s->params->radix * num_qos_levels, sizeof(int));
...@@ -1269,7 +1269,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me ...@@ -1269,7 +1269,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me
int bw_consumed = get_rtr_bandwidth_consumption(s, k, j); int bw_consumed = get_rtr_bandwidth_consumption(s, k, j);
if(s->router_id == 0) if(s->router_id == 0)
//fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]); fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]);
...@@ -1699,22 +1699,6 @@ static void router_credit_send(router_state * s, terminal_custom_message * msg, ...@@ -1699,22 +1699,6 @@ static void router_credit_send(router_state * s, terminal_custom_message * msg,
strcpy(buf_msg->category, msg->category); strcpy(buf_msg->category, msg->category);
buf_msg->type = type; buf_msg->type = type;
if(strcmp(msg->category, "medium") == 0)
if(is_terminal == 0)
if(buf_msg->output_chan < 4 || buf_msg->output_chan >= 8)
printf("\n Router medium prio arrived packet-id %d rid %d sq %d", msg->packet_ID, msg->origin_router_id, sq);
tw_error(TW_LOC, "\n port %d output chan %d dest %d ", buf_msg->vc_index, buf_msg->output_chan, is_terminal);
else
if(buf_msg->output_chan < 1)
printf("\n Incorrect terminal vc %d ", buf_msg->output_chan);
tw_event_send(buf_e); tw_event_send(buf_e);
return; return;
...@@ -2257,7 +2241,9 @@ static void packet_send(terminal_state * s, tw_bf * bf, terminal_custom_message ...@@ -2257,7 +2241,9 @@ static void packet_send(terminal_state * s, tw_bf * bf, terminal_custom_message
rc_stack_push(lp, cur_entry, delete_terminal_custom_message_list, s->st); rc_stack_push(lp, cur_entry, delete_terminal_custom_message_list, s->st);
s->terminal_length[vcg] -= s->params->chunk_size; s->terminal_length[vcg] -= s->params->chunk_size;
cur_entry = s->terminal_msgs[next_vcg]; cur_entry = NULL;
if(next_vcg >= 0)
/* if there is another packet inline then schedule another send event */ /* if there is another packet inline then schedule another send event */
if(cur_entry != NULL && if(cur_entry != NULL &&
...@@ -339,7 +339,7 @@ struct terminal_state ...@@ -339,7 +339,7 @@ struct terminal_state
long finished_chunks; long finished_chunks;
long finished_packets; long finished_packets;
tw_stime *last_buf_full; tw_stime last_buf_full;
tw_stime busy_time; tw_stime busy_time;
tw_stime max_latency; tw_stime max_latency;
...@@ -678,6 +678,7 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p) ...@@ -678,6 +678,7 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p)
MPI_Comm_rank(MPI_COMM_CODES, &myRank); MPI_Comm_rank(MPI_COMM_CODES, &myRank);
if (!myRank) { if (!myRank) {
printf("\n------------------ Dragonfly Plus Parameters ---------\n"); printf("\n------------------ Dragonfly Plus Parameters ---------\n");
printf("\tnum_qos_levels = %d\n",p->num_qos_levels);
printf("\tnum_routers = %d\n",p->num_routers); printf("\tnum_routers = %d\n",p->num_routers);
printf("\tlocal_bandwidth = %.2f\n",p->local_bandwidth); printf("\tlocal_bandwidth = %.2f\n",p->local_bandwidth);
printf("\tglobal_bandwidth = %.2f\n",p->global_bandwidth); printf("\tglobal_bandwidth = %.2f\n",p->global_bandwidth);
...@@ -742,7 +743,7 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -742,7 +743,7 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
fprintf(stderr, "Buffer size of global channels not specified, setting to %d\n", p->global_vc_size); fprintf(stderr, "Buffer size of global channels not specified, setting to %d\n", p->global_vc_size);
rc = configuration_get_value_int(&config, "PARAMS", "qos_levels", anno, &p->num_qos_levels); rc = configuration_get_value_int(&config, "PARAMS", "num_qos_levels", anno, &p->num_qos_levels);
if(rc) { if(rc) {
p->num_qos_levels = 1; p->num_qos_levels = 1;
fprintf(stderr, "Number of QOS levels not specified, setting to %d\n", p->num_qos_levels); fprintf(stderr, "Number of QOS levels not specified, setting to %d\n", p->num_qos_levels);
...@@ -1403,7 +1404,7 @@ void router_plus_setup(router_state *r, tw_lp *lp) ...@@ -1403,7 +1404,7 @@ void router_plus_setup(router_state *r, tw_lp *lp)
char rtr_bw_log[128]; char rtr_bw_log[128];
sprintf(rtr_bw_log, "router-bw-tracker"); sprintf(rtr_bw_log, "router-bw-tracker");
dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w"); dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w+");
if(dragonfly_rtr_bw_log != NULL) if(dragonfly_rtr_bw_log != NULL)
fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time"); fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time");
...@@ -1487,7 +1488,7 @@ int get_vcg_from_category(terminal_plus_message * msg) ...@@ -1487,7 +1488,7 @@ int get_vcg_from_category(terminal_plus_message * msg)
else if(strcmp(msg->category, "medium") == 0) else if(strcmp(msg->category, "medium") == 0)
return Q_MEDIUM; return Q_MEDIUM;
else else
tw_error(TW_LOC, "\n priority needs to be specified with qos_levels>1 %d", msg->category); tw_error(TW_LOC, "\n priority needs to be specified with qos_levels > 1 %s", msg->category);
static int get_rtr_bandwidth_consumption(router_state * s, int qos_lvl, int output_port) static int get_rtr_bandwidth_consumption(router_state * s, int qos_lvl, int output_port)
...@@ -1558,7 +1559,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess ...@@ -1558,7 +1559,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess
...@@ -1600,6 +1601,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess ...@@ -1600,6 +1601,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess
for(int k = 0; k < num_qos_levels; k++) for(int k = 0; k < num_qos_levels; k++)
...@@ -1615,7 +1617,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess ...@@ -1615,7 +1617,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess
s->qos_status[j][k] = Q_ACTIVE; s->qos_status[j][k] = Q_ACTIVE;
s->qos_data[j][k] = 0; s->qos_data[j][k] = 0;
//s->busy_time_sample[j] = 0; s->busy_time_sample[j] = 0;
if(tw_now(lp) > max_qos_monitor) if(tw_now(lp) > max_qos_monitor)
...@@ -1625,7 +1627,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess ...@@ -1625,7 +1627,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_plus_mess
tw_stime bw_ts = bw_reset_window + codes_local_latency(lp); tw_stime bw_ts = bw_reset_window + codes_local_latency(lp);
terminal_plus_message *m; terminal_plus_message *m;
tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp, tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp,
DRAGONFLY_CUSTOM_ROUTER, (void**)&m, NULL); DRAGONFLY_PLUS_ROUTER, (void**)&m, NULL);
m->type = R_BANDWIDTH; m->type = R_BANDWIDTH;
m->magic = router_magic_num; m->magic = router_magic_num;
tw_event_send(e); tw_event_send(e);
...@@ -1659,7 +1661,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_plus_messag ...@@ -1659,7 +1661,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_plus_messag
...@@ -1704,7 +1706,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_plus_messag ...@@ -1704,7 +1706,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_plus_messag
msg->num_cll++; msg->num_cll++;
terminal_plus_message * m; terminal_plus_message * m;
tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp, DRAGONFLY_CUSTOM, tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp, DRAGONFLY_PLUS,
(void**)&m, NULL); (void**)&m, NULL);
m->type = T_BANDWIDTH; m->type = T_BANDWIDTH;
m->magic = terminal_magic_num; m->magic = terminal_magic_num;
...@@ -1891,6 +1893,7 @@ static void router_credit_send(router_state *s, terminal_plus_message *msg, tw_l ...@@ -1891,6 +1893,7 @@ static void router_credit_send(router_state *s, terminal_plus_message *msg, tw_l
buf_msg->output_chan = msg->saved_channel; buf_msg->output_chan = msg->saved_channel;
...@@ -1966,7 +1969,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message ...@@ -1966,7 +1969,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message
...@@ -2104,7 +2107,7 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_plus_message ...@@ -2104,7 +2107,7 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_plus_message
if(bf->c1) { if(bf->c1) {
s->in_send_loop = 1; s->in_send_loop = 1;
if(bf->c3) if(bf->c3)
s->last_buf_full[0] = msg->saved_busy_time; s->last_buf_full = msg->saved_busy_time;
return; return;
...@@ -2143,7 +2146,7 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_plus_message ...@@ -2143,7 +2146,7 @@ static void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_plus_message
if(bf->c6) if(bf->c6)
s->busy_time = msg->saved_total_time; s->busy_time = msg->saved_total_time;
s->busy_time_sample = msg->saved_sample_time; s->busy_time_sample = msg->saved_sample_time;
...@@ -2175,11 +2178,11 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2175,11 +2178,11 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
if(vcg == -1) { if(vcg == -1) {
bf->c1 = 1; bf->c1 = 1;
s->in_send_loop = 0; s->in_send_loop = 0;
if(!s->last_buf_full[0]) if(!s->last_buf_full)
bf->c3 = 1; bf->c3 = 1;
msg->saved_busy_time = s->last_buf_full[0]; msg->saved_busy_time = s->last_buf_full;
s->last_buf_full[0] = tw_now(lp); s->last_buf_full = tw_now(lp);
return; return;
...@@ -2257,7 +2260,10 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2257,7 +2260,10 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
if(num_qos_levels > 1) if(num_qos_levels > 1)
next_vcg = get_next_vcg(s, bf, msg, lp); next_vcg = get_next_vcg(s, bf, msg, lp);
if(next_vcg >= 0)
if (cur_entry != NULL && s->vc_occupancy[next_vcg] + s->params->chunk_size <= s->params->cn_vc_size) { if (cur_entry != NULL && s->vc_occupancy[next_vcg] + s->params->chunk_size <= s->params->cn_vc_size) {
...@@ -2282,15 +2288,15 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2282,15 +2288,15 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
ts += tw_rand_unif(lp->rng); ts += tw_rand_unif(lp->rng);
model_net_method_idle_event(ts, 0, lp); model_net_method_idle_event(ts, 0, lp);
if (s->last_buf_full[0] > 0.0) { if (s->last_buf_full > 0.0) {
bf->c6 = 1; bf->c6 = 1;
msg->saved_total_time = s->busy_time; msg->saved_total_time = s->busy_time;
msg->saved_sample_time = s->busy_time_sample; msg->saved_sample_time = s->busy_time_sample;
s->busy_time += (tw_now(lp) - s->last_buf_full[0]); s->busy_time += (tw_now(lp) - s->last_buf_full);
s->busy_time_sample += (tw_now(lp) - s->last_buf_full[0]); s->busy_time_sample += (tw_now(lp) - s->last_buf_full);
s->last_buf_full[0] = 0.0; s->last_buf_full = 0.0;
return; return;
...@@ -2885,12 +2891,16 @@ static void terminal_buf_update(terminal_state *s, tw_bf *bf, terminal_plus_mess ...@@ -2885,12 +2891,16 @@ static void terminal_buf_update(terminal_state *s, tw_bf *bf, terminal_plus_mess
bf->c1 = 0; bf->c1 = 0;
bf->c2 = 0; bf->c2 = 0;
bf->c3 = 0; bf->c3 = 0;
int vcg = 0;
if(s->params->num_qos_levels > 1)
vcg = get_vcg_from_category(msg);
tw_stime ts = codes_local_latency(lp); tw_stime ts = codes_local_latency(lp);
s->vc_occupancy[0] -= s->params->chunk_size; s->vc_occupancy[vcg] -= s->params->chunk_size;
if (s->in_send_loop == 0 && s->terminal_msgs[0] != NULL) { if (s->in_send_loop == 0 && s->terminal_msgs[vcg] != NULL) {
tw_event *e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY_PLUS, (void **) &m, NULL); tw_event *e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY_PLUS, (void **) &m, NULL);
...@@ -2925,6 +2935,10 @@ void terminal_plus_event(terminal_state *s, tw_bf *bf, terminal_plus_message *ms ...@@ -2925,6 +2935,10 @@ void terminal_plus_event(terminal_state *s, tw_bf *bf, terminal_plus_message *ms
case T_BUFFER: case T_BUFFER:
terminal_buf_update(s, bf, msg, lp); terminal_buf_update(s, bf, msg, lp);
break; break;
case T_BANDWIDTH:
issue_bw_monitor_event_rc(s, bf, msg, lp);
break;
default: default:
printf("\n LP %d Terminal message type not supported %d ", (int) lp->gid, msg->type); printf("\n LP %d Terminal message type not supported %d ", (int) lp->gid, msg->type);
...@@ -3884,21 +3898,18 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3884,21 +3898,18 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
int num_qos_levels = s->params->num_qos_levels; int num_qos_levels = s->params->num_qos_levels;
int vcs_per_qos = s->params->num_vcs / num_qos_levels; int vcs_per_qos = s->params->num_vcs / num_qos_levels;
if(num_qos_levels > 1) if(num_qos_levels > 1 && !s->is_monitoring_bw)
if(s->is_monitoring_bw == 0)
s->is_monitoring_bw = 1; s->is_monitoring_bw = 1;
int vcg = 0; int vcg = 0;
...@@ -4359,6 +4370,10 @@ void router_plus_event(router_state *s, tw_bf *bf, terminal_plus_message *msg, t ...@@ -4359,6 +4370,10 @@ void router_plus_event(router_state *s, tw_bf *bf, terminal_plus_message *msg, t
router_buf_update(s, bf, msg, lp); router_buf_update(s, bf, msg, lp);
break; break;
case R_BANDWIDTH:
issue_rtr_bw_monitor_event(s, bf, msg, lp);
break;
default: default:
printf( printf(
"\n (%lf) [Router %d] Router Message type not supported %d dest " "\n (%lf) [Router %d] Router Message type not supported %d dest "
...@@ -4390,6 +4405,10 @@ void terminal_plus_rc_event_handler(terminal_state *s, tw_bf *bf, terminal_plus_ ...@@ -4390,6 +4405,10 @@ void terminal_plus_rc_event_handler(terminal_state *s, tw_bf *bf, terminal_plus_
terminal_buf_update_rc(s, bf, msg, lp); terminal_buf_update_rc(s, bf, msg, lp);
break; break;
case T_BANDWIDTH:
break;
default: default:
tw_error(TW_LOC, "\n Invalid terminal event type %d ", msg->type); tw_error(TW_LOC, "\n Invalid terminal event type %d ", msg->type);
...@@ -4411,6 +4430,10 @@ void router_plus_rc_event_handler(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -4411,6 +4430,10 @@ void router_plus_rc_event_handler(router_state *s, tw_bf *bf, terminal_plus_mess
case R_BUFFER: case R_BUFFER:
router_buf_update_rc(s, bf, msg, lp); router_buf_update_rc(s, bf, msg, lp);
break; break;
case R_BANDWIDTH:
issue_rtr_bw_monitor_event_rc(s, bf, msg, lp);
break;
...@@ -330,7 +330,6 @@ static model_net_event_return model_net_event_impl_base( ...@@ -330,7 +330,6 @@ static model_net_event_return model_net_event_impl_base(
if ( src_mn_lp == dest_mn_lp && message_size < (uint64_t)codes_node_eager_limit) if ( src_mn_lp == dest_mn_lp && message_size < (uint64_t)codes_node_eager_limit)
printf("\n Calling model-net noop event! %d %d %s", src_mn_lp, dest_mn_lp, category);
return model_net_noop_event(final_dest_lp, is_pull, offset, message_size, return model_net_noop_event(final_dest_lp, is_pull, offset, message_size,
remote_event_size, remote_event, self_event_size, self_event, remote_event_size, remote_event, self_event_size, self_event,
sender); sender);
Markdown is supported
0% or .
Please register or to comment
