Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
codes
codes
Commits
08cb4d92
Commit
08cb4d92
authored
Feb 26, 2014
by
Misbah Mubarak
Browse files
updates to i/o lang, setting the group_size and group_rank variables
parent
297f3aec
Changes
4
Show whitespace changes
Inline
Side-by-side
codes/CodesIOKernelTypes.h
View file @
08cb4d92
@@ -70,6 +70,7 @@ extern int64_t * var;
extern
int
inst_ready
extern
int
group_rank
extern
int
group_size
int
temp_group_rank
#endif
src/iokernellang/CodesKernelHelpers.c
View file @
08cb4d92
@@ -303,6 +303,7 @@ int codes_kernel_helper_bootstrap(char * io_kernel_path, char *
off_t
ksize
0
struct
stat
info
temp_group_rank
rank
/* get the kernel from the file */
codes_kernel_helper_parse_cf
io_kernel_path
io_kernel_def_path
io_kernel_meta_path
rank
task_info
src/iokernellang/codesImpl.c
View file @
08cb4d92
@@ -275,7 +275,9 @@ int64_t ex(
var
1
t1
inst_ready
1
return
1
group_rank
temp_group_rank
//printf("\n group rank %d ", *group_rank);
return
group_rank
case
GETGROUPSIZE
@@ -283,7 +285,9 @@ int64_t ex(
var
0
1
var
1
t1
inst_ready
1
group_size
t1
//printf("\n group size %d ", *group_size);
return
group_size
case
GETCURTIME
src/workload/codes-bgp-io-wrkld.c
View file @
08cb4d92
@@ -147,7 +147,7 @@ void bgp_io_workload_get_next(int rank, struct codes_workload_op *op)
case
CODES_WK_WRITE
op
u
write
file_id
next_wrkld
next_event
var
0
op
u
write
offset
rank
next_wrkld
next_event
var
2
op
u
write
offset
next_wrkld
next_event
var
2
op
u
write
size
next_wrkld
next_event
var
1
break
@@ -186,7 +186,7 @@ void bgp_io_workload_get_next(int rank, struct codes_workload_op *op)
case
CODES_WK_READ
op
u
read
file_id
next_wrkld
next_event
var
0
op
u
read
offset
rank
next_wrkld
next_event
var
2
op
u
read
offset
next_wrkld
next_event
var
2
op
u
read
size
next_wrkld
next_event
var
1
break
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
