Commit 067cfc4e authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
updating reverse handler for DF-Custom
parent c548151b
...@@ -2725,8 +2725,11 @@ static int do_global_adaptive_routing( router_state * s, ...@@ -2725,8 +2725,11 @@ static int do_global_adaptive_routing( router_state * s,
/* if a direct global channel exists for non-minimal route then give a priority to that. */ /* if a direct global channel exists for non-minimal route then give a priority to that. */
if(msg->my_l_hop == 1)
nonmin_chan_a = find_chan(s->router_id, intm_grp_id_a, s->params->num_routers); nonmin_chan_a = find_chan(s->router_id, intm_grp_id_a, s->params->num_routers);
nonmin_chan_b = find_chan(s->router_id, intm_grp_id_b, s->params->num_routers); nonmin_chan_b = find_chan(s->router_id, intm_grp_id_b, s->params->num_routers);
/* two possible nonminimal routes */ /* two possible nonminimal routes */
int rand_a = tw_rand_integer(lp->rng, 0, num_nonmin_chans_a - 1); int rand_a = tw_rand_integer(lp->rng, 0, num_nonmin_chans_a - 1);
int rand_b = tw_rand_integer(lp->rng, 0, num_nonmin_chans_b - 1); int rand_b = tw_rand_integer(lp->rng, 0, num_nonmin_chans_b - 1);
...@@ -2880,21 +2883,27 @@ static void router_packet_receive_rc(router_state * s, ...@@ -2880,21 +2883,27 @@ static void router_packet_receive_rc(router_state * s,
int output_port = msg->saved_vc; int output_port = msg->saved_vc;
int output_chan = msg->saved_channel; int output_chan = msg->saved_channel;
if(bf->c15)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c18) if(bf->c18)
if(bf->c16)
if(bf->c3)
if(bf->c20) if(bf->c20)
for(int i = 0; i < 8; i++) for(int i = 0; i < 8; i++)
//tw_rand_reverse_unif(lp->rng);
if(bf->c10) if(bf->c10)
...@@ -2975,10 +2984,9 @@ router_packet_receive( router_state * s, ...@@ -2975,10 +2984,9 @@ router_packet_receive( router_state * s,
* intermediate router ID which is in the same group. */ * intermediate router ID which is in the same group. */
if(src_grp_id != dest_grp_id) if(src_grp_id != dest_grp_id)
bf->c18 = 1;
if(cur_chunk->msg.my_l_hop >= 1) if(cur_chunk->msg.my_l_hop >= 1)
bf->c16 = 1; bf->c3 = 1;
vector<int> direct_rtrs = get_indirect_conns(s, lp, dest_grp_id); vector<int> direct_rtrs = get_indirect_conns(s, lp, dest_grp_id);
int indxa = tw_rand_integer(lp->rng, 0, direct_rtrs.size() - 1); int indxa = tw_rand_integer(lp->rng, 0, direct_rtrs.size() - 1);
intm_router_id = direct_rtrs[indxa]; intm_router_id = direct_rtrs[indxa];
...@@ -2990,6 +2998,7 @@ router_packet_receive( router_state * s, ...@@ -2990,6 +2998,7 @@ router_packet_receive( router_state * s,
else else
bf->c18 = 1;
intm_router_id = tw_rand_integer(lp->rng, 0, s->params->total_routers - 1); intm_router_id = tw_rand_integer(lp->rng, 0, s->params->total_routers - 1);
intm_router_id_b = tw_rand_integer(lp->rng, 0, s->params->total_routers - 1); intm_router_id_b = tw_rand_integer(lp->rng, 0, s->params->total_routers - 1);
if((intm_router_id/s->params->num_routers) == local_grp_id) if((intm_router_id/s->params->num_routers) == local_grp_id)
...@@ -3000,10 +3009,12 @@ router_packet_receive( router_state * s, ...@@ -3000,10 +3009,12 @@ router_packet_receive( router_state * s,
else else
bf->c15 = 1;
intm_router_id = (src_grp_id * s->params->num_routers) + intm_router_id = (src_grp_id * s->params->num_routers) +
(((s->router_id % s->params->num_routers) + (((s->router_id % s->params->num_routers) +
tw_rand_integer(lp->rng, 1, s->params->num_routers - 1)) % s->params->num_routers); tw_rand_integer(lp->rng, 1, s->params->num_routers - 1)) % s->params->num_routers);
/* progressive adaptive routing is only triggered when packet has to traverse a /* progressive adaptive routing is only triggered when packet has to traverse a
* global channel. It doesn't make sense to use it within a group */ * global channel. It doesn't make sense to use it within a group */
if(dest_grp_id != src_grp_id && if(dest_grp_id != src_grp_id &&
Markdown is supported
0% or .
Please register or to comment
