Commit 060f9674 authored by Matthieu Dorier's avatar Matthieu Dorier
Browse files
Merge branch 'cortex-links' into 'cortex'
Cortex links
See merge request !25
parents 4e95e6be 769a71d9
...@@ -179,6 +179,7 @@ src_util_templates_lp_template_dummy_main_SOURCES = \ ...@@ -179,6 +179,7 @@ src_util_templates_lp_template_dummy_main_SOURCES = \
# get rid of annoying unused function in template # get rid of annoying unused function in template
bin_PROGRAMS += src/workload/codes-workload-dump bin_PROGRAMS += src/workload/codes-workload-dump
bin_PROGRAMS += src/networks/topology-test
bin_PROGRAMS += src/network-workloads/model-net-mpi-replay bin_PROGRAMS += src/network-workloads/model-net-mpi-replay
bin_PROGRAMS += src/network-workloads/model-net-dumpi-traces-dump bin_PROGRAMS += src/network-workloads/model-net-dumpi-traces-dump
bin_PROGRAMS += src/network-workloads/model-net-synthetic bin_PROGRAMS += src/network-workloads/model-net-synthetic
...@@ -197,7 +198,7 @@ src_network_workloads_model_net_mpi_replay_SOURCES = \ ...@@ -197,7 +198,7 @@ src_network_workloads_model_net_mpi_replay_SOURCES = \
src_network_workloads_model_net_mpi_replay_CFLAGS = $(AM_CFLAGS) src_network_workloads_model_net_mpi_replay_CFLAGS = $(AM_CFLAGS)
src_network_workloads_model_net_synthetic_SOURCES = src/network-workloads/model-net-synthetic.c src_network_workloads_model_net_synthetic_SOURCES = src/network-workloads/model-net-synthetic.c
src_network_workloads_model_net_synthetic_custom_dfly_SOURCES = src/network-workloads/model-net-synthetic-custom-dfly.c src_network_workloads_model_net_synthetic_custom_dfly_SOURCES = src/network-workloads/model-net-synthetic-custom-dfly.c
src_networks_topology_test_SOURCES = src/networks/topology-test.c
#bin_PROGRAMS += src/network-workload/codes-nw-test #bin_PROGRAMS += src/network-workload/codes-nw-test
...@@ -26,7 +26,7 @@ ...@@ -26,7 +26,7 @@
#include <cortex/topology.h> #include <cortex/topology.h>
#endif #endif
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 1
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 4999 #define DFLY_HASH_TABLE_SIZE 4999
...@@ -3330,24 +3330,34 @@ static void dragonfly_custom_get_router_neighbor_list(void* topo, router_id_t r, ...@@ -3330,24 +3330,34 @@ static void dragonfly_custom_get_router_neighbor_list(void* topo, router_id_t r,
int src_col = r % params->num_router_cols; int src_col = r % params->num_router_cols;
/* First the routers in the same row */ /* First the routers in the same row */
for(int i = 0; i < params->num_router_cols; i++) int i = 0;
{ int offset = 0;
while(i < params->num_router_cols)
int neighbor = gid * params->num_routers + (src_row * params->num_router_cols) + i; int neighbor = gid * params->num_routers + (src_row * params->num_router_cols) + i;
if(neighbor != r) if(neighbor != r)
neighbors[i] = neighbor; {
} neighbors[offset] = neighbor;
offset++;
i++;
/* Now the routers in the same column. */ /* Now the routers in the same column. */
for(int i = 0; i < params->num_router_rows; i++) offset = 0;
i = 0;
while(i < params->num_router_rows)
int neighbor = gid * params->num_routers + src_col + (i * params->num_router_cols); int neighbor = gid * params->num_routers + src_col + (i * params->num_router_cols);
int offset = i + params->num_router_cols - 1;
neighbors[offset] = neighbor; {
neighbors[offset+params->num_router_cols-1] = neighbor;
offset++;
i++;
int g_offset = params->num_router_cols + params->num_router_cols - 2; int g_offset = params->num_router_cols + params->num_router_rows - 2;
/* Now fill up global channels */ /* Now fill up global channels */
set<router_id_t> g_neighbors; set<router_id_t> g_neighbors;
...@@ -3412,8 +3422,9 @@ static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node, ...@@ -3412,8 +3422,9 @@ static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node,
if(size < 3) if(size < 3)
return -1; return -1;
int rid = node / params->num_cn; int rid = (node / params->num_cn) % params->num_routers;
int gid = rid / params->num_routers; int rid_global = node / params->num_cn;
int gid = rid_global / params->num_routers;
int lid = node % params->num_cn; int lid = node % params->num_cn;
location[0] = gid; location[0] = gid;
/* turning on track lp will generate a lot of output messages */
#include <ross.h>
#include <inttypes.h>
#include "codes/codes-workload.h"
#include "codes/codes.h"
#include "codes/model-net.h"
/* TODO: Replace NUM_NODES and num_routers once we have functions to fetch
* topology node and router counts. Right now it is hard coded for Theta. */
#define NUM_NODES 3456
extern struct cortex_topology dragonfly_custom_cortex_topology;
int main(int argc, char** argv) {
int* net_ids;
int num_nets;
MPI_Init(&argc,&argv);
printf("\n %s ", argv[1]);
configuration_load(argv[1], MPI_COMM_WORLD, &config);
model_net_register();
net_ids = model_net_configure(&num_nets);
/* The topo argument is NULL since we are using global variables */
int num_routers = NUM_NODES/4;
void * topo_arg = NULL;
double local_bandwidth, global_bandwidth, cn_bandwidth;
int num_router_cols, num_router_rows, num_cns;
configuration_get_value_int(&config, "PARAMS", "num_router_rows", NULL, &num_router_rows);
configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", NULL, &num_cns);
configuration_get_value_int(&config, "PARAMS", "num_router_cols", NULL, &num_router_cols);
configuration_get_value_double(&config, "PARAMS", "local_bandwidth", NULL, &local_bandwidth);
configuration_get_value_double(&config, "PARAMS", "global_bandwidth", NULL, &global_bandwidth);
configuration_get_value_double(&config, "PARAMS", "cn_bandwidth", NULL, &cn_bandwidth);
/* First check for the same rows */
for(int i = 0; i < num_router_cols - 1; i++)
double router_bw = dragonfly_custom_cortex_topology.get_router_link_bandwidth(topo_arg, i, i+1);
assert(router_bw == local_bandwidth);
/* Now check for black links, connections in the same column. */
for(int i = 0; i < num_router_rows - 1; i++)
int src = i * num_router_cols;
int dest = (i + 1) * num_router_cols;
double router_bw = dragonfly_custom_cortex_topology.get_router_link_bandwidth(topo_arg, src, dest);
/* Now check for a router in a different row and column, should not have a
* connection in between them */
int dest = (i + 1) * num_router_cols + 2;
assert(router_bw == 0.0);
/* For global connections, check routers 0-3 connections to groups 1 and 5 */
for(int i = 0; i < 4; i++)
int dest = i + (num_router_rows * num_router_cols);
double router_bw = dragonfly_custom_cortex_topology.get_router_link_bandwidth(topo_arg, i, dest);
assert(router_bw == global_bandwidth);
dest = i + (5 * num_router_rows * num_router_cols);
/* For the first four compute nodes , get their compute node bandwidth now */
double cn_bw = dragonfly_custom_cortex_topology.get_compute_node_bandwidth(topo_arg, i);
assert(cn_bw == cn_bandwidth);
cn_bw = dragonfly_custom_cortex_topology.get_compute_node_bandwidth(topo_arg, -1);
assert(cn_bw == -1.0);
cn_bw = dragonfly_custom_cortex_topology.get_compute_node_bandwidth(topo_arg, 3800);
int grp1_offset = num_router_cols * num_router_rows;
/* Check connections for the first router row */
for(int i = grp1_offset; i < grp1_offset + num_router_cols; i++)
int num_neighbors = dragonfly_custom_cortex_topology.get_router_neighbor_count(topo_arg, i);
//printf("\n Router %d Number of neighbors %d ", i, num_neighbors);
assert(num_neighbors == 22);
router_id_t * routers = malloc(num_neighbors * sizeof(router_id_t));
dragonfly_custom_cortex_topology.get_router_neighbor_list(topo_arg, i, routers);
if(i == 0)
for(int j = 0; j < num_neighbors; j++)
printf("\n Router id %d ", routers[j]);
int32_t * location = malloc(2 * sizeof(int32_t));
dragonfly_custom_cortex_topology.get_router_location(topo_arg, i, location, sizeof(location));
assert(location[0] == 1 && location[1] == (i - grp1_offset));
free(location);
for(int k = 0; k < num_cns; k++)
cn_id_t cn_id = i * num_cns + k;
int32_t * loc_cn = malloc(3 * sizeof(int32_t));
dragonfly_custom_cortex_topology.get_compute_node_location(topo_arg, cn_id, loc_cn, sizeof(loc_cn));
//printf("\n location[0] %d location[1] %d location[2] %d ", location[0], location[1], location[2]);
assert(location[0] == 1 && location[1] == (i - grp1_offset) && location[2] == k);
free(loc_cn);
router_id_t rid = dragonfly_custom_cortex_topology.get_router_from_compute_node(topo_arg, cn_id);
assert(rid == i);
int cn_count = dragonfly_custom_cortex_topology.get_router_compute_node_count(topo_arg, i);
cn_id_t * cn_ids = malloc(sizeof(cn_id_t) * cn_count);
dragonfly_custom_cortex_topology.get_router_compute_node_list(topo_arg, i, cn_ids);
for(int k = 0; k < cn_count; k++)
assert(cn_ids[k] == cn_id);
MPI_Finalize();
Markdown is supported
0% or .
Please register or to comment
