Commit 04a43e9b authored by mubarak's avatar mubarak
Browse files
Fixing dragonfly print
parent 56ec9353
...@@ -1928,7 +1928,7 @@ dragonfly_terminal_final( terminal_state * s, ...@@ -1928,7 +1928,7 @@ dragonfly_terminal_final( terminal_state * s,
if(!s->terminal_id) if(!s->terminal_id)
written = sprintf(s->output_buf, "# Format <LP id> <Terminal ID> <Total Data Size> <Total Time Spent> <# Msgs finished> <# Packets finished> <# Chunks finished> <Avg hops>\n"); written = sprintf(s->output_buf, "# Format <LP id> <Terminal ID> <Total Data Size> <Total Time Spent> <# Msgs finished> <# Packets finished> <# Chunks finished> <Avg hops>\n");
written += sprintf(s->output_buf + written, "%lu %u %ld %lf %ld %ld %lf\n", lp->gid, s->terminal_id, s->total_msg_size, s->total_time, s->finished_msgs, s->finished_packets, s->finished_chunks, (float)s->total_hops/s->finished_chunks); written += sprintf(s->output_buf + written, "%lu %u %ld %lf %ld %ld %ld %ld\n", lp->gid, s->terminal_id, s->total_msg_size, s->total_time, s->finished_msgs, s->finished_packets, s->finished_chunks, (float)s->total_hops/s->finished_chunks);
lp_io_write(lp->gid, "dragonfly-msg-stats", written, s->output_buf); lp_io_write(lp->gid, "dragonfly-msg-stats", written, s->output_buf);
if(s->terminal_msgs[0] != NULL) if(s->terminal_msgs[0] != NULL)
Markdown is supported
0% or .
Please register or to comment
