Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
03ebb0ff
Commit
03ebb0ff
authored
Mar 20, 2017
by
Matthieu Dorier
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
replaced MPI_COMM_WORLD with MPI_COMM_CODES
parent
2bf51bc4
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
5 additions
and
5 deletions
+5
-5
src/network-workloads/model-net-synthetic-custom-dfly.c
+5
-5
No files found.
View file @
03ebb0ff
@@ -358,10 +358,10 @@ int main(
return
0
return
0
MPI_Comm_rank
MPI_COMM_
WORLD
rank
MPI_Comm_rank
MPI_COMM_
CODES
rank
MPI_Comm_size
MPI_COMM_
WORLD
nprocs
MPI_Comm_size
MPI_COMM_
CODES
nprocs
configuration_load
argv
2
MPI_COMM_
WORLD
config
configuration_load
argv
2
MPI_COMM_
CODES
config
model_net_register
model_net_register
svr_add_lp_type
svr_add_lp_type
@@ -401,12 +401,12 @@ int main(
do_lp_io
1
do_lp_io
1
int
flags
lp_io_use_suffix
LP_IO_UNIQ_SUFFIX
0
int
flags
lp_io_use_suffix
LP_IO_UNIQ_SUFFIX
0
int
ret
lp_io_prepare
lp_io_dir
flags
io_handle
MPI_COMM_
WORLD
int
ret
lp_io_prepare
lp_io_dir
flags
io_handle
MPI_COMM_
CODES
assert
ret
0
"lp_io_prepare failure"
assert
ret
0
tw_run
tw_run
if
do_lp_io
if
do_lp_io
int
ret
lp_io_flush
io_handle
MPI_COMM_
WORLD
int
ret
lp_io_flush
io_handle
MPI_COMM_
CODES
assert
ret
0
"lp_io_flush failure"
assert
ret
0
model_net_report_stats
net_id
net_id
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
