Commit 03dd1867 authored by Misbah Mubarak's avatar Misbah Mubarak Committed by Neil McGlohon
Dragonfly Plus: Comments and Config changes
parent 7398e4ad
...@@ -48,11 +48,7 @@ PARAMS ...@@ -48,11 +48,7 @@ PARAMS
# file # file
num_cns_per_router="4"; num_cns_per_router="4";
# number of global channels per router # number of global channels per router
<<<<<<< HEAD num_global_channels="4";
num_global_channels="10";
num_global_channels="3";
>>>>>>> a1ef291a9dac... Modify dfp config
# network config file for intra-group connections # network config file for intra-group connections
intra-group-connections="../src/network-workloads/conf/dragonfly-custom/neil-intra"; intra-group-connections="../src/network-workloads/conf/dragonfly-custom/neil-intra";
# network config file for inter-group connections # network config file for inter-group connections
...@@ -156,6 +156,7 @@ struct dragonfly_plus_param ...@@ -156,6 +156,7 @@ struct dragonfly_plus_param
int num_cn; int num_cn;
int intra_grp_radix; int intra_grp_radix;
// MM: won't need these four variables, remove
int num_col_chans; int num_col_chans;
int num_row_chans; int num_row_chans;
int num_router_rows; int num_router_rows;
...@@ -342,7 +343,6 @@ struct router_state ...@@ -342,7 +343,6 @@ struct router_state
int* global_channel; int* global_channel;
tw_stime* next_output_available_time; tw_stime* next_output_available_time;
tw_stime* cur_hist_start_time;
tw_stime** last_buf_full; tw_stime** last_buf_full;
tw_stime* busy_time; tw_stime* busy_time;
...@@ -356,7 +356,6 @@ struct router_state ...@@ -356,7 +356,6 @@ struct router_state
int *queued_count; int *queued_count;
struct rc_stack * st; struct rc_stack * st;
int* last_sent_chan;
int** vc_occupancy; int** vc_occupancy;
int64_t* link_traffic; int64_t* link_traffic;
int64_t * link_traffic_sample; int64_t * link_traffic_sample;
...@@ -364,9 +363,6 @@ struct router_state ...@@ -364,9 +363,6 @@ struct router_state
const char * anno; const char * anno;
const dragonfly_plus_param *params; const dragonfly_plus_param *params;
int* prev_hist_num;
int* cur_hist_num;
char output_buf[4096]; char output_buf[4096];
char output_buf2[4096]; char output_buf2[4096];
...@@ -594,16 +590,15 @@ static void dragonfly_read_config(const char * anno, dragonfly_plus_param *param ...@@ -594,16 +590,15 @@ static void dragonfly_read_config(const char * anno, dragonfly_plus_param *param
routing = -1; routing = -1;
if(routing == PROG_ADAPTIVE) /* MM: This should be 2 for dragonfly plus*/
p->num_vcs = 10; p->num_vcs = 2;
else
p->num_vcs = 8;
rc = configuration_get_value_int(&config, "PARAMS", "num_groups", anno, &p->num_groups); rc = configuration_get_value_int(&config, "PARAMS", "num_groups", anno, &p->num_groups);
if(rc) { if(rc) {
printf("Number of groups not specified. Aborting"); printf("Number of groups not specified. Aborting");
MPI_Abort(MPI_COMM_CODES, 1); MPI_Abort(MPI_COMM_CODES, 1);
/* MM: Don't need the following four config variables. Remove. */
rc = configuration_get_value_int(&config, "PARAMS", "num_col_chans", anno, &p->num_col_chans); rc = configuration_get_value_int(&config, "PARAMS", "num_col_chans", anno, &p->num_col_chans);
if(rc) { if(rc) {
// printf("\n Number of links connecting chassis not specified, setting to default value 3 "); // printf("\n Number of links connecting chassis not specified, setting to default value 3 ");
...@@ -980,13 +975,9 @@ void router_plus_setup(router_state * r, tw_lp * lp) ...@@ -980,13 +975,9 @@ void router_plus_setup(router_state * r, tw_lp * lp)
r->global_channel = (int*)malloc(p->num_global_channels * sizeof(int)); r->global_channel = (int*)malloc(p->num_global_channels * sizeof(int));
r->next_output_available_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime)); r->next_output_available_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
r->cur_hist_start_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
r->link_traffic = (int64_t*)malloc(p->radix * sizeof(int64_t)); r->link_traffic = (int64_t*)malloc(p->radix * sizeof(int64_t));
r->link_traffic_sample = (int64_t*)malloc(p->radix * sizeof(int64_t)); r->link_traffic_sample = (int64_t*)malloc(p->radix * sizeof(int64_t));
r->cur_hist_num = (int*)malloc(p->radix * sizeof(int));
r->prev_hist_num = (int*)malloc(p->radix * sizeof(int));
// r->last_sent_chan = (int*) malloc(p->num_router_rows * sizeof(int));
r->vc_occupancy = (int**)malloc(p->radix * sizeof(int*)); r->vc_occupancy = (int**)malloc(p->radix * sizeof(int*));
r->in_send_loop = (int*)malloc(p->radix * sizeof(int)); r->in_send_loop = (int*)malloc(p->radix * sizeof(int));
r->pending_msgs = r->pending_msgs =
...@@ -1004,16 +995,12 @@ void router_plus_setup(router_state * r, tw_lp * lp) ...@@ -1004,16 +995,12 @@ void router_plus_setup(router_state * r, tw_lp * lp)
rc_stack_create(&r->st); rc_stack_create(&r->st);
// for(int i = 0; i < p->num_router_rows; i++)
// r->last_sent_chan[i] = 0;
for(int i=0; i < p->radix; i++) for(int i=0; i < p->radix; i++)
// Set credit & router occupancy // Set credit & router occupancy
r->busy_time[i] = 0.0; r->busy_time[i] = 0.0;
r->busy_time_sample[i] = 0.0; r->busy_time_sample[i] = 0.0;
r->next_output_available_time[i]=0; r->next_output_available_time[i]=0;
r->cur_hist_start_time[i] = 0;
r->link_traffic[i]=0; r->link_traffic[i]=0;
r->link_traffic_sample[i] = 0; r->link_traffic_sample[i] = 0;
r->cur_hist_num[i] = 0; r->cur_hist_num[i] = 0;
...@@ -1043,7 +1030,8 @@ void router_plus_setup(router_state * r, tw_lp * lp) ...@@ -1043,7 +1030,8 @@ void router_plus_setup(router_state * r, tw_lp * lp)
return; return;
/* MM: These packet events (packet_send, packet_receive etc.) will be used as is, basically, the routing functions will
* be changed only. */
/* dragonfly packet event , generates a dragonfly packet on the compute node */ /* dragonfly packet event , generates a dragonfly packet on the compute node */
static tw_stime dragonfly_plus_packet_event( static tw_stime dragonfly_plus_packet_event(
model_net_request const * req, model_net_request const * req,
...@@ -1112,6 +1100,8 @@ static void dragonfly_plus_packet_event_rc(tw_lp *sender) ...@@ -1112,6 +1100,8 @@ static void dragonfly_plus_packet_event_rc(tw_lp *sender)
return; return;
/*MM: This will also be used as is. This is meant to sent a credit back to the
* sending router. */
/*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/ /*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/
static void router_credit_send(router_state * s, terminal_plus_message * msg, static void router_credit_send(router_state * s, terminal_plus_message * msg,
tw_lp * lp, int sq) { tw_lp * lp, int sq) {
...@@ -2192,6 +2182,9 @@ void dragonfly_plus_router_final(router_state * s, ...@@ -2192,6 +2182,9 @@ void dragonfly_plus_router_final(router_state * s,
rc_stack_destroy(s->st); rc_stack_destroy(s->st);
/*MM: These statistics will need to be updated for dragonfly plus.
* Especially the meta file information on router ports still have green
* and black links. */
const dragonfly_plus_param *p = s->params; const dragonfly_plus_param *p = s->params;
int written = 0; int written = 0;
if(!s->router_id) if(!s->router_id)
...@@ -2228,6 +2221,9 @@ void dragonfly_plus_router_final(router_state * s, ...@@ -2228,6 +2221,9 @@ void dragonfly_plus_router_final(router_state * s,
lp_io_write(lp->gid, (char*)"dragonfly-router-traffic", written, s->output_buf2); lp_io_write(lp->gid, (char*)"dragonfly-router-traffic", written, s->output_buf2);
/* MM: This function needs to be modified. Add static routing for fat tree here
* if needed. This would rather be simplified to return the connected spine or
* leaf router alone. */
static vector<int> get_intra_router(router_state * s, int src_router_id, int dest_router_id, int num_rtrs_per_grp) static vector<int> get_intra_router(router_state * s, int src_router_id, int dest_router_id, int num_rtrs_per_grp)
/* Check for intra-group connections */ /* Check for intra-group connections */
...@@ -2280,6 +2276,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des ...@@ -2280,6 +2276,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des
return intersection; return intersection;
/*MM: This function would need major routing changes. */
/* get the next stop for the current packet /* get the next stop for the current packet
* determines if it is a router within a group, a router in another group * determines if it is a router within a group, a router in another group
* or the destination terminal */ * or the destination terminal */
...@@ -2387,6 +2384,7 @@ get_next_stop(router_state * s, ...@@ -2387,6 +2384,7 @@ get_next_stop(router_state * s,
return router_dest_id; return router_dest_id;
/*MM: This function would need major changes according to routing algorithm. */
/* gets the output port corresponding to the next stop of the message */ /* gets the output port corresponding to the next stop of the message */
static int static int
get_output_port( router_state * s, get_output_port( router_state * s,
...@@ -2469,6 +2467,8 @@ get_output_port( router_state * s, ...@@ -2469,6 +2467,8 @@ get_output_port( router_state * s,
return output_port; return output_port;
/* MM: This will no longer be needed for dragonfly plus. We will have to
* implement progressive adaptive routing though. */
static void do_local_adaptive_routing(router_state * s, static void do_local_adaptive_routing(router_state * s,
tw_lp * lp, tw_lp * lp,
terminal_plus_message * msg, terminal_plus_message * msg,
...@@ -2526,6 +2526,7 @@ static void do_local_adaptive_routing(router_state * s, ...@@ -2526,6 +2526,7 @@ static void do_local_adaptive_routing(router_state * s,
msg->path_type = NON_MINIMAL; msg->path_type = NON_MINIMAL;
/*MM: Change this to do_adaptive_routing. Do you know what are the congestion sensing mechanism for adaptive routing in dragonfly plus? Is it similar to dragonfly? */
static int do_global_adaptive_routing( router_state * s, static int do_global_adaptive_routing( router_state * s,
...@@ -2811,6 +2812,8 @@ static void router_packet_receive_rc(router_state * s, ...@@ -2811,6 +2812,8 @@ static void router_packet_receive_rc(router_state * s,
/* MM: This will need changes for the port selection and routing part. The
* progressive adaptive routing would need modification as well. */
/* Packet arrives at the router and a credit is sent back to the sending terminal/router */ /* Packet arrives at the router and a credit is sent back to the sending terminal/router */
static void static void
router_packet_receive( router_state * s, router_packet_receive( router_state * s,
...@@ -3073,6 +3076,8 @@ static void router_packet_send_rc(router_state * s, ...@@ -3073,6 +3076,8 @@ static void router_packet_send_rc(router_state * s,
s->in_send_loop[output_port] = 1; s->in_send_loop[output_port] = 1;
/* MM: I think this mostly stays the same. */
/* routes the current packet to the next stop */ /* routes the current packet to the next stop */
router_packet_send( router_state * s, router_packet_send( router_state * s,
Markdown is supported
0%
or
Please register or to comment
