Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
010ab8a3
Commit
010ab8a3
authored
Aug 14, 2013
by
Philip Carns
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
remove unused interval merge and rb trees
parent
068648d8
Changes
5
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
5 changed files
with
0 additions
and
2831 deletions
+0
-2831
src/Makefile.subdir
src/Makefile.subdir
+0
-4
src/util/interval-merge-tree.c
+0
-1495
src/util/interval-merge-tree.h
+0
-160
src/util/red-black-tree.c
+0
-1049
src/util/red-black-tree.h
+0
-123
No files found.
src/Makefile.subdir
View file @
010ab8a3
@@ -88,10 +88,6 @@ src_libcodes_base_a_SOURCES = \
src/modelconfig/txt_configfile.c
codes/tools.h
src/util/tools.c
src/util/codes-callbacks.h
src/util/codes-callbacks.c
src/util/codes_mapping.c
deleted
100644 → 0
View file @
068648d8
This diff is collapsed.
deleted
100644 → 0
View file @
068648d8
#ifndef RB_TREE_H
#define RB_TREE_H
#ifdef __cplusplus
extern
"C"
#endif
#include <stdlib.h>
#include <stdint.h>
/* defines */
/* colors: red, black, and 0 (for undefined) */
#define RB_TREE_COLOR_BLACK 'B'
#define RB_TREE_COLOR_RED 'R'
#define RB_TREE_COLOR_NONE 0
/* ops: hints for directing how the rank and max values should be updated */
#define RB_TREE_INSERT 0
#define RB_TREE_DELETE 1
#define RB_TREE_RANK_INC 2
#define RB_TREE_RANK_DEC 3
/* overlap cases: what type of overlap was detected */
#define RB_TREE_INTERVAL_NO_OVERLAP 0
#define RB_TREE_INTERVAL_C1 1
#define RB_TREE_INTERVAL_C2 2
#define RB_TREE_INTERVAL_C3 3
#define RB_TREE_INTERVAL_C4 4
#define RB_TREE_INTERVAL_SAME 5
#define RB_TREE_NODE_POOL_SIZE_MAX 16
#define RB_TREE_CONSUME 2
/* data types */
* interval_merge_tree_interval_t, describes the range of the interval the node encompasses
* start - the start of the interval
* end - the end of the interval
struct
size_t
start
size_t
end
typedef
struct
* interval_merge_tree_key_t, container for the key and value pair stored in the node
* key - the key for the node
* value - the value associated with the key
struct
void
key
void
value
typedef
struct
struct
interval_merge_tree_interval_ll
void
data
void
key
struct
next
typedef
struct
interval_merge_tree_interval_ll_t
* interval_merge_tree_node_t, the node structure for the rb tree
* key - the key / value pair
* left - the left child of the node
* right - the right child of the node
* parent - the parent of the node
* size - the number of descendants of this node (includes itself)
* max - the max interval of descendant nodes (includes self)
* interval - the range associated with this node
* color - the color of the node
struct
key
struct
left
struct
right
struct
parent
unsigned
int
size
unsigned
int
max
interval
ll_head
ll_tail
char
color
char
node_pool
struct
consumer
typedef
struct
/* functions */
int
interval_merge_tree_interval_ll_init
node
void
data
int
interval_merge_tree_interval_ll_destroy
ll
int
interval_merge_tree_destroy_entire_key
key
interval_merge_tree_create_node
int
interval_merge_tree_destroy_node
node
int
interval_merge_tree_destroy_tree
node
int
interval_merge_tree_insert
node
key
root
int
interval_merge_tree_insert_interval
node
key
root
int
interval_merge_tree_print_tree
node
int
node
int
level
char
dir
interval_merge_tree_key_find
node
size_t
k
interval_merge_tree_node_find
node
size_t
k
interval_merge_tree_delete
root
node
interval_merge_tree_find_delete
root
size_t
k
interval_merge_tree_node_find_rank
node
size_t
k
int
op
interval_merge_tree_interval_search
root
interval
unsigned
int
oc
int
interval_merge_tree_merge_intervals
root
n_node
key
size_t
interval_merge_tree_size
node
interval_merge_tree_delete_min_node
root
#ifdef __cplusplus
#endif
#endif
deleted
100644 → 0
View file @
068648d8
deleted
100644 → 0
View file @
068648d8
#ifndef SRC_COMMON_UTIL_RED_BLACK_TREE_H
#define SRC_COMMON_UTIL_RED_BLACK_TREE_H
/* derived from IOFSL's red-black tree */
#ifdef __cplusplus
extern
"C"
#endif
#include <stdlib.h>
#include <stdint.h>
/* defines */
/* data types */
* red_black_tree_interval_t, describes the range of the interval the node encompasses
struct
size_t
start
size_t
end
typedef
struct
* red_black_tree_key_t, container for the key and value pair stored in the node
struct
red_black_tree_key
void
key
void
value
typedef
struct
red_black_tree_key
struct
red_black_tree_interval_ll
void
data
void
key
struct
next
typedef
struct
red_black_tree_interval_ll_t
* red_black_tree_node_t, the node structure for the rb tree
struct
red_black_tree_node
key
struct
red_black_tree_node
left
struct
red_black_tree_node
right
struct
red_black_tree_node
parent
unsigned
int
size
unsigned
int
max
interval
ll_head
ll_tail
char
color
char
node_pool
struct
red_black_tree_node
consumer
typedef
struct
red_black_tree_node
/* functions */
int
red_black_tree_interval_ll_init
node
void
data
int
red_black_tree_interval_ll_destroy
ll
int
red_black_tree_destroy_entire_key
key
red_black_tree_create_node
int
red_black_tree_destroy_node
node
int
red_black_tree_destroy_tree
node
int
red_black_tree_insert
node
key
root
int
red_black_tree_insert_interval
node
key
root
int
red_black_tree_print_tree
node
int
node
int
level
char
dir
red_black_tree_key_find
node
size_t
k
red_black_tree_node_find
node
size_t
k
red_black_tree_delete
root
node
red_black_tree_find_delete
root
size_t
k
red_black_tree_interval_search
root
interval
unsigned
int
oc
int
red_black_tree_merge_intervals
root
n_node
key
size_t
red_black_tree_size
node
red_black_tree_delete_min_node
root
#ifdef __cplusplus
#endif
#endif
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
