Commit 00aa08fc authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding router link traffic stats for dragonfly
parent 4f033d4b
...@@ -25,5 +25,5 @@ PARAMS ...@@ -25,5 +25,5 @@ PARAMS
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="512"; message_size="512";
routing="nonminimal"; routing="minimal";
...@@ -207,7 +207,10 @@ struct terminal_state ...@@ -207,7 +207,10 @@ struct terminal_state
tw_stime last_buf_full; tw_stime last_buf_full;
tw_stime busy_time; tw_stime busy_time;
char output_buf[4096]; char output_buf[4096];
/* For LP suspend functionality */
int error_ct;
/* terminal event type (1-4) */ /* terminal event type (1-4) */
...@@ -282,6 +285,7 @@ struct router_state ...@@ -282,6 +285,7 @@ struct router_state
int* cur_hist_num; int* cur_hist_num;
char output_buf2[4096];
static short routing = MINIMAL; static short routing = MINIMAL;
...@@ -1319,7 +1323,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1319,7 +1323,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
N_finished_msgs--; N_finished_msgs--;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
struct dfly_qhash_entry * d_entry_pop = msg->saved_hash; struct dfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st);
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
s->rank_tbl_pop++; s->rank_tbl_pop++;
...@@ -1432,8 +1436,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1432,8 +1436,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
msg->saved_avg_time = s->total_time; msg->saved_avg_time = s->total_time;
s->total_time += (tw_now(lp) - msg->travel_start_time); s->total_time += (tw_now(lp) - msg->travel_start_time);
if(s->terminal_id == TRACK)
printf("\n Updating travel time %lf ", s->total_time);
msg->saved_total_time = dragonfly_total_time; msg->saved_total_time = dragonfly_total_time;
dragonfly_total_time += tw_now( lp ) - msg->travel_start_time; dragonfly_total_time += tw_now( lp ) - msg->travel_start_time;
total_hops += msg->my_N_hop; total_hops += msg->my_N_hop;
...@@ -1531,7 +1533,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1531,7 +1533,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
/* Remove the hash entry */ /* Remove the hash entry */
qhash_del(hash_link); qhash_del(hash_link);
msg->saved_hash = tmp; rc_stack_push(lp, tmp, free, s->st);
s->rank_tbl_pop--; s->rank_tbl_pop--;
return; return;
...@@ -1991,6 +1993,24 @@ void dragonfly_router_final(router_state * s, ...@@ -1991,6 +1993,24 @@ void dragonfly_router_final(router_state * s,
sprintf(s->output_buf + written, "\n"); sprintf(s->output_buf + written, "\n");
lp_io_write(lp->gid, "dragonfly-router-stats", written, s->output_buf); lp_io_write(lp->gid, "dragonfly-router-stats", written, s->output_buf);
written = 0;
if(!s->router_id)
written = sprintf(s->output_buf2, "# Format <LP ID> <Group ID> <Router ID> <Link traffic per router port(s)>");
written += sprintf(s->output_buf2 + written, "\n # Router ports in the order: %d local channels, %d global channels ",
p->num_routers, p->num_global_channels);
written += sprintf(s->output_buf2 + written, "\n %ld %d %d",
lp->gid,
s->router_id / p->num_routers,
s->router_id % p->num_routers);
for(int d = 0; d < p->num_routers + p->num_global_channels; d++)
written += sprintf(s->output_buf2 + written, " %ld", s->link_traffic[d]);
sprintf(s->output_buf2 + written, "\n");
lp_io_write(lp->gid, "dragonfly-router-traffic", written, s->output_buf2);
/* Get the number of hops for this particular path source and destination groups */ /* Get the number of hops for this particular path source and destination groups */
...@@ -1685,7 +1685,7 @@ static void torus_report_stats() ...@@ -1685,7 +1685,7 @@ static void torus_report_stats()
if(!g_tw_mynode) if(!g_tw_mynode)
printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us finished packets %ld finished hops %ld \n", printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us finished packets %lld finished hops %lld \n",
(float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000, total_finished_packets, avg_hops); (float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000, total_finished_packets, avg_hops);
Markdown is supported
0% or .
Please register or to comment
